Home » Modeling » Epsilon » Installation problems
Installation problems [message #638987] Sun, 14 November 2010 08:14 Go to next message
Hi all,
I was just trying to install Epsilon for first time via the Update Manager of Eclipse 3.6M7 and I have the following error:
Cannot complete the install because one or more required items could not be found.
Software currently installed: Epsilon EMF/GMF Live Validation (Incubation) 0.8.9.201004151115 (org.eclipse.epsilon.evl.emf.validation.feature.feature.grou p 0.8.9.201004151115)
Missing requirement: Epsilon EMF Model Support (Incubation) 0.8.9.201004151115 (org.eclipse.epsilon.emc.emf 0.8.9.201004151115) requires 'bundle org.eclipse.emf.mapping.xsd2ecore 0.0.0' but it could not be found
Cannot satisfy dependency:
From: Epsilon EMF/GMF Live Validation (Incubation) 0.8.9.201004151115 (org.eclipse.epsilon.evl.emf.validation.feature.feature.grou p 0.8.9.201004151115)
To: org.eclipse.epsilon.emc.emf 0.0.0
So, what shall I do? I really would like to use the live validation features...
Greetings,
Hristina
Re: Installation problems [message #638990 is a reply to message #638987] Sun, 14 November 2010 08:51 Go to previous messageGo to next message
After "full" Eclipse update... no notification for errors while installing! So, I assumed it is OK now... But, nothing was installed! After trying again via the Update Manager, the same error message received.
The same exception when installing from binaries from local site...
Not fun... I really would like to try the validation!
Any suggestions?!
[Updated on: Sun, 14 November 2010 09:33] by Moderator
Re: Installation problems [message #638995 is a reply to message #638990] Sun, 14 November 2010 09:39 Go to previous messageGo to next message
Glad it wasn't something more complicated :) Thanks for letting us know.
Dimitris
On 14/11/2010 15:51, Hristina wrote:
> Solved after "full" Eclipse update...
Re: Installation problems [message #638996 is a reply to message #638995] Sun, 14 November 2010 09:52 Go to previous messageGo to next message
But I am not glad... Smile
I cannot even start!
Can you give me some ideas how to install Epsilon, please!
Hristina
Re: Installation problems [message #639095 is a reply to message #638996] Mon, 15 November 2010 04:41 Go to previous messageGo to next message
Hi Hristina,
From your previous post I understood that you managed to install
Epsilon successfully. Isn't this the case?
Dimitris
On 14/11/2010 16:52, Hristina wrote:
> But I am not glad... :)
> Hristina
Re: Installation problems [message #639117 is a reply to message #639095] Mon, 15 November 2010 06:18 Go to previous messageGo to next message
Hi Dimitris,
No, I did not succeed!
I tried to install Epsilon in two different ways (via Update site and via binaries) and non of these worked. In both cases I had the same exception --> see in the first post.
So, do I have any other options?
Greetings,
Hristina
Re: Installation problems [message #639124 is a reply to message #639117] Mon, 15 November 2010 06:25 Go to previous messageGo to next message
Could you please try the interim update site?
Dimitris
Hristina <xmoneva@gmail.com> wrote:
> Hi Dimitris,
> Greetings,
> Hristina
Re: Installation problems [message #641485 is a reply to message #639124] Thu, 25 November 2010 10:57 Go to previous messageGo to next message
Sorry for the delay...
I did try the interim site as well - also do not work in my case (same exception)!
And now what? :)
Hristina
Re: Installation problems [message #641491 is a reply to message #641485] Thu, 25 November 2010 11:10 Go to previous message
Hi Hristina,
I've just downloaded a fresh copy of the latest Eclipse Modeling
distribution (for Windows) from here
http://www.eclipse.org/downloads/
and installed Epsilon from the stable update site
http://download.eclipse.org/modeling/gmt/epsilon/updates/
without any problems. Could you please try with the latest Eclipse
Modeling distribution in case the problem you're encountering comes from
a glitch in the M7 version you're currently using?
Dimitris
> exception)!
> And now what? :)
> Hristina
Previous Topic:Is there any way of stopping Console from clearing ?
Next Topic:[Eugenia]: SVN checkout
Current Time: Fri Jul 25 19:28:56 EDT 2025
Powered by FUDForum. Page generated in 0.08081 seconds
