Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Browser execute() mechanism kills existing JS(How can you send multiple execute() methods to completion)
Browser execute() mechanism kills existing JS [message #640674] Mon, 22 November 2010 13:44 Go to next message
I'm not entirely sure on the exact problem but the symptoms are the following:
We have a bunch of jQuery animations running.
We call execute() again, and it seems to stop it running, you can see this here:
http://imagebin.org/124153
Basically each line fades in, and when they are quick in succesion the previous ones don't bother finishing. The gaps in the image, are actually parts that didn't get very far in the animation.
Is there a reason why execute() would kill the previous requests, and how can we work around this?
Re: Browser execute() mechanism kills existing JS [message #640931 is a reply to message #640674] Tue, 23 November 2010 10:00 Go to previous messageGo to next message
I haven't heard of this before. All js execution is managed by the
underlying native browser, so it's possible that this would work in some
implementations but not in others, due to either a bug or a design
difference.
One possible workaround you can try is to do your execute()s in an
asyncExec(...) block so that they're run when the event queue is idle (which
_may_ indicate that the fade has completed). I'm not sure if this will
help, but if you want to try it, do your execute() like:
browser.getDisplay().asyncExec(new Runnable() {
public void run() {
if (browser.isDisposed()) return;
browser.execute(...);
If this does not help then it's hard to know what's happening here or if it
can be worked around without a test case. It would also be helpful to know
if it happens in the different native browser implementations (eg.- on
Windows the Browser embeds IE, on Linux it embeds either gecko/mozilla or
webkitgtk, etc.). If you're able to reduce your case to a small case that
reproduces the problem (ideal template:
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/org. eclipse.swt.snippets/src/org/eclipse/swt/snippets/Snippet148 .java )
then please log a report with swt at
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=SWT .
Grant
"Steve R" <eclipse@sjrx.net> wrote in message
news:icedeu$egr$1@news.eclipse.org...
> following:
> here:
Re: Browser execute() mechanism kills existing JS [message #641338 is a reply to message #640931] Wed, 24 November 2010 23:58 Go to previous message
Okay so after many attempts at trying to make a test case, we are convinced that it's something with jQuery and something else... execute() doesn't seem to kill currently running JS.
[Updated on: Wed, 24 November 2010 23:58] by Moderator
Previous Topic:Drawing a border around a Combo
Next Topic:Tableviewer reset
Current Time: Wed Jul 23 06:10:15 EDT 2025
Powered by FUDForum. Page generated in 0.09521 seconds
