Home » Eclipse Projects » Eclipse Platform » Efficient update of workspace with new config spec
Efficient update of workspace with new config spec [message #640396] Sun, 21 November 2010 12:13 Go to next message
We are using clearcase as SCM.
We use clearcase plug-in and set a new config spec (cs) from within Eclipse ( cleartool setcs <mychanged_cs>).
With my new cs directories and files does not exist in my view anymore.
Will a resource change event be triggered for these resources? ( My guess is no).
If not is there an efficient algorithm to use ( beginning in workspace root) to find out what has changed?
br,
//mike
Re: Efficient update of workspace with new config spec [message #640543 is a reply to message #640396] Mon, 22 November 2010 07:56 Go to previous messageGo to next message
> guess is no).
if the tool doesn't update the resources, then you have to refresh your
workspace. Go to your package explorer/project explorer, deselect
anything, and use F5 Refresh
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Efficient update of workspace with new config spec [message #640633 is a reply to message #640543] Mon, 22 November 2010 11:29 Go to previous message
How can I using the API for plug-ins check which resources I have in the workspace before I "cleartool setcs <my cs file>" and after .
Is there some kind of operation on the project (IProject) that you can recommend?
br,
//mike
Previous Topic:Can I open a SWT.MOZILLA internal browser using IWorkbenchBrowserSupport?
Next Topic:How to get a reference to a Browser
Current Time: Sat Jul 26 15:21:25 EDT 2025
Powered by FUDForum. Page generated in 0.43068 seconds
