[Xtext] IllegalStateException "Stack of grammar elements seems to be corrupt." [message #641760] |
Sat, 27 November 2010 12:10  |
Originally posted by: koester.matthias.gmx.de
After changing my grammar - which included using the options backtrack
and memoize - my content assist throws an IllegalStateException "Stack
of grammar elements seems to be corrupt.". Here is the full stacktrace:
java.lang.RuntimeException: java.lang.IllegalStateException: Stack of
at
org.eclipse.xtext.ui.editor.contentassist.antlr.AbstractCont entAssistParser.getFollowElements(AbstractContentAssistParse r.java:163)
at
org.eclipse.xtext.ui.editor.contentassist.antlr.AbstractCont entAssistParser.getFollowElements(AbstractContentAssistParse r.java:84)
at
org.eclipse.xtext.ui.editor.contentassist.antlr.ParserBasedC ontentAssistContextFactory.computeFollowElements(ParserBased ContentAssistContextFactory.java:517)
at
org.eclipse.xtext.ui.editor.contentassist.antlr.ParserBasedC ontentAssistContextFactory.computeFollowElements(ParserBased ContentAssistContextFactory.java:483)
at
org.eclipse.xtext.ui.editor.contentassist.antlr.ParserBasedC ontentAssistContextFactory.computeFollowElements(ParserBased ContentAssistContextFactory.java:478)
at
org.eclipse.xtext.ui.editor.contentassist.antlr.ParserBasedC ontentAssistContextFactory.createContexts(ParserBasedContent AssistContextFactory.java:191)
at
org.eclipse.xtext.ui.editor.contentassist.antlr.ParserBasedC ontentAssistContextFactory.create(ParserBasedContentAssistCo ntextFactory.java:130)
at
org.eclipse.xtext.ui.editor.contentassist.CompletionProposal Computer.exec(CompletionProposalComputer.java:48)
at
org.eclipse.xtext.ui.editor.contentassist.CompletionProposal Computer.exec(CompletionProposalComputer.java:1)
at
org.eclipse.xtext.util.concurrent.IStateAccess$AbstractImpl. readOnly(IStateAccess.java:40)
at
org.eclipse.xtext.ui.editor.model.XtextDocument.readOnly(Xte xtDocument.java:70)
at
org.eclipse.xtext.ui.editor.contentassist.XtextContentAssist Processor.computeCompletionProposals(XtextContentAssistProce ssor.java:79)
at
org.eclipse.jface.text.contentassist.ContentAssistant.comput eCompletionProposals(ContentAssistant.java:1834)
at
org.eclipse.jface.text.contentassist.CompletionProposalPopup .computeProposals(CompletionProposalPopup.java:556)
at
org.eclipse.jface.text.contentassist.CompletionProposalPopup .access$16(CompletionProposalPopup.java:553)
at
org.eclipse.jface.text.contentassist.CompletionProposalPopup $2.run(CompletionProposalPopup.java:488)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at
org.eclipse.jface.text.contentassist.CompletionProposalPopup .showProposals(CompletionProposalPopup.java:482)
at
org.eclipse.jface.text.contentassist.ContentAssistant.showPo ssibleCompletions(ContentAssistant.java:1660)
at
org.eclipse.jface.text.source.SourceViewer.doOperation(Sourc eViewer.java:913)
at
org.eclipse.jface.text.source.projection.ProjectionViewer.do Operation(ProjectionViewer.java:1534)
at
org.eclipse.ui.texteditor.ContentAssistAction$1.run(ContentA ssistAction.java:82)
at
org.eclipse.ui.texteditor.ContentAssistAction.run(ContentAss istAction.java:80)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at org.eclipse.ui.commands.ActionHandler.execute(ActionHandler. java:185)
at
org.eclipse.ui.internal.handlers.LegacyHandlerWrapper.execut e(LegacyHandlerWrapper.java:109)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
at
org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:508)
at
org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:169)
at
org.eclipse.ui.internal.keys.WorkbenchKeyboard.executeComman d(WorkbenchKeyboard.java:468)
at
org.eclipse.ui.internal.keys.WorkbenchKeyboard.press(Workben chKeyboard.java:786)
at
org.eclipse.ui.internal.keys.WorkbenchKeyboard.processKeyEve nt(WorkbenchKeyboard.java:885)
at
org.eclipse.ui.internal.keys.WorkbenchKeyboard.filterKeySequ enceBindings(WorkbenchKeyboard.java:567)
at
org.eclipse.ui.internal.keys.WorkbenchKeyboard.access$3(Work benchKeyboard.java:508)
at
org.eclipse.ui.internal.keys.WorkbenchKeyboard$KeyDownFilter .handleEvent(WorkbenchKeyboard.java:123)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:152 5)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1257)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1282)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1267)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1294 )
at org.eclipse.swt.widgets.Widget.gtk_key_press_event(Widget.ja va:730)
at org.eclipse.swt.widgets.Control.gtk_key_press_event(Control. java:2839)
at
org.eclipse.swt.widgets.Composite.gtk_key_press_event(Compos ite.java:734)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1743)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4794 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4372 )
at org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(Native Method)
at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(OS.java:81 63)
at org.eclipse.swt.widgets.Display.eventProc(Display.java:1239)
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Na tive Method)
at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS. java:2224)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3169)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2629)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2593)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 27)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:670)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:663)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at
at
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Looking at the source code didn't give me a hint what might have gone
wrong. And searching bugzilla and google didn't help either. The only
unusual thing I do in my project is to use a post process to move some
features from subclasses to their common super class. Can this cause
this problem? Or is it caused by my grammar?
Matthias
Re: [Xtext] IllegalStateException "Stack of grammar elements seems to be corrupt." [message #641811 is a reply to message #641809] |
Sun, 28 November 2010 06:09   |
Hi Matthias,
at a first glance I'd doubt that a scope provider implementation can
cause this exception.
Sebastian
Am 28.11.10 12:03, schrieb Matthias Köster:
> Hi Sebastian,
> Removing memoize=true didn't help, but it looks like my scope providers
> are causing the problem: I copied my grammar to a new xtext project
> without my scope providers and there the content assist worked. Of
> course without the interesting stuff ;-)
> I will investigate this problem further, but just wanted to hear if you
> think that the problem can also be caused by my scope providers?
> Best regards,
> Matthias
> Sebastian Zarnekow schrieb:
>> Hi Matthias,
>> the exception signals a violation of an invariant in the content
>> assist parser. It is unlikely that your Ecore model post-processing
>> has something to do with it. Could you please file a ticket with a
>> reproducable sample attached? Does it help if you turn memoization off?
>> Regards,
>> Sebastian
Re: [Xtext] IllegalStateException "Stack of grammar elements seems to be corrupt." [message #641823 is a reply to message #641815] |
Sun, 28 November 2010 09:31   |
Hi Matthias,
Antlr uses an internal timeout when it's analyzing the grammar. Your
observation should not have something to do with first and second time
generation.
See here:
http://20000frames.blogspot.com/2010/09/dealing-with-could-n ot-even-do-k1-for.html
Sebastian
Am 28.11.10 12:36, schrieb Matthias Köster:
> I encountered another strange thing: When I disable the backtrack and
> memoize option for my parser.antlr.XtextAntlrUiGeneratorFragment the
> generation fails. That's fine, but when I now regenerate everything with
> option backtrack=true I get the following ANTLR error:
> error(10): internal error:
> org.antlr.tool.Grammar.createLookaheadDFA(Grammar.java:864): could not
> even do k=1 for decision 10
> Now the strange thing:
> When I generate everything a second time, the ANTLR error doesn't show
> up! As far as I can see my MWE should clean the generated source before
> each run, but now it seems to store some state between runs... Or why
> does my generator fail during the first run and fails on the second run?
> Regards,
> Matthias
>> Hi Matthias,
>> Regards,
>> Sebastian
Re: [Xtext] IllegalStateException "Stack of grammar elements seems to be corrupt." [message #641901 is a reply to message #641823] |
Mon, 29 November 2010 03:05   |
Hi Sebastian,
I fixed my problem by patching the
class. Stripping down my xtext project to a reasonable size requires
more time than I can invest right now, but my example is open sourced at
google code. The patch is actually very easy, to me it looks like an if
statement in method getFollowElements(final
AbstractInternalContentAssistParser parser, AbstractElement
elementToParse, String[] ruleNames, int startIndex)
isn't correct.
So how can we proceed to solve the problem? Should I file a bug request
with a pointer to my open source project or is it enough when I add the
patch to my bug request?
Matthias
> Hi Matthias,
> generation.
> See here:
> Regards,
> Sebastian
Re: [Xtext] IllegalStateException "Stack of grammar elements seems to be corrupt." [message #641915 is a reply to message #641895] |
Mon, 29 November 2010 03:37   |
Hi Alex,
Thx for your hint, but I already knew that I can start from a metamodel
and then create a Xtext grammar to map to it ;-)
Since my post processor doesn't seem to cause the problem, I'm fine with
my current approach ;-)
I like the DRY principle and it's great that Xtext is supporting it. For
me one of the main benefits of using Xtext is the fast turn around time.
Before using Xtext I used ANTLR and DLTK. That gave me the full power of
ANTLR (like predicates, etc.), but I had to synchronize my grammar with
my metamodel manually. That was really time consuming and wasn't fun at
all.
Another stumbling block was using DLTK. It's really a great framework,
but it's still lacking documentation. And the source code isn't very
easy to understand, especially when compared with Xtext! And the Xtext
community is much bigger and much nicer;-)
Matthias
Alexander Nittka schrieb:
>> I've read the documentation about the model interference and currently
>> I don't see another
>> way than a post processor to shape my metamodel as I want it to look
>> like;-)
> have you tried instantiating an existing meta model? You need not use
> the one generated automatically.
> Alex
Re: [Xtext] IllegalStateException "Stack of grammar elements seems to be corrupt." [message #641923 is a reply to message #641901] |
Mon, 29 November 2010 04:31   |
Hi Matthias,
a patch and a test case would be great.
Sebastian
Am 29.11.10 09:05, schrieb Matthias Köster:
> Hi Sebastian,
> isn't correct.
> Best regards,
> Matthias
>> Hi Matthias,
>> generation.
>> See here:
>> Regards,
>> Sebastian
FUDForum. Page generated in 0.31063 seconds
