View stack not correctly painted for a newly opened perspective [message #639858] |
Thu, 18 November 2010 02:41  |
--------------060503060409060405000101
Hi, I have a problem in 3.6.x with perspectives that have a lot of views
in a single view stack: If opened for the first time, the tab of the
currently shown view is not selected and the blue line around the view
is broken. The thin line between the tabs and the view is also missing
(this is visible if the stack does not contain the active part). I have
attached a screenshot showing this with a simple example.
To reproduce this, it is enough to create a new plug-in project with the
RCP Mail Example template. In the file Perspective.java change the
method to look like this:
folder.addPlaceholder(View.ID + ":*");
folder.addView(View.ID);
for (int i = 0; i < 20; i++) {
folder.addView(View.ID + ":" + i);
layout.getViewLayout(NavigationView.ID).setCloseable(false);
(just adding the three lines with the loop).
I'd be greatful for any pointers and workarounds
Peter
Content-Type: image/png;
name="Bildschirmfoto 2010-11-18 um 08.31.52.png"
filename="Bildschirmfoto 2010-11-18 um 08.31.52.png"
iVBORw0KGgoAAAANSUhEUgAAAdYAAABYCAIAAADHtUERAAAXVmlDQ1BJQ0Mg UHJvZmlsZQAA
eAHVWXk8Vd3X3+fO93JN1zzP8zwPmeeMmYm45nm8hDQYUqGBEFEKGYuSKSkh VCRDoVBKQiSF
lPE96nme3+/9/N73v/efd38+Z5/vXWvttfc9a52911oHALZFcnh4MIIOgJBQ SqSNsR6vk7ML
L/YNoAK0gA5AgIPsFRWua21tDv7X9mMEloPbsNServ9V7H9m0Hv7RHkBAFnD bE/vKK8QGNcD
gNDzCo+kAID8CdMHDlPCYYx6AmPGSHiBMJ7Yw35/8PIe9vyN0ajfMnY2+gCg WQHAUZPJkX4A
EAVhOm+Mlx+sh2gAAIYh1DsgFACSE4y1vPzJ3gCw5cEykiEhYXv4MYxFPf9N j9+/YTLZ8x+d
ZLLfP/jPf4FHwhMbBESFB5Pjfv/4v+xCgqPh5/W7McA9dWiw5Z5tmOFrzpts YAbfOeFrJzz4
t81gGYjdJ9TeFqbtYclQT0urv7CWb6SRDYzhsZB1OEVvD8PPDPINp1jb/UU/ Fu+vbwljapie
7RNl+Leea4Hk/Xs2o4HpdZHRNvYwFoTxo6gYW0MYwx4FfYz3t3P8S2bV28fg LzoC4RtgZPpH
BsEQQDHdm4sRtjl/UJjZ3hrguRDKwAwEAx8QDSLhPhRIAXOgDwz+6qWALyDD nBiYFwWCwCcY
h8AjwuAxYTDm/UtO/z8oRr/H+cHj/rtGXuAFy0b/M+ef2XjhOf/WGQC8Yfw3 nQzPscfbW12U
e0DSv+b8W2JP3+/VyFbLzstu/b0mlDBKHqWE0kNporRQaoAXxYxiB1IoRZQq SheljdKAeWrA
CHyENfv9vcY9/SF1vjF5YXHqDv4wd++/e/7NBQ6/pQP++f0fKwAB/YtNi3+v AACKTyz8HgCg
HxYeFxng50/h1YXfXB9JXtNQL2lJXnlZOdk99v+btrdn/Vnsis3vvQhifvEv WkgyAGrZsE8d
/BfNawqApm8A4D/9iyYUBbtzAgDdC17RkTF/9KH2bmhAgHdDRsAGuIEAEIWf szxQBhpABxiC
/cAK2AFncAj2H3/YByPBYZAAEkEqSAcXQA64DIpACagAt0AdaAKtoB10g14w AF6BcTAFZsAC
WAY/wCYEQViICJEgNogHEoIkIHlIFdKCDCFzyAZyhjwgPygUioYSoGQoHcqC LkPXoUroDnQP
aoeeQoPQa+g9NA99hzYQSAQ1ghHBhRBGyCBUEboIM4Qdwg3hh4hAxCNSEOcQ eYhixE1EI6Id
0Yt4hZhCLCDWkABJhWRG8iGlkKpIfaQV0gXpi4xEHkOmIXORxcgaZAuyBzmM nEIuIn+hMCgS
ihclBfupCcoe5YWKQB1DZaAuoypQjajHqGHUe9QyagdNRHOiJdDqaFO0E9oP fRidis5Fl6Eb
0F3oV+gZ9A8MBsOMEcGoYEwwzphAzBFMBuYKphbzCDOImcasYbFYNqwEVhNr hSVjKdhUbD72
JrYNO4Sdwf7EUeF4cPI4I5wLLhSXhMvFVeEe4oZws7hNPB1eCK+Ot8J74+Pw 5/Gl+Bb8C/wM
fpNATxAhaBLsCIGEREIeoYbQRZggrFBRUfFTqVEdoAqgOkGVR3Wb6gnVe6pf 1AzU4tT61K7U
0dTnqMupH1G/pl4hEonCRB2iC5FCPEesJHYS3xJ/0pBopGlMabxpjtMU0DTS DNEs0eJphWh1
aQ/RxtPm0t6lfUG7SIenE6bTpyPTHaMroLtHN0q3Rk+il6O3og+hz6Cvon9K P8eAZRBmMGTw
ZkhhKGHoZJgmIUkCJH2SFymZVErqIs0wYhhFGE0ZAxnTGW8x9jMuMzEwKTI5 MMUyFTA9YJpi
RjILM5syBzOfZ65jHmHeYOFi0WXxYTnDUsMyxLLOysGqw+rDmsZay/qKdYON l82QLYgtk62J
bZIdxS7OfoD9MPtV9i72RQ5GDg0OL440jjqON5wITnFOG84jnCWcfZxrXNxc xlzhXPlcnVyL
3MzcOtyB3NncD7nneUg8WjwBPNk8bTyfeZl4dXmDefN4H/Mu83HymfBF813n 6+fb5Bfht+dP
4q/lnxQgCKgK+ApkC3QILAvyCFoIJghWC74RwgupCvkLXRLqEVoXFhF2FD4l 3CQ8J8IqYioS
L1ItMiFKFNUWjRAtFn0phhFTFQsSuyI2II4QVxL3Fy8QfyGBkFCWCJC4IjEo iZZUkwyVLJYc
laKW0pWKkaqWei/NLG0unSTdJL0kIyjjIpMp0yOzI6skGyxbKjsuxyC3Xy5J rkXuu7y4vJd8
gfxLBaKCkcJxhWaFb4oSij6KVxXHlEhKFkqnlDqUtpVVlCOVa5TnVQRVPFQK VUZVGVWtVTNU
n6ih1fTUjqu1qv1SV1anqNepf9WQ0gjSqNKY2yeyz2df6b5pTX5NsuZ1zSkt Xi0PrWtaU9p8
2mTtYu0POgI63jplOrO6YrqBujd1l/Rk9SL1GvTW9dX1j+o/MkAaGBukGfQb MhjaG142fGvE
b+RnVG20bKxkfMT4kQnaxMwk02TUlMvUy7TSdHm/yv6j+x+bUZvZml02+2Au bh5p3mKBsNhv
cdFiwlLIMtSyyQpYmVpdtJq0FrGOsL5/AHPA+kDBgU82cjYJNj22JFt32yrb H3Z6duftxu1F
7aPtOxxoHVwdKh3WHQ0csxynnGScjjr1OrM7Bzg3u2BdHFzKXNYOGh7MOTjj quSa6jriJuIW
6/b0EPuh4EMP3Gndye53PdAejh5VHltkK3Ixec3T1LPQc9lL3+uS14K3jne2 97yPpk+Wz6yv
pm+W75yfpt9Fv3l/bf9c/8UA/YDLAd8CTQKLAteDrILKg3aDHYNrQ3AhHiH3 QhlCg0Ifh3GH
xYYNhkuEp4ZPRahH5EQsR5pFlkVBUW5RzRRGODjsixaNPhn9PkYrpiDm52GH w3dj6WNDY/vi
xOPOxM3GG8XfOII64nWkI4EvITHh/VHdo9ePQcc8j3UcFziecnzmhPGJikRC YlDi8yTZpKyk
1WTH5JYUrpQTKdMnjU9Wp9KkRqaOntI4VXQadTrgdP8ZhTP5Z3bSvNOepcum 56ZvZXhlPDsr
dzbv7O4533P955XPX72AuRB6YSRTO7Miiz4rPmv6osXFxmze7LTs1Rz3nKe5 irlFlwiXoi9N
5ZnnNecL5l/I37rsf/lVgV5BbSFn4ZnC9SveV4au6lytKeIqSi/auBZwbey6 8fXGYuHi3BJM
SUzJp1KH0p4bqjcqy9jL0su2y0PLpypsKh5XqlRWVnFWna9GVEdXz990vTlw y+BWc41UzfVa
5tr02+B29O3PdzzujNSZ1XXcVb1bUy9UX9hAakhrhBrjGpeb/Jummp2bB+/t v9fRotHScF/6
fnkrX2vBA6YH5x8SHqY83G2Lb1t7FP5osd2vfbrDvWO806nz5eMDj/u7zLqe dBt1d/bo9rQ9
0XzS+lT96b1nqs+aepV7G/uU+hqeKz1v6Ffub3yh8qJ5QG2gZXDf4MMh7aH2 YYPh7pemL3tf
Wb4aHLEfGRt1HZ0a8x6bex38+tubmDeb4ycm0BNpk3STuW853xa/E3tXO6U8 9eC9wfu+D7Yf
xqe9phc+Rn3cmkn5RPyUO8szWzknP9c6bzQ/8Png55mF8IXNxdQv9F8Kl0SX 6r/qfO1bdlqe
+Rb5bfd7xgrbSvmq4mrHmvXa2x8hPzbX036y/az4pfqrZ8NxY3bz8BZ2K29b bLtlx2xnYjdk
dzecHEn+HQsg4R7h6wvA93I4h3CGc4cBAAiP/uQUvyXgdAWCZWCMgWNwAzgK GIa4ITeoEgEQ
Toj7SBHkZRQLqhAtie7BhGJ5sMO4HLwHQZoKRfWW+hsNkVaB7iB9EsMd0iwT J7MzyyXWCXYh
jnDOh9y0PH68D/nZBCIFW4U2RJRFw8XKxd9IYqWkpC1lfGVj5RLlTyokKR5V oij7qRxQFVdD
qb1Vv6eRuy9a015LRZtDB6GzqDuq16XfYFBuWGiUZZxmkmR6ZD/FLNQ8wMLH 0tvK29r7gL9N
qC3F7qh9qsM5x0tORc7lLrUHG11b3ToOdbv3erwgD3uOeo17f/BZ8t3xJwVI BpoE+QafDrkZ
OhC2GsESqRrlTImNzogpOHwz9mHcUPx8AuIo9zHN4+4nkhOrkoaTd05yp8qd 0j/teCYk7VR6
aUbP2a/nuS7YZGZk9WbT5tjn5l+ayOe87FJwqXDgKq5I51rs9driuVL+G65l keUnKi5UFlc1
Vw/dXK4h1WrcDrhTUPeiHteg0ujQRGm+cK+6peP+q9aZB98ebrTttiM7UJ2Y x/guQje2e7tn
8cnA0/Jnkb1yvbN9mc9Vnk/1V7+IHtAexA0ODRUMe7+UfvnrVddI1ih5TPU1 ++vtN+/HH0/c
mEx96/NOd4pzavX9sw9F0zEfrWekYC/7Nvtm7ul86+f6hTuLt7/cXar5WrF8 61vn9+VV1bXC
de6fDzaitrR22HZ3Yfuj4VhxH4gAzRABMoBOQ6MICUQyYgaOrTrguL8NbY6e wZzBKmM/4a7g
XQl8hEWqBdgDAC2RTpBelcGGRGHMYWphnmFlYNNlP8xxi3OOW4jHi/c63wD/ D0F2IQ3hgyJR
omfE8sWLJUokr0pdlE6SCZa1kVOUJ8nPKtyFPcFYmU75tUqxarCasjpQf6qR tc9VU1jzq1aL
9mkdN11VPUa9r/q9sDekGHka65hwmWyZju9vMcs3j7VwsdS2ErYmWq8deGfz zLbJrsQ+0yHR
MdKJ7GzrYnBQyVXIjfkQ/tC2+4rHAvmj55TXpPe4z7jvhN+k/7uAd4GTQePB b0LehI6HTcI7
9UzkQtQKZSsGc5ghliOOL17kiHSC8lHtY6bH7U94JVKSUpMLUupO9qbOn6Y5 o5DmnH40o/hs
97nPF+gylbPcLqZm1+aM5n7NA/kMl4ULNAsdr1Cu5hY9uDZbzFRiXJoA739P ymcrMVXC1YY3
vW8l15TWdt+eryPela+3aQhoPNqU2Vx6r7Gl5/5Y69yDX22ER5zt0h0KnUKP SV2ga7F7tKf9
SfXT7GcJvT59ls9V+0Vf8A1wDrINsQ2zv+R+JTAiOiozpvRa/Y3OuNGE5aTL 26B3yVPFsD9s
f1SbOfqpZ451Puhz+6LIl+tf5ZY/fL+7Wv6j9efSpsp29m/7o+BsQRa4gItg AuKCHKB86CNC
EZGGmEdaIltQsqgatBK6A+OEWcVm4zRwc/gbhFgqD2pzoiqNEC0LHZEeywCR kIxoJgwzLQsH
qzCbErshhwNnAFcwtyePE68Z3z5+UQFaOKLqFbomHCqiKvJLtEEsVFxIfFTi uCSv5CMpsjQk
XSpjIrMomyWnJvdePl1BReGD4nklLaUF5UsqeipfVPPVDNWW1Qs0jDVW9hVp mmv+1CrVttHe
1WnUjdST11vRrzeINlQ2XDdqMo4z0TDZNH2w/5iZjjkw77BIsTSxIlq9tC48 4GejYIuwHYR9
JNrB1JHLccmpzfmCixfsJTjXCbc7h067u3uokknkr559Xje9L/hE+zr7afrz BaAD5gOfB90J
zgmJC3UL0wuXiGCLxEauRX2gvIhuiSk5nB4bEWcfr3qELQFK2DgGHcefYEhk TxJIlkhROKme
qnPK6LTZGes0t/TIjNNni87dPd99YTRzJuvrxfXsrZyd3J08Qr7sZeeClMKa K6NF4JrIdYvi
yJLc0uYbr8t2K+QqvasuVffdAjWKtQG3r94Zvout39cQ0XijafQevkX9flDr 5QdPHq4+4mk3
6YjozHvc1vWhB/1E7KnVs7jeir7JfvYXhwYqBzeHbV52jriPsb7emBB/2/Z+ cIYy37R0cWX1
15M9+/+pLe2dCRhlAEqKAXCEayM2FgCUSgIgJA+fH20AWBMBsFMDCLZ8AHWc B5BxzT/nBw0Q
hzPLYHAezhpfgQ34FDGAgqCL0F3oFbSOYEdoI7xhb7qNGINzNzGkLfIosgL5 EgVQ0ihXVBqq
BfUZzYG2QCeiW9CrGFlMCOYm5gtWFhuDbcMRcM64ajwC74q/T+AiJMM7z0Gq UWp76hGiE3GC
xpNmnjaCdoMuhZ6WvoBBlKGRZEh6xejPuMWUxSzO/JjFnWWTNY9NhW2EPYaD laOF8xAXmusW
txMPmqee15ePnW+QP13AWBAt2C10RthKhFlkXLRIzFNcUPyTRIVkoJSk1JJ0 ncxhWW05vNyI
/A2Fw4q2SsrKbMo7KtNwVH1LPUvjMLxP6WgJaeO1v+q81G3Rq4f9sMGwyeie 8T2Te6aN+++Y
VZkXWVy0TLGiWHsdsLbRsZW3E7bndmB1ZHZidmZ34T0o6qrgpn3Iwv2gRyA5 3vOs14APydfB
L8//dSBLkG1wRkhn6I9wkQiHyJNRdZS3MaKHo2O74zmOUBKGj6keL01kScpM YTiZf0rodGOa
QfrYWQp8So1mVWUX5d7PpynIuap2zbM4s7S7bLdSq/r4rfbbqDrj+jONRc0N Lc9bP7cR21U6
g7oqe74/M+y71r8yqD+c/qp3DPFGeuLA2+CpxA9ZH6996p778vnH4vulW8tu 31ZXKKvvfmis
Z/x8uUG/abp1dLtqZ+T3/kEHZIAtiIVrB11gAa4K7IN8oUyoHs7zdxBCCHNE NKII8RSxCufs
lsgEZDVyHEUFnythqGLUCJoKrYuOQzei1zDKmDjMAywazqMLsYs4Xdxl3Dre Gf+IIEEooKKl
OkvNSH2VKEFspbGmmaVNpOOha6f3YSAyNJHcGCHGciZrpi3mKhYXViJrJ9sR diX2FY67nBQu
Ja517vs8ibwmfHR84/zlAhRBfSEmoTnhhyK5olFi1uLSEkSJL5L9UrXSmTIU WWc5LXkhBRqF
X4qfld4qD6s8VW1Xa1Fv0Li976ZmpVa5dplOmW65Xq3+fYMnhqNGs8Y/TQn7 Oc1kzHUtbC19
rWKt0w9csamwrbfrtB92+OS44UzvInZQ39XNLe5QLpxvDJG/efF6e/hc853y 5w1wDywMGguh
DzUJOxZ+J2I6ioliGJ0Y8zyWPS4wvjWB7qjvsYcnWBIjkvpSRE4mp06d1jxT lc6fUXiO/XxB
Jk9WWbZszoNL5nmTl8MKkVfyijyuq5Uwl/4qm6p4XtV2s76m5nZVXUV9WWNG c3iLTavCQ4a2
5fb+zltdZ3vCntr3aj0Xe8E4sDX07mXLSMaY3RuG8a7J8HekqdsfTKcnZkJm 0XMXPzMvZCyu
Ldl8vbI8/p12RWXVZi3gR9R6/M/4X9EbIZseWzbb2juSu0y/7c8I1OD63lnQ DD5C9JAOFA5d
hXqgb3Bdxwyu41QhxpE0SF1kDPIW8iOKE+WAykQ9h+1uis5Aj2D4MRGYTriC EoUdwqngSvDM
+EwCE6GISo5qjDqFqEScoymidaJjpBuiz2ZwIvGRvjP2MF1nPs7ixbqfTZld mIODk8S5zfWJ
e5Cnnbeer5q/TKBUsFzolnCTSLfomNiC+K4ko5SYtLaMvWyw3En5IoX7ilPK OBV5VXe1c+oP
NZY1BbQctTN0OnR/6osbHDLMNRowIZpa7s8ye20hYBlm1XaA3sbNtsxuxcHA Mc/pm4v1wXo3
nkPnPdDkRM8lb1WfZN8Bf56AiMCuYI6Q6NChcPmInMgtik9052H22Ki4/iNS CReO/jzue+JN
kl3yyMlDqQunj5+ZSdfLuH4OOu994WmW7MWCHHxu/KWv+X6Xpws9r0wX2Vx7 VCxbcv0GqexU
+XYlperLTb9b07Xk2+/rPO/ONAQ3rjcnt9DfL3mg8rD/UUAHrrO660D35pOK Z059hOddLxIH
tYe2XjaNhI7xv34xHjPJ/PbOlNH70Wnvj0uf7GdL5xY+8y+YLwZ8CVzy/mqw zLP84duN79bf
f61cWZVdfbxmvzb2w+XH5LrDet9PvZ9Nv4R+Zf7a3vDfGNhU2szf3N7y3Grf 5tk+tj25o7GT
s7O8u3+3dM/+Ub4K8BkBN4haDw4m3+7urggDgM0CYDtzd3ezeHd3uwRONuBv II+C/3yv2BPG
wDX3wtI91K2fcmLv/u/tvwACDIc+oCn6YQAAAAlwSFlzAAALEwAACxMBAJqc GAAAC3JJREFU
eAHtnU2IZEkRgF8Nc1h/TjqyLF48ehEvs+CI+IOgXjwpIoouiKLedNs/VsEV dBH/j7soXkQZ
RE8e/DusP7PsgnMRL3sRx4PiOO2IYvfudFdPGdXRHRuT+TLrvXqV76fqa4aa yIjIiMjvZUUn
r6qrZvs3n634gQAEIACBwgQuPfRAdXCrunGtOtxf7O9ptguFkxIeAhCAAASS BGjBSTQYIAAB
CJQmQAsuTZj4EIAABJIEaMFJNBggAAEIlCZACy5NmPgQgAAEkgRowUk0GCAA AQiUJkALLk2Y
+BCAAASSBGjBSTQYIAABCJQmQAsuTZj4EIAABJIEaMFJNBggAAEIFCUwm81o wUUJExwCEIDA
vQRm9wxpwffgYAABCECgNwKLxYIW3BttEkEAAhAICdCCQyKMIQABCPRDgHvB /XAmCwQgAIF6
ApyC67mghQAEIFCaAPeCSxMmPgQgAIEcAU7BOTrYIAABCBQlQAsuipfgEIAA BHIEaME5Otgg
AAEIFCVACy6Kl+AQgAAEcgQu/ubJ3+bsWdub3/Imb+8SysdBhgAEIDB1AkF7 TC3n4p8OXpWy
5fWveckN7yD9t2FKP6ut3E8WrYpcba9O7A/DmElbDQzbEhuJf8MLd/HRD71t jYof/f6v/KyG
yfwUZAhAAAJbTECOpE0aI/eCt3gPsDQIQGDsBGjBY79C1AeBHSFw6f5Xyz9d rJe3e/kXt3t5
rA4CEJgKgf2bz2rnFcHLJer/ymPfyIT9/COfqrWuN6s2lCn7aMF7T//A8n3z ygdMLiGQqztV
GMIwRaD03vCd18uperrov/Wd79ZOf/gTH6nVq3K9WZmAfbRgSf+lB2/J4xf/ 8IpMKZsykas7
SRjCMEWg6N7QGxHSfCW7l1PF9K/PN+g16umjBZ/M7x7NF9Wsuju/u0aJraaQ qxWuWmcY1mJp
pYRhK1zq7Huul9cI1WTKes10kqfg+fFciRyfCylAAfdgmJrl9eQKoAVDzyol wzCAFgxT3Lwe
hgG0YOhZmayHXx16WTQy3WuCoUVoLqTu9jaPsCnPUqfgj//yCfkozFk1W1TV F17/38OjZcGf
u3z7Y794wkp//B0fNbmLQK4u9HQuDGGYItDn3qitQdu3mYKh6ScqlGrBx88f f/oN/1tCWcwO
jpZ3IUSYVYuHH/y3NGX5+dq1l57+Hz7I7zr9FWePoUc0JleABIYGhL1hKFQY +d4IqvU1m0mX
YMOpC6Va8NGd+T/+c7ykY4fh2fJELF1YkR3fObVugh+5ulOEIQxTBPrcG6ka tlhfrAU/f/T4
tftO70NU7798uDwEn1L84fUXLyU5EFdnN4hjuPaLOjbVao7IFXGBoSJhb0Rb oxrz3oir3TbN
6f0Av6hSLfjqBz9jad79vcfec/k56bs/vn7fTz78gt4cOgrk6ghQpsMQhikC fe6NVA3j0a/3
PopM/aVasE85vzN/7liOvneP7yRPvt5fZPlFHWgaDslloGBoKFRgbxiQSewN q1Zff9MXh0QZ
DM2tB6HE+yh6acHzE6VzcnwmlIM1J1dnuDDsjLCCYXeGFiH4hREMzW2iQh8t +GR+cvV3wkfu
gqxowTHcWJMHTa6YWKyBYZ5ATCzW5COwD2NisSbPcEesfbTgn+99uTea5OqO GoYwTBHoc2+k
atgyfR8teMuQsRwIQAACHQn87Lq8Q2H5QwtWDjxCAAIQ6I/AOy+/SJPRgvuD TiYIQAACSuDv
t89eGKMFsyUgAAEI9E3gwvLP05Y/tGDlwCMEIACB/gicd2D5C+LF2Yc2tEou 36AsX2Jv31rf
5ItCW8XHGQIQgMDUCQSN8dJDD1SHt6q/PCWP//zzJ3V1nIKnfpWpHwIQmA6B 5Sf4Lqt9+yPP
aNEba8E//eMrJeK7Xvs3jcsjBCAAgZ0loP3w5avW/+uvvo4vsV8FCTsEIACB MgQuzCpacBm0
RIUABCCwisBbP/sMLXgVJOwQgAAEyhB48utXaMFl0BIVAhCAwCoC3IhYRQg7 BCAAgWIE5N3B
nIKL0SUwBCAAgSyBN+49vbE3pWUTtTbqB+MP+AGj9hH9rUvflgmFCBQKa9Tb xm/rb4kQINCF
wFPfvqLT+27BsuN93W2brE5vPquhf5OqxCeTN2/1S95uuZZDrbIfDpLaJ0pd we4V+kRBlsAU
DLW87gX4ZSKPn8Ds/C+Ue23BuvmCDdoKVpe5mUQaNv80yKfOWzOpMZUm0OTS NPFZWacF8RvJ
yxah1tOsCLtAQF6I059eW3AtWd+XvSzOOhRBt2xqaA5+SqyUIEF88cn8xOlq y9AI4pyxik8Q
zfJ6vcoap3aKd44dAqt3EDlfnnduVYB39ilML5EtuHcQpfnElZ9OemGiOcee scbmpoR4imik
GNNbOhFMmSo+lUXn2hozbph2kMD5IXiIT0oL9nSGvm16fYb4J4kGCRy80odd 72lgszS7BvSy
T7HSWhtNZ9kqvOATqew1MjEYiiZI4R1EDqZ4qy/Du+UDmlWn22Ot3itN1hp8 JV72lWhwb105
1+oRT5U1rw9iPiZkahMfP9fLNh0BAqsILKrTT0YbpgXL/rbngxTafRP7aKtW vrTbE6yJc8on
X3bK2rZUyR5PCYLHw1TNpo9jNjGZTyEhU1X3jB0venPItoqVGZt7dl8+EcZJ YLAbEbY7bRd2
AWTRugRpNVczavFx9pRV/M25+cJtilYYBA+GDVMEMW3tDaeb/2aFVFWbzbJG tACyRMiU6p3z
uTJB8hOxbg0BOwXv1vuCpdE074CZi51/CuWtmbApk685CB4MUxFivY8ZW4fS jLOqWsipUsXZ
TF7OI61NkZ+CddIE5NU4/dfry3G2NZWdbjvdpoFJHUwZb9B4lmgCZaCRYfdr lilJgqesWlir
7H6KVh4ED4beXxPlNRrTSoqd4+V4H53uNUFSdcgoa1P7WeLg44scDGMHi+kF A6X+cZBaZ3ET
vc3VYX6uxVG3eIoWYG5ekETq75XIu0BgY9+a8a+XvU94lf68YH1KsFnbbk2e 4U2IQakJJXya
EDj7vODbP7KvFpJZy2/NOLhV3bhWHe4v9vc0Tq+n4CalZ3zovxk4tSYlJiZ+ adXyQQmBwQlM
qQXTR9puF4i1IgauVrhw3giB3Xo5biPICAIBCEBgUwRowZsiSRwIQAACrQnQ glsjYwIEIACB
TRGgBW+KJHEgAAEINCBw/gE96koLboAMFwhAAAJlCNCCy3AlKgQgAIEGBGjB DSClXS7dfzVt
3JilnywbK5dAEIBAYwK9vi/Y/lJAyxvz2zCl6+3ffG9jjPWOQetcI+BGyqgv Di0EIDACAr22
YF3vmDuvXZE12qXNVSHunrEmmBIPu5cRx0QDAQiMh8AALdgv3v7mWARtzf6k HGtkrijNxzuo
7IM3l/1xVbuetUszmV7DBs0xdov9RaNhvbPKFs2bJJH61y6k1tP8zSpzLXht HJQQgMBQBOQb
5AZowUEDlcWbRgVrrDK0xhorxeodOkK0PmVd7LSwe25HpEwr9b4hap2aziaa UFtGvDTz90Wa
0gS1xtPRQAACYyCwWCwGaMHWVQ1BrDFTE6Hj9CYpVvpI11vp08ShSxxr300S 4QMBCAxOYJhT
8ODLLlHARtofp9cSl4aYEBgnAem/cgrehjel6R2JkVD2x1jpyzJUjQodO7UP PpL1UgYEINCF
wAA3IjLlyi0F308Hv8OgPVQLFjkY2kJivWp0irmtFHycvLP3FDlw9tbAxBAC EBgJATkCy0F4
Yt+aMRJ2Dcvwh9a4UTYM0tFNahgqdcfKmQ6B6RJIf2vGfvXX31cH0/zWjHLX w/fKQll6SJGq
nC6cIoMeAoMTGNeNiKFwcE4cijx5IbDjBLbh5bgdv4QsHwIQmC4BWvB0rx2V QwACkydAC578
JWQBEIDAdAn8H90Rwz0lqGdOAAAAAElFTkSuQmCC
--------------060503060409060405000101--
Re: View stack not correctly painted for a newly opened perspective [message #641261 is a reply to message #639858] |
Wed, 24 November 2010 10:57  |
Strange, apparently nobody is having this problem. I have added a
bugzilla: https://bugs.eclipse.org/bugs/show_bug.cgi?id=331025
Peter
Am 18.11.10 08:41, schrieb Peter Kullmann:
> Best regards,
> Peter
FUDForum. Page generated in 0.13923 seconds
