Home » Modeling » Epsilon » xsdxml Example(It doesn't work)
xsdxml Example [message #640181] Fri, 19 November 2010 08:34 Go to next message
Hello everyone!
I'm trying the xsdxml example to learn to read xml files.
I've downloaded the example from Epsilon website and from
Epsilon repository but the result is the same:
When I launch the note.launch, I receive this error message:
"Called feature from on undefined object (...\org.eclipse.epsilon.examples.xsdxml\note.eol@3:17)"
I use Eclipse Helios Release and Epsilon 0.8.9 but
I've tried in Eclipse Ganymede and Epsilon 0.8.6 and It doesn't work too.
Please, can someone help me?
Thank you,
Álvaro
Re: xsdxml Example [message #640191 is a reply to message #640181] Fri, 19 November 2010 09:12 Go to previous messageGo to next message
Hi Alvaro,
I'll have a look at this later on today. In the meantime, would the
plain XML driver perhaps be suitable for what you're doing?
http://www.eclipse.org/gmt/epsilon/doc/articles/plain-xml/
Dimitris
ajimenezr wrote:
> Hello everyone!
> I'm trying the xsdxml example to learn to read xml files. I've
> (...\org.eclipse.epsilon.examples.xsdxml\mailto:note.eol@3:17)"
> Thank you,
> Regards,
> Álvaro
Re: xsdxml Example [message #640466 is a reply to message #640191] Mon, 22 November 2010 03:50 Go to previous messageGo to next message
Hello Dimitris,
thanks for your answer, but I need to query XML documents based in a XSD Sad
Have you tried the XSDXML example in Eclipse Helios and Epsilon 0.8.9 ?
or Could you tell me what versions I need?
Thanks for advance. Regards,
Álvaro
Re: xsdxml Example [message #640542 is a reply to message #640466] Mon, 22 November 2010 07:47 Go to previous message
Hi Alvaro,
I've just tried this example under Helios (following the instructions in
readme.txt) using the latest Epsilon interim version and it appears to
be working fine for me. I'll have another go at it under MacOS to see if
I can reproduce this there.
Dimitris
ajimenezr wrote:
> Hello Dimitris,
> thanks for your answer, but I need to query XML documents based in a XSD :(
> Álvaro
Previous Topic:[Eugenia] Formatting custom figures
Next Topic:Any idea how to show a node with two icons?
Current Time: Sat Jul 26 07:55:31 EDT 2025
Powered by FUDForum. Page generated in 0.04709 seconds
