Home » Eclipse Projects » Eclipse Platform » Contributing the extension point programatically(Contributing the extension point programatically)
Contributing the extension point programatically [message #642147] Tue, 30 November 2010 01:12 Go to next message
I am trying to contribute an extension from start method of my bundle activator. The following thread helped me for that. It mandates that we set a startup parameter allowing the registry to accept null user token, this seems to be a sort of the security thing. i want to do it without giving the startup parameter, for which i need the security token accessible in the plugin.
http://dev.eclipse.org/newslists/news.eclipse.platform.rcp/m sg36505.html
in the class ExtensionRegistry there is a method getTemporaryUserToken() to access the token, but it is clearly mentioned not to use the method and should contact the equinox team if somebody needs to use them.
I feel that bundle should be able to contribute an extension freely without any of the security hurdle. please mention if am missing something.
Jagadish Suri
Re: Contributing the extension point programatically [message #642260 is a reply to message #642147] Tue, 30 November 2010 10:53 Go to previous message
jagadish suri wrote:
You found information on what is supported today.
You may want this, but other apps and products built on eclipse
especially require that contributed bundles cannot arbitrarily fiddle
with the extension registry.
Since you control your app, you can do it no problem with the null user
token.
In my app, you'll not be fiddling with my extension registry thank you
very much! :-)
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Previous Topic:Timeout when loading bundles
Next Topic:project dependency on antbuilder product
Current Time: Sat Jul 26 14:41:03 EDT 2025
Powered by FUDForum. Page generated in 0.29110 seconds
