Add java element decoration to a common navigator [message #641380] |
Thu, 25 November 2010 04:17  |
I have created a common navigator to display resources (Projects, Folders, Files) on my own arrangement, with customized label and content providers.
Nevertheless, I would like to subscribe to marker service on resources when error are encountered (an error decorator is added on Java file, folder and project image when error occurs on a java class file).
Is there a way to use jdt processing or must I develop this part?
Thanks for any help
Alain
Re: Add java element decoration to a common navigator [message #663718 is a reply to message #663047] |
Wed, 06 April 2011 06:11  |
Quote: | Could you please explain me what do you mean by "Project, Folder and File classes were extended"
I created classes which extends org.eclipse.core.internal.resources.Project, org.eclipse.core.internal.resources.File, ...
Quote: | how you overrode the getImage method"
I created my own MenuNavigator which use a specific MenuLabelProvider which is inspired by org.eclipse.jdt.internal.ui.navigator.JavaNavigatorLabelProv ider.
The label provider has a field DelegateLabelProvider delegeteLabelProvider which refers to a class which extends org.eclipse.jdt.internal.ui.packageview.PackageExplorerLabel Provider.
Hope it helps you
FUDForum. Page generated in 0.04167 seconds
