Home » Modeling » Papyrus » Bug in drop comment?
Bug in drop comment? [message #640951] Tue, 23 November 2010 11:21 Go to next message
I'm using this code to visualize a Comment created from code:
public static void dropObjectAt(EObject obj, EditPart epart, int x, int y){
		DropObjectsRequest dropObjectsRequest = new DropObjectsRequest();
		ArrayList<Object> objectList = new ArrayList<Object>();
		objectList.add(obj);
		dropObjectsRequest.setObjects(objectList);
		dropObjectsRequest.setLocation(new Point(x, y));
		org.eclipse.gef.commands.Command cmd = epart.getCommand(dropObjectsRequest);
		PapyrusMultiDiagramEditor editor = (PapyrusMultiDiagramEditor) PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage().getActiveEditor();
		editor.getDiagramEditPart().getDiagramEditDomain().getDiagramCommandStack().execute(cmd);
The problem is that this Comment has one annotated element, and if I drop it manually the link is created, but if I use the dropObjectAt method it doesn't.
Debugging it turns out that the drop is processed in OldCommonDiagramDragAndDropEditPolicy.getDropConstraintComma nd:
the creation of the node Comment works, but the CommonDeferredCreateConnectionViewCommand doesn't find the edit part of the Comment.
So my question: should the parent of the Comment do a refresh to create an edit part for the Comment?
Why does it work when I drop the Comment manually?
If this is a bug I think it's related to another problem I'm having: in another post I asked how to modify the appearance of the Comment, Remi told me where to look, I found the code and tried to execute it in my code, but nothing happens.
I use the exact code that AppearanceForAppliedStereotypeComposite uses:
domain = EditorUtils.getTransactionalEditingDomain();
//appearance for the stereotype
domain.getCommandStack().execute(
		AppliedStereotypeHelper.getAddAppliedStereotypeCommand(domain, comment, stereoQualifiedName, presentationKind));
//appearance for the property
			AppliedStereotypeHelper.getAddAppliedStereotypePropertiesCommand(domain, comment, stereoQualifiedName+ "." + property.getName()));
The Comment remains unchanged and in this way the icons of the properties tree that appears in the appearance tab are not modified.
Is it possible to access directly to the instance of AppearanceForAppliedStereotypeComposite and simulate an user interaction (even if some methods are protected)?
Thanks in advance and sorry for the long post, 123star
Re: Bug in drop comment? [message #641182 is a reply to message #640951] Wed, 24 November 2010 08:44 Go to previous messageGo to next message
The appearance of the comment not showing was not a related bug, but an error in my code Smile
Remains the problem of the drop of the link
Re: Bug in drop comment? [message #641540 is a reply to message #641182] Thu, 25 November 2010 18:53 Go to previous messageGo to next message
I will transfer this message to the person which used to develop this part of Papyrus. Hope you will have an answer soon Wink
Rémi
Re: Bug in drop comment? [message #641654 is a reply to message #641540] Fri, 26 November 2010 09:31 Go to previous messageGo to next message
Hi 123Star,
First, I have dropped the comment into the diagram and the link has not be drawn. I have done that for the class diagram. And you which type is it your diagram?
For the class diagram this a bug, when I drop a comment I have also to display the link that is the annotated element.
Patrick
Re: Bug in drop comment? [message #641728 is a reply to message #641654] Sat, 27 November 2010 04:41 Go to previous messageGo to next message
Hi Patrick,
I drop the comment in a composite structure diagram with the above method dropObjectAt and the link is not created.
If I drop the same comment manually, then the link is created, so I think another way is used (which one? why they differ?)
So you're saying that the automatic drop of the link ( for the drop of a comment ) is not processed yet for the composite structure diagram?
Debugging I found out that a Command is created in OldCommonDiagramDragDropEditPolicy.getDropCommentCommand: there the link is not created because there is no edit part for the comment, so I thought that a refresh should be done on the containter of the comment for creating its edit part before the command for creating the link.
Thanks four your reply
Re: Bug in drop comment? [message #642285 is a reply to message #640951] Tue, 30 November 2010 11:57 Go to previous message
I think that the refresh of the container can't be done because the command that creates the comment is not processed yet.
I'm out of options.... here's the situation:
I use the method dropObjectAt(described above) to drop in a composite structure diagram a comment that has an annotated element( a port )
The comment is created but the link is not showing
If I drop the same comment manually the link is created
Why the manual drop works? What kind of command does it use?
Thanks in advance
Previous Topic:Block Interfaces with lollipop
Next Topic:Import model libraries and external profiles?
Current Time: Sat Jul 26 10:47:43 EDT 2025
Powered by FUDForum. Page generated in 0.15175 seconds
