Home » Eclipse Projects » Virgo » Running Virgo in Eclipse
Running Virgo in Eclipse [message #641017] Tue, 23 November 2010 17:03 Go to next message
I previously was able to get Spring-DM Server to run in eclipse, but seem to no longer be able to do that with the Virgo upgrade.
Eclipse gives me the following error when I attempt to set Virgo up as a Server:
.version file in lib directory is missing key 'dm.server.version'. Make sure to point to a dm Server 2.0 installation.
I am still using the Spring-DM Tools, is there a different plugin that i should be using?
Thanks.
Re: Running Virgo in Eclipse [message #641043 is a reply to message #641017] Tue, 23 November 2010 23:29 Go to previous messageGo to next message
You need to obtain the latest level of the tools as described in the Virgo Programmer Guide. Then create a Virgo server under the EclipseRT section rather than a SpringSource dm Server under the Spring (?) section - see section 7.2 of the Programmer Guide.
Re: Running Virgo in Eclipse [message #641179 is a reply to message #641043] Wed, 24 November 2010 08:37 Go to previous message
Good call. Thanks.
Previous Topic:Classloader Exception during EntityManager setup
Next Topic:Class loader exception during JPA processing
Current Time: Sun Nov 09 03:59:59 EST 2025
Powered by FUDForum. Page generated in 0.03393 seconds
