Home » Eclipse Projects » Eclipse Platform » How to write % char within xml that is included for org.eclipse.ui.editors.templates
How to write % char within xml that is included for org.eclipse.ui.editors.templates [message #640849] Tue, 23 November 2010 05:52 Go to next message
I want to write % char within xml file. Whenever xml is parsed by eclipse it tries to search for localized string since % is used in xml to get localized string from .properties file. Is there a way by which you can exclude % from parsing.
This happens specially when you implement extension point org.eclipse.ui.editors.templates and add new include and specify xml file to read the templates.
For example your included xml file can have this.
<templates>
<template name="test" id="xyz"
description="%test.Description" context="java" enabled="true"
> </template>
for(int i;i<10;i++){
${:link('100%')}
When i start eclipse and view these templates it comes as
${:link('100!')}
</templates>
note ! mark. while debugging i found that its trying to find localized string which is empty. so ! is displayed.
Re: How to write % char within xml that is included for org.eclipse.ui.editors.templates [message #640887 is a reply to message #640849] Tue, 23 November 2010 07:53 Go to previous message
> ${:link('100%')}
What if you try %%
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Previous Topic:Replace file icons but retain its error markers
Next Topic:List of all visible ( package explorer) resources in workspace
Current Time: Fri Nov 07 11:27:10 EST 2025
Powered by FUDForum. Page generated in 0.04011 seconds
