Home » Modeling » TMF (Xtext) » Cross-reference problem.
Cross-reference problem. [message #642143] Tue, 30 November 2010 00:12 Go to next message
If I have a grammar like this:
HLMModel	:
			'module' name=ID '(' (inputs+=ID (',' inputs+=ID)*)? ')'
				('returns' '(' (outputs+=ID (',' outputs+=ID)*) ')')? '{'
				startup=Startup
				(states+=MyState)+
Startup		:
			'startup' '{' nextState=[MyState] '}' ;
MyState :
		'state' name=ID '{' 'next' '=' nextState=[MyState] '}';
and an example like this:
module T() {
startup {a}
state a { next = b}
state b { next = a}
The cross-referencing to the State doesn't seem to work. However, if I change my HLMModel rule by commenting out the 'module' part, i.e.,
HLMModel	:
//			'module' name=ID '(' (inputs+=ID (',' inputs+=ID)*)? ')'
//				('returns' '(' (outputs+=ID (',' outputs+=ID)*) ')')? '{'
				startup=Startup
				(states+=MyState)+
Then, cross-referencing works OK. What am I doing wrong in the above grammar? Thank you for any ideas.
Re: Cross-reference problem. [message #642185 is a reply to message #642143] Tue, 30 November 2010 04:59 Go to previous messageGo to next message
Have you got the SimpleNamesFragment or the QualifiedNamesFragment configured in your .mwe2 workflow file? I'm betting on the latter Wink
Re: Cross-reference problem. [message #642311 is a reply to message #642185] Tue, 30 November 2010 13:29 Go to previous message
Thank you for your help. I had enabled SimpleNamesFragment. By disabling that, and enabling QualifiedNamesFragment, it works nicely now!
Thanks.
Previous Topic:Performance of saving a XtextResource
Next Topic:Insert Automatic NewLine After 80 character In editor Xtext
Current Time: Fri Jul 11 23:01:26 EDT 2025
Powered by FUDForum. Page generated in 0.27026 seconds
