| Cannot Use Helios [message #641766] |
Sat, 27 November 2010 13:40 |
--BOOM--
!ENTRY org.eclipse.jface 4 2 2010-11-27 12:38:04.677
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.jface".
!STACK 0
at org.eclipse.php.internal.core.format.FormatPreferencesSuppor t.verifyValidity(FormatPreferencesSupport.java:100)
at org.eclipse.php.internal.core.format.FormatPreferencesSuppor t.getIndentationChar(FormatPreferencesSupport.java:89)
at org.eclipse.php.internal.ui.editor.configuration.PHPStructur edTextViewerConfiguration.getIndentPrefixes(PHPStructuredTex tViewerConfiguration.java:448)
at org.eclipse.wst.sse.ui.internal.StructuredTextViewer.configu re(StructuredTextViewer.java:311)
at org.eclipse.php.internal.ui.compare.MergeSourceViewer.config ure(MergeSourceViewer.java:542)
at org.eclipse.php.internal.ui.compare.TextMergeViewer$Contribu torInfo.internalSetDocument(TextMergeViewer.java:546)
at org.eclipse.php.internal.ui.compare.TextMergeViewer$Contribu torInfo.setDocument(TextMergeViewer.java:434)
at org.eclipse.php.internal.ui.compare.TextMergeViewer.updateCo ntent(TextMergeViewer.java:2569)
at org.eclipse.php.internal.ui.compare.ContentMergeViewer.inter nalRefresh(ContentMergeViewer.java:814)
at org.eclipse.php.internal.ui.compare.ContentMergeViewer.input Changed(ContentMergeViewer.java:704)
at org.eclipse.jface.viewers.ContentViewer.setInput(ContentView er.java:274)
at org.eclipse.compare.CompareViewerSwitchingPane.setInput(Comp areViewerSwitchingPane.java:276)
at org.tigris.subversion.subclipse.ui.wizards.dialogs.SvnWizard CommitPage.setCompareInput(SvnWizardCommitPage.java:557)
at org.tigris.subversion.subclipse.ui.wizards.dialogs.SvnWizard CommitPage.access$20(SvnWizardCommitPage.java:551)
at org.tigris.subversion.subclipse.ui.wizards.dialogs.SvnWizard CommitPage$15.doubleClick(SvnWizardCommitPage.java:393)
at org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredV iewer.java:824)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
at org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(S tructuredViewer.java:822)
at org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSel ect(AbstractTreeViewer.java:1421)
at org.eclipse.jface.viewers.CheckboxTreeViewer.handleDoubleSel ect(CheckboxTreeViewer.java:283)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSe lected(StructuredViewer.java:1225)
at org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEven t(OpenStrategy.java:238)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.ja va:235)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:296)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3657)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.tigris.subversion.subclipse.ui.actions.CommitAction.conf irmCommit(CommitAction.java:329)
at org.tigris.subversion.subclipse.ui.actions.CommitAction$1.ru n(CommitAction.java:114)
at org.tigris.subversion.subclipse.ui.repository.RepositoryMana ger.run(RepositoryManager.java:375)
at org.tigris.subversion.subclipse.ui.actions.SVNAction$1.run(S VNAction.java:231)
at org.tigris.subversion.subclipse.ui.actions.SVNAction$2.run(S VNAction.java:240)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.tigris.subversion.subclipse.ui.actions.SVNAction.run(SVN Action.java:237)
at org.tigris.subversion.subclipse.ui.actions.CommitAction.exec ute(CommitAction.java:102)
at org.tigris.subversion.subclipse.ui.actions.SVNAction.run(SVN Action.java:56)
at org.eclipse.ui.actions.ActionDelegate.runWithEvent(ActionDel egate.java:70)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:241)
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 38)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
FUDForum. Page generated in 0.19395 seconds
