Home » Modeling » Epsilon » Problem with HUTN configuration files(Problem with HUTN configuration files)
Problem with HUTN configuration files [message #640779] Tue, 23 November 2010 02:24 Go to next message
Hi again!
I'm having problems with reference elements in hutn configuration files. For instance, this a configuration I'm using:
patterns: ConfiguredPattern "CP1" {
specifics: SpecificInstance "SI1" {
instance: Instance " platform:/resource/es.cv.gvcase.linkers.dd2cld.transf/models /DD2CLD.rulescatalog#//@configurations.0/@pattern/@elements. 0 "
element: DataStructure " /es.cv.gvcase.linkers.dd2cld.test.data/models/TFR-MAP-003-V0 0-001.model#//gbddName/dsName "
pattern: Pattern " platform:/resource/es.cv.gvcase.linkers.dd2cld.transf/models /DD2CLD.rulescatalog#//@configurations.0/@pattern "
firstElement: DataStructure " /es.cv.gvcase.linkers.dd2cld.test.data/models/TFR-MAP-003-V0 0-001.model#//gbddName/dsName "
defaultRule: Rule " platform:/resource/es.cv.gvcase.linkers.dd2cld.transf/models /DD2CLD.rulescatalog#//@configurations.0/@rules.0 "
parameterValue: ParameterValue "PV1" {
parameter: Parameter " platform:/resource/es.cv.gvcase.linkers.dd2cld.transf/models /DD2CLD.rulescatalog#//@configurations.0/@parameter.0 "
rule: Rule " platform:/resource/es.cv.gvcase.linkers.dd2cld.transf/models /DD2CLD.rulescatalog#//@configurations.0/@rules.0 "
The lines "element:" and "firstElement:" are wrong. I'm using epsilon 0.8.9. In the 0.8.8 version this syntax error doesn't occur.
My point is that the elements must be referenced by ID, but not all the elements contains an ID field.
Any idea?
Thanks.
Re: Problem with HUTN configuration files [message #640826 is a reply to message #640779] Tue, 23 November 2010 05:10 Go to previous messageGo to next message
Hi Jes,
I'm a bit confused... This HUTN source code doesn't use a HUTN configuration file. In Epsilon, HUTN configuration files only define three types (Configuration, IdentifierRule and DefaultValueRule), none of which are used in this HUTN source code.
So, it seems that this isn't a problem with HUTN configuration files, but with a cross-model reference. I think the errors might be expected because, in this HUTN source, the two lines that have errors (firstElement and element) seem to be incorrect for two reasons:
1) They should start with "platform:/resource" (like the other cross-references in this HUTN source).
2) They should reference the target model elements using a URI fragment. For example, "//@configurations.0/@rules.0" is a valid URI fragment, which means the "first rule contained in the first configuration of the model".
"//gbddName/dsName" is not a valid URI fragment, and EMF cannot resolve it. Either use a valid URI fragment, or use an XMI ID instead.
The EMF book describes the way in which URI fragments and XMI IDs can be used to refer to model elements. There seems to be an online version of the relevant chapter here: http://learning.infocollections.com/ebook%202/Computer/Progr amming/Java/Eclipse.Modeling.Framework/0131425420_ch13lev1se c2.html
I can't explain why this worked in Epsilon 0.8.8. Without a URI schema (such as "platform:/resource"), the cross-references could not have been resolved. I hope the two proposals above help to fix the problem now though.
Louis.
Re: Problem with HUTN configuration files [message #641062 is a reply to message #640779] Wed, 24 November 2010 02:52 Go to previous messageGo to next message
This is another (full) example that works in Epsilon 0.8.8:
@Spec {
metamodel "Configuration_UML2DB" {
nsUri: "http:///es.cv.gvcase.transformationConfiguration.ecore"
C_UML2DB {
Configuration "Configuration_UML2DB" {
instance: Instance " platform:/resource/es.cv.gvcase.linkers.uml2db.transf/models /UML2DB.rulescatalog#//@configurations.12/@pattern/@elements .0 "
element: Class " /es.cv.gvcase.linkers.uml2db.test.data/models/TFR-MAP-003-V0 3-001.model#//C1 "
pattern: Pattern " platform:/resource/es.cv.gvcase.linkers.uml2db.transf/models /UML2DB.rulescatalog#//@configurations.12/@pattern "
firstElement: Class " /es.cv.gvcase.linkers.uml2db.test.data/models/TFR-MAP-003-V0 3-001.model#//C1 "
defaultRule: Rule " platform:/resource/es.cv.gvcase.linkers.uml2db.transf/models /UML2DB.rulescatalog#//@configurations.12/@rules.0 "
parameter: Parameter " platform:/resource/es.cv.gvcase.linkers.uml2db.transf/models /UML2DB.rulescatalog#//@configurations.12/@parameter.0 "
value: Property " /es.cv.gvcase.linkers.uml2db.test.data/models/TFR-MAP-003-V0 3-001.model#//C1/P1 "
value: Property " /es.cv.gvcase.linkers.uml2db.test.data/models/TFR-MAP-003-V0 3-001.model#//C1/P2 "
rule: Rule " platform:/resource/es.cv.gvcase.linkers.uml2db.transf/models /UML2DB.rulescatalog#//@configurations.12/@rules.0 "
source: Model "UML" {
metamodel: Metamodel " platform:/resource/es.cv.gvcase.linkers.uml2db.transf/models /UML2DB.rulescatalog#//@source.0 "
path: " /es.cv.gvcase.linkers.uml2db.test.data/models/TFR-MAP-003-V0 3-001.model "
modelRef: Model " /es.cv.gvcase.linkers.uml2db.test.data/models/TFR-MAP-003-V0 3-001.model#/ "
catalog: Catalog " platform:/resource/es.cv.gvcase.linkers.uml2db.transf/models /UML2DB.rulescatalog#/ "
TransformationId: "es.cv.gvcase.linkers.uml2db.transf.Transformation"
See the lines "element:" and "firstElement:", there are using references to the elements by name (in this case, C1 is the name of the class in the hutn model).
This same code with the 0.8.9 version of Epsilon shows me errors in that lines. I don't understand it.
Cheers.
Re: Problem with HUTN configuration files [message #641094 is a reply to message #640779] Wed, 24 November 2010 04:16 Go to previous messageGo to next message
Problem solved, my fault. This is the correct syntax:
element: DataStructure " /es.cv.gvcase.linkers.dd2cld.test.data/models/TFR-MAP-003-V0 0-001.model#//@dataStructures.0 "
I had tried with @datastructures.0, but the 's' should be uppercase.
Thanks.
Re: Problem with HUTN configuration files [message #641101 is a reply to message #641094] Wed, 24 November 2010 04:29 Go to previous message
Hi Jes,
Great, glad you fixed the problem.
I'm surprised that the cross reference value works when it doesn't have a schema (such as: platform:/resource), but perhaps this is a difference between operating systems. (I'm using Mac OS).
Louis.
Previous Topic:[EWL] Wizard menu error
Next Topic:custom marker view in an RCP app using evl
Current Time: Tue Jul 22 23:01:44 EDT 2025
Powered by FUDForum. Page generated in 0.26233 seconds
