Home » Eclipse Projects » Plugin Development Environment (PDE) » Running and debugging eclipse tests(problems in how to correctly import, install eclipse Testting framework and debug through the eclipse test cases)
icon5.gif  Running and debugging eclipse tests [message #642033] Mon, 29 November 2010 10:40
I would like to go through (run and debug the test cases created by eclipse in order to follow the same testing procedure for a plugin I am developing.
I tried two method but did not manage to get test cases working
1) Downloaded all the CVS test cases as shown in this tutorial:
http://www.vogella.de/articles/EclipseCodeAccess/article.htm l#versioncontrol. The problem with this method is that I get a lot of missing dependencies even after downloading all the projects on the CVS. Do I need some jar files?
2) Downloaded the JUnit Plugin Tests and Automated Testing Framework and Example Plug-ins from the eclipse download site ( http://download.eclipse.org/eclipse/downloads/drops/R-3.6.1- 201009090800/index.php) and tried to follow the instructions bundled in them as well as the tutorial on http://www.eclipse.org/articles/Article-PDE-Automation/autom ation.html (Part 2 that describes Automated Tests). I could not import/build the Automated Testing Framework properly in eclipse.
Could someone please point me in the right directions whether one of these methods is correct.. and if I can find some tutorial that describes better how to get the test cases working.
Previous Topic:Producing a group archive with p2.gathering=true
Next Topic:Unique plugin id for each project
Current Time: Fri Jul 18 18:31:26 EDT 2025
Powered by FUDForum. Page generated in 0.06105 seconds
