Home » Modeling » Graphiti » Hide individual resize handles?
Hide individual resize handles? [message #640389] Sun, 21 November 2010 10:10 Go to next message
I've seen that the method canResizeShape of the resize feature is called with
width, height, x and y set to -1 to determine whether to show the resize
handles. If the method returns false, the GFNonResizableEditPolicy is used and
thus all resizing handles are disabled. I've got some shapes that can be
resized horizontally, but require a fixed height. Is there a way to disable
only the top and bottom resize handles? I know that I can prevent the actual
resizing later on, but the current situation isn't optimal from the user's
point of view: the visual appearance of the element pretends to be resizable
in any direction, and you have to actually try and grab it just to be shown
that it can't be resized...
Volker
* Volker Wegert * http://www.volker-wegert.de/contact *
I used to drive a Heisenbergmobil, but everytime I looked at the speedometer,
I got lost.
Re: Hide individual resize handles? [message #640509 is a reply to message #640389] Mon, 22 November 2010 06:43 Go to previous messageGo to next message
Hi Volker,
unfortunately this is currently not possible.
Please open a bugzilla if you want that we extend the framework for this resize behaviour.
BR,
Matthias
Re: Hide individual resize handles? [message #641503 is a reply to message #640509] Thu, 25 November 2010 12:31 Go to previous messageGo to next message
Hi Matthias,
in another thread opened by me Tim Kaiser replied "I think it makes
sense to not show the resize handles if resize is not enabled."
I wouldn't show selection handles either in this case.
But the orange rectangle (without handles) could be shown.
Changing the primary/secondary selection colors is not really satisfactory.
I think it would make sense to change in
org.eclipse.graphiti.ui.internal.util.draw2d.GFHandleHelper. createShapeHandles(GraphicalEditPart,
IConfigurationProvider, int, boolean)
the line
list.add(new GFSurroundingHandle(owner, cp, supportedResizeDirections,
movable));
to
list.add(new GFSurroundingHandle(owner, cp, PositionConstants.NSEW,
movable));
To have the surrounding handle in any case.
Does that make sense to you?
Another suggestion is for the case that e.g. only horizontal resize is
allowed. Then I would only draw the eastern and western handles since
the corner handles usually allow to resize in both directions (I noticed
though that the cursor is changing in accordance to the resize
configuration).
And finally: it would be nice if not only color and style of the
surrounding handle could be change but also the line width.
Henrik
Am 22.11.2010 12:43, schrieb Matthias Gorning:
> I think it makes sense to not show the resize handles if resize is not
>> enabled.
Re: Hide individual resize handles? [message #643975 is a reply to message #640509] Wed, 08 December 2010 16:05 Go to previous messageGo to next message
Matthias Gorning <matthias.gorning@sap.com> writes:
After some more digging, I was pleased to find out this is not true - at least
in the current CVS version. The ResizeShapeFeature just has to override
getResizeConfiguration(). If the returned object signals that it's not
possible to resize the object either horizontally or vertically, the resize
handles are not shown. This is sufficient for my application, with one small
exception: The method getResizeConfiguration() does not know about the object
to be resized, so it can't determine the resizing properties
dynamically. Would it be possible to pass the ResizeShapeContext as a
parameter?
BTW, there's a typo in IResizeConfiguration - isHoriz_a_ntalResizeAllowed. Do
you want a separate bugzilla entry for this?
Volker
"Ich fürchte, die Tiere betrachten den Menschen als ein Wesen ihresgleichen,
das in höchst gefährlicher Weise den gesunden Tierverstand verloren hat."
(Nietzsche)
Re: Hide individual resize handles? [message #644029 is a reply to message #643975] Thu, 09 December 2010 02:37 Go to previous messageGo to next message
Hi Volker,
yes, we can pass the ResizeShapeContext as a
parameter to the method getResizeConfiguration(). Please, open a bugzilla.
I couldn't find the typo in IResizeConfiguration. Where exactly is it?
BR,
Matthias
Re: Hide individual resize handles? [message #644449 is a reply to message #644029] Sat, 11 December 2010 09:38 Go to previous messageGo to next message
Done, 332360.
Horizantal instead of Horizontal. It's also in the patch.
Volker
"Aktienkurse sind wie Erdgeschoßwohnungen. Ständig gibt es Einbrüche." (Ingolf
Lück, Wochenshow)
Re: Hide individual resize handles? [message #644462 is a reply to message #644449] Sat, 11 December 2010 11:57 Go to previous messageGo to next message
Volker Wegert <mail@volker-wegert.de> writes:
> Done, 332360.
....ouch. There's a subsequent problem: I've got some figures that can't be
resized at all. If I switch off both horizontal and vertical resizing, the
editor no longer hightlights the element when it is selected. Applying the
change proposed by Henrik Rentz-Reichert in this thread (change
GFHandleHelper.createShapeHandles: replace new GFSurroundingHandle(owner, cp,
supportedResizeDirections with new GFSurroundingHandle(owner, cp,
PositionConstants.NSEW) fixes this. I'll add this to the bug.
Volker
"Ein Gerücht geht so schnell um die Welt, da hat sich die Wahrheit noch nicht
einmal die Schnürsenkel gebunden." (Hans Joachim Rauschenbach)
Re: Hide individual resize handles? [message #644558 is a reply to message #644462] Mon, 13 December 2010 04:40 Go to previous message
Changes commited as proposed.
BR,
Matthias
Previous Topic:design question - bundle feature classes as local classes?
Next Topic:Linking Domain Models to Diagram
Current Time: Tue Jul 22 22:58:13 EDT 2025
Powered by FUDForum. Page generated in 0.18517 seconds
