Home » Eclipse Projects » Buckminster dev » [buckminster-dev] Passing javac parameter
[buckminster-dev] Passing javac parameter [message #639128] |
Mon, 15 November 2010 06:33  |
Dear List,
I need to pass a parameter to javac during the build of the workspace, as I need the encoding to be in UTF-8!
How can I achieve this, I did not find a respective parameter?
It should be just like
javac -encoding=UTF-8 or the setting in the Eclipse workspace Preferences/General/Workspace
thx,
Marco
Hope, the list is right for this?!?
Re: [buckminster-dev] Passing javac parameter [message #639189 is a reply to message #639128] |
Mon, 15 November 2010 09:51   |
Hi Marco,
Just set that preference in an empty workspace, then zip it and use it as your template workspace for your build. That's
the way you'd set most of the preferences. Not just encoding, but also all warnings/errors, jdk compliance, etc.
HTH,
Thomas Hallgren
On 11/15/2010 12:33 PM, Marco Descher wrote:
> Dear List,
> thx,
> Marco
Re: [buckminster-dev] Passing javac parameter [message #640851 is a reply to message #639189] |
Tue, 23 November 2010 05:51   |
Hey Thomas and List,
thanks for your help, there are however the following problems:
According to the bucky book, the respective option should be -t, this however results in
INFO: import '-t' '/home/marco/templateWorkspace.zip' '/var/lib/hudson/jobs/Elexis_Trunk_Core_Build/workspace/site .core.elexis/org.eclipse.platform.mspec'
org.eclipse.buckminster.cmdline.parser.InvalidOptionExceptio n: The option '-t' is invalid
A successive use of --template results in
INFO: import '--template' '/home/marco/templateWorkspace.zip' '/var/lib/hudson/jobs/Elexis_Trunk_Core_Build/workspace/site .core.elexis/org.eclipse.platform.mspec'
Workspace at /var/lib/hudson/jobs/Elexis_Trunk_Core_Build/workspace is not empty
I think I've seen this one before, but don't have a clue!
Marco
Am 15.11.2010 um 15:51 schrieb Thomas Hallgren:
> Hi Marco,
> Just set that preference in an empty workspace, then zip it and use it as your template workspace for your build. That's the way you'd set most of the preferences. Not just encoding, but also all warnings/errors, jdk compliance, etc.
> HTH,
> Thomas Hallgren
>> Dear List,
>> thx,
>> Marco
> _______________________________________________
> buckminster-dev mailing list
> buckminster-dev@eclipse.org
> https://dev.eclipse.org/mailman/listinfo/buckminster-dev
Re: [buckminster-dev] Passing javac parameter [message #641103 is a reply to message #640893] |
Wed, 24 November 2010 04:24   |
Hey,
I do execute the following subsequent steps within Hudson:
+ rm -Rf .metadata/
[After checking in the Repo, which is necessary, I do entirely remove the .metadata]
+ [workspace] $ java -Dbuckminster.output.root=/var/lib/hudson/jobs/Elexis_2.1_Co re_Build/workspace/buckminster.output -Dbuckminster.temp.root=/var/lib/hudson/jobs/Elexis_2.1_Core _Build/workspace/buckminster.temp -DtargetPlatformPath=/var/lib/hudson/jobs/Elexis_2.1_Core_Bu ild/workspace/targetPlatform -jar /usr/local/bin/buckminster-headless/plugins/org.eclipse.equi nox.launcher_1..1.0.v20100507.jar -application org.eclipse.buckminster.cmdline.headless -data /var/lib/hudson/jobs/Elexis_2.1_Core_Build/workspace --loglevel info -S /var/lib/hudson/jobs/Elexis_2.1_Core_Build/workspace/command s.txt
I
NFO: import '--template' '/home/marco/templateWorkspace.zip' '/var/lib/hudson/jobs/Elexis_2.1_Core_Build/workspace/site.c ore.elexis/site.cquery'
Workspace at /var/lib/hudson/jobs/Elexis_2.1_Core_Build/workspace is not empty
So there definitely is no .metadata within the workspace. The only things located in there is the cloned mercurial repository!
Is there a way to have more output on what files the templateworkspace actually bangs on? Or is there a way to force the template into existence?
thx,
marco
Am 23.11.2010 um 14:09 schrieb Thomas Hallgren:
> I think you can use either -T or --template so the documentation is wrong.
> It means that the workspace that you are trying to import to already exists and has some content (a .metadata folder most likely). That's not permitted when you start with a template.
> - thomas
Re: [buckminster-dev] Passing javac parameter [message #641173 is a reply to message #641172] |
Wed, 24 November 2010 08:15  |
The workspace template is just a zip. So an alternative to using the -T or --template option is to simply unzip it
before you do the import.
- thomas
Current Time: Wed Jul 23 18:09:07 EDT 2025
Powered by FUDForum. Page generated in 0.43546 seconds
