Home » Eclipse Projects » Virgo » [virgo kernel] ExtensionsHookConfigurator breaks resource loading in Pax Web/Felix Webconsole
[virgo kernel] ExtensionsHookConfigurator breaks resource loading in Pax Web/Felix Webconsole [message #641824] Sun, 28 November 2010 09:56 Go to next message
I've been trying to get Apache Felix webconsole going in a bare Virgo kernel distribuion but I have been puzzled by that the appearance is not the same as when executed in a "naked" Equinox setup. More specifically, in the Virgo kernel the webconsole's stylesheets and javascripts don't seem to be handled correctly. Digging deeper, I found that it is the ExtensionsHookConfigurator that seems to be causing problems since when taken out of the equation the webconsole displays as it should.
How to reproduce?
First, you need to download the following bundle files and add them under lib/kernel
https://ebr.springsource.com/repository/app/bundle/version/d ownload?name=com.springsource.javax.servlet&version=2.5. 0&type=binary
http://repo2.maven.org/maven2/org/ops4j/pax/web/pax-web-jett y-bundle/0.8.1/pax-web-jetty-bundle-0.8.1.jar
http://apache.dataphone.se//felix/org.apache.felix.webconsol e-3.1.6.jar
Then make the following configuration changes:
First, add the bundles to the lib/org.eclipse.virgo.kernel.launch.properties file.
  file:lib/kernel/org.eclipse.virgo.kernel.deployer-2.1.0.RELEASE.jar@start,\
  file:lib/kernel/org.eclipse.virgo.kernel.model-2.1.0.RELEASE.jar@start,\
  file:lib/kernel/org.eclipse.virgo.kernel.kerneldmfragment-2.1.0.RELEASE.jar,\
- file:lib/kernel/org.eclipse.virgo.kernel.shell-2.1.0.RELEASE.jar@start
+ file:lib/kernel/org.eclipse.virgo.kernel.shell-2.1.0.RELEASE.jar@start,\
+  file:lib/kernel/com.springsource.javax.servlet-2.5.0.jar@start,\
+  file:lib/kernel/pax-web-jetty-bundle-0.8.1.jar@start,\
+  file:lib/kernel/org.apache.felix.webconsole-3.1.6.jar@start
Second, we turn off the user region for these tests.
In config/org.eclipse.virgo.kernel.userregion.properties comment out the following lines:
-baseBundles = \
- file:lib/kernel/org.eclipse.virgo.kernel.userregion-2.1.0.RELEASE.jar@start,\
- file:lib/kernel/org.eclipse.virgo.kernel.osgicommand-2.1.0.RELEASE.jar@start
+# baseBundles = \
+#  file:lib/kernel/org.eclipse.virgo.kernel.userregion-2.1.0.RELEASE.jar@start,\
+#  file:lib/kernel/org.eclipse.virgo.kernel.osgicommand-2.1.0.RELEASE.jar@start
Now, start Virgo via the startup script (NOTE: ExtensionsHookConfigurator is enabled) and go to http://localhost:8080/system/console.
Note that the page appearance is quite bleak.
Now, try the same thing with the ExtensionsHookConfigurator disbabled:
Comment out the following line in lib/org.eclipse.virgo.kernel.launch.properties and then restart Virgo.
-osgi.hook.configurators.include=org.eclipse.virgo.osgi.extensions.equinox.hooks.ExtensionsHookConfigurator
+#osgi.hook.configurators.include=org.eclipse.virgo.osgi.extensions.equinox.hooks.ExtensionsHookConfigurator
Now, the appearance of the webconsole page is a lot more sophisticated.
Is this a bug in the ExtensionsHookConfigurator?
[Updated on: Sun, 28 November 2010 10:33] by Moderator
Re: [virgo kernel] ExtensionsHookConfigurator breaks resource loading in Pax Web/Felix Webconsole [message #641927 is a reply to message #641824] Mon, 29 November 2010 04:41 Go to previous messageGo to next message
Well, it's either a bug or a subtle interaction between Virgo's Equinox hooks and this particular application.
We'll need to carve out some time to delve into this. This week we have a Virgo F2F meeting and the week after we have some urgent work to do on the tooling, so this will have to go into the backlog.
On the assumption that there is a bug, please would you raise a bugzilla so we don't lose track of this. Thanks.
Re: [virgo kernel] ExtensionsHookConfigurator breaks resource loading in Pax Web/Felix Webconsole [message #642090 is a reply to message #641824] Mon, 29 November 2010 13:46 Go to previous messageGo to next message
Filed a bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=331370
best regards, Peter
Re: [virgo kernel] ExtensionsHookConfigurator breaks resource loading in Pax Web/Felix Webconsole [message #642921 is a reply to message #642090] Fri, 03 December 2010 05:44 Go to previous messageGo to next message
Excellent. Thanks Peter.
Re: [virgo kernel] ExtensionsHookConfigurator breaks resource loading in Pax Web/Felix Webconsole [message #649704 is a reply to message #642090] Thu, 20 January 2011 06:48 Go to previous message
Just for anyone that comes along looking for answers. I am looking in to this and documenting progressing the bug Peter raised.
Previous Topic:File not found
Next Topic:Create a web bundle project, and deploy it within Eclipse
Current Time: Wed Jul 23 12:05:44 EDT 2025
Powered by FUDForum. Page generated in 0.31489 seconds
