Home » Eclipse Projects » Virgo » Classloader Exception during EntityManager setup
Classloader Exception during EntityManager setup [message #640900] Tue, 23 November 2010 08:54 Go to next message
I'm running Virgo 2.1.0 with Eclipselink 2.0.2 ontop of the default included spring version 3.0.0.
80% of the time I get an Classloader Exception during startup of my application.
[2010-11-23 14:40:20.662] Thread-3                     <AG0000E> Application context creation failure for bundle 'de.uniulm.iai.slc.plan-2-de.uniulm.iai.slc.core.business' version '2.0.0.RELEASE-SNAPSHOT'. org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'personManager' defined in URL [bundleentry://66.fwk1752858176/META-INF/spring/slc-business-context.xml]: Cannot resolve reference to bean 'slcDao' while setting bean property 'slcDao'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'slcDao' defined in URL [bundleentry://66.fwk1752858176/META-INF/spring/slc-dao-descriptions.xml]: Cannot resolve reference to bean 'secondaryTeachingRoleDao' while setting bean property 'secondaryTeachingRoleDao'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'entityManagerFactory' defined in URL [bundleentry://66.fwk1752858176/META-INF/spring/slc-db-context.xml]: Invocation of init method failed; nested exception is javax.persistence.PersistenceException: Exception [EclipseLink-28018] (Eclipse Persistence Services - 2.0.2.v20100323-r6872): org.eclipse.persistence.exceptions.EntityManagerSetupException
Exception Description: Predeployment of PersistenceUnit [slc] failed.
Internal Exception: org.eclipse.virgo.kernel.osgi.framework.BundleClassLoaderUnavailableException: Failed to get class loader for bundle 'org.eclipse.virgo.region.user_0.0.0 [1]' - possible resolution problem.
        at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:328)
        at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:106)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1325)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1086)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:517)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
        at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:291)
        at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:222)
        at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:288)
        at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:190)
        at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:580)
        at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:895)
        at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.access$1600(AbstractDelegatedExecutionApplicationContext.java:69)
        at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext$4.run(AbstractDelegatedExecutionApplicationContext.java:355)
        at org.springframework.osgi.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85)
        at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.completeRefresh(AbstractDelegatedExecutionApplicationContext.java:320)
        at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$CompleteRefreshTask.run(DependencyWaiterApplicationContextExecutor.java:132)
        at org.eclipse.virgo.kernel.agent.dm.ContextPropagatingTaskExecutor$2.run(ContextPropagatingTaskExecutor.java:95)
        at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
        at java.lang.Thread.run(Thread.java:680)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'slcDao' defined in URL [bundleentry://66.fwk1752858176/META-INF/spring/slc-dao-descriptions.xml]: Cannot resolve reference to bean 'secondaryTeachingRoleDao' while setting bean property 'secondaryTeachingRoleDao'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'entityManagerFactory' defined in URL [bundleentry://66.fwk1752858176/META-INF/spring/slc-db-context.xml]: Invocation of init method failed; nested exception is javax.persistence.PersistenceException: Exception [EclipseLink-28018] (Eclipse Persistence Services - 2.0.2.v20100323-r6872): org.eclipse.persistence.exceptions.EntityManagerSetupException
        at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:322)
        ... 20 common frames omitted
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'entityManagerFactory' defined in URL [bundleentry://66.fwk1752858176/META-INF/spring/slc-db-context.xml]: Invocation of init method failed; nested exception is javax.persistence.PersistenceException: Exception [EclipseLink-28018] (Eclipse Persistence Services - 2.0.2.v20100323-r6872): org.eclipse.persistence.exceptions.EntityManagerSetupException
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1420)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:519)
        at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:281)
        ... 30 common frames omitted
Caused by: javax.persistence.PersistenceException: Exception [EclipseLink-28018] (Eclipse Persistence Services - 2.0.2.v20100323-r6872): org.eclipse.persistence.exceptions.EntityManagerSetupException
        at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.predeploy(EntityManagerSetupImpl.java:991)
        at org.eclipse.persistence.jpa.PersistenceProvider.createContainerEntityManagerFactory(PersistenceProvider.java:202)
        at org.springframework.orm.jpa.LocalContainerEntityManagerFactoryBean.createNativeEntityManagerFactory(LocalContainerEntityManagerFactoryBean.java:225)
        at org.springframework.orm.jpa.AbstractEntityManagerFactoryBean.afterPropertiesSet(AbstractEntityManagerFactoryBean.java:308)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1477)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1417)
        ... 39 common frames omitted
Caused by: org.eclipse.persistence.exceptions.EntityManagerSetupException:
        at org.eclipse.persistence.exceptions.EntityManagerSetupException.predeployFailed(EntityManagerSetupException.java:210)
        ... 45 common frames omitted
Caused by: org.eclipse.virgo.kernel.osgi.framework.BundleClassLoaderUnavailableException: Failed to get class loader for bundle 'org.eclipse.virgo.region.user_0.0.0 [1]' - possible resolution problem.
        at org.eclipse.virgo.kernel.userregion.internal.equinox.EquinoxUtils.getBundleClassLoader(EquinoxUtils.java:69)
        at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.getBundleClassLoader(KernelBundleClassLoader.java:125)
        at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.access$4(KernelBundleClassLoader.java:124)
        at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader$ThrowAwayClassLoader.findClassFromImport(KernelBundleClassLoader.java:415)
        at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader$ThrowAwayClassLoader.findClassInternal(KernelBundleClassLoader.java:392)
        at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader$ThrowAwayClassLoader.loadClass(KernelBundleClassLoader.java:364)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
        at java.lang.Class.forName0(Native Method)
        at java.lang.Class.forName(Class.java:247)
        at org.eclipse.persistence.internal.security.PrivilegedAccessHelper.getClassForName(PrivilegedAccessHelper.java:88)
        at org.eclipse.persistence.internal.jpa.metadata.MetadataHelper.getClassForName(MetadataHelper.java:97)
        at org.eclipse.persistence.internal.jpa.metadata.ORMetadata.getJavaClass(ORMetadata.java:176)
        at org.eclipse.persistence.internal.jpa.metadata.ORMetadata.getJavaClass(ORMetadata.java:151)
        at org.eclipse.persistence.internal.jpa.metadata.converters.EnumeratedMetadata.process(EnumeratedMetadata.java:100)
        at org.eclipse.persistence.internal.jpa.metadata.accessors.mappings.MappingAccessor.processEnumerated(MappingAccessor.java:1340)
        at org.eclipse.persistence.internal.jpa.metadata.accessors.mappings.BasicAccessor.processEnumerated(BasicAccessor.java:340)
        at org.eclipse.persistence.internal.jpa.metadata.accessors.mappings.MappingAccessor.processJPAConverters(MappingAccessor.java:1354)
        at org.eclipse.persistence.internal.jpa.metadata.accessors.mappings.MappingAccessor.processMappingConverter(MappingAccessor.java:1422)
        at org.eclipse.persistence.internal.jpa.metadata.accessors.mappings.MappingAccessor.processMappingValueConverter(MappingAccessor.java:1440)
        at org.eclipse.persistence.internal.jpa.metadata.accessors.mappings.BasicAccessor.process(BasicAccessor.java:300)
        at org.eclipse.persistence.internal.jpa.metadata.MetadataDescriptor.processAccessors(MetadataDescriptor.java:1287)
        at org.eclipse.persistence.internal.jpa.metadata.accessors.classes.ClassAccessor.processAccessors(ClassAccessor.java:825)
        at org.eclipse.persistence.internal.jpa.metadata.accessors.classes.EmbeddableAccessor.process(EmbeddableAccessor.java:257)
        at org.eclipse.persistence.internal.jpa.metadata.MetadataDescriptor.processAccessors(MetadataDescriptor.java:1257)
        at org.eclipse.persistence.internal.jpa.metadata.accessors.classes.EntityAccessor.processAccessors(EntityAccessor.java:847)
        at org.eclipse.persistence.internal.jpa.metadata.accessors.classes.EntityAccessor.process(EntityAccessor.java:708)
        at org.eclipse.persistence.internal.jpa.metadata.MetadataProject.processStage2(MetadataProject.java:1333)
        at org.eclipse.persistence.internal.jpa.metadata.MetadataProcessor.processORMMetadata(MetadataProcessor.java:461)
        at org.eclipse.persistence.internal.jpa.deployment.PersistenceUnitProcessor.processORMetadata(PersistenceUnitProcessor.java:390)
        at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.predeploy(EntityManagerSetupImpl.java:945)
        ... 44 common frames omitted
Caused by: java.lang.ClassCastException: org.eclipse.osgi.internal.composite.CompositeClassLoader cannot be cast to org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader
        at org.eclipse.virgo.kernel.userregion.internal.equinox.EquinoxUtils.getBundleClassLoader(EquinoxUtils.java:67)
        ... 74 common frames omitted
As mentioned this happens not on every startup and I don't see any differences if I deploy my plan right during startup or afterwards. Without my custom application everything works fine, the admin application is starting fine.
I checked via telnet and I do not see a difference in bundle states. Neither for kernel nor for user-space bundles. I also did not spot any exceptions before I deploy my custom application. So, for me everything is working fine as it should since I did not modifiy the default configuration.
Does anyone have an idea whats the problem?
Re: Classloader Exception during EntityManager setup [message #640903 is a reply to message #640900] Tue, 23 November 2010 09:01 Go to previous messageGo to next message
I found a topic from june which might be the same problem:
http://www.eclipse.org/forums/index.php?t=msg&th=170888& amp;start=0&S=13a707f5aeffd3b3653b2b780cb37e82
Apparently, there is no solution to the problem ... Sad
I tried to push spring to 3.0.5 in user region, but it doesn't change anything.
Re: Classloader Exception during EntityManager setup [message #640907 is a reply to message #640903] Tue, 23 November 2010 09:13 Go to previous messageGo to next message
Steffen,
Can you create a bugzilla issue and attach a bundle to reproduce this issue? I would be interested to debug through this.
Dmitry
Re: Classloader Exception during EntityManager setup [message #640912 is a reply to message #640907] Tue, 23 November 2010 09:27 Go to previous messageGo to next message
The root cause looks the same as the one back in June and my advice is the same: try to get to the bottom of why the user region bundle is not resolving. Admittedly this might be a tall order, so reproducing so we can take a look is probably easiest.
Dmitry: thanks for offering to debug this one! I'm really interested in the outcome.
Re: Classloader Exception during EntityManager setup [message #640915 is a reply to message #640912] Tue, 23 November 2010 09:33 Go to previous messageGo to next message
This looks interesting:
Re: Classloader Exception during EntityManager setup [message #640922 is a reply to message #640915] Tue, 23 November 2010 09:57 Go to previous message
Well spotted! CompositeClassLoader does not extend DefaultClassLoader, so this looks like a bug in EquinoxUtils.
We'll look into this under bug 330924. (Thanks for raising the bug Steffen.)
Previous Topic:Spring LDAP and exporting the service
Next Topic:Running Virgo in Eclipse
Current Time: Sat Jul 26 15:19:36 EDT 2025
Powered by FUDForum. Page generated in 0.05180 seconds
