Home » Modeling » Modeling (top-level project) » serialize ecore references into container
Re: serialize ecore references into container [message #640140 is a reply to message #640132] |
Fri, 19 November 2010 04:57   |
please see below...
On 2010-11-19 10:25, Florian Marienfeld wrote:
> suppose I have this metamodel:
> class Chair has a reference named "parts" of type "Part". Part is
> superclass to classes Leg and Arm.
> by default a model instance gets serialized to this:
> <chair:Chair xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:chair="chair.de">
> <parts xsi:type="chair:Arm"/>
> <parts xsi:type="chair:Leg"/>
> </chair:Chair>
This XML format is conforming to the XMI standard. In XMI you always have
<$referenceName xsi:type="$type" ($attributes)*>...</$referenceName>
> What I would like is:
> <Chair>
> <Parts>
> <Arm/>
> <Leg/>
> </Parts>
> </Chair>
> What is the way to go?
If you want to change that format without touching the metamodel, I
guess, you would have to write your own Resource/ResourceFactory
implementation and register it before serializing your model rather than
using XMIResources.
But you could also write an XML schema according to your needs and
generate the corresponding ecore model and then use the
GenericXMLResourceFactoryImpl as, I guess, Ed suggested (cf. end of
article [1]).
> Thanks, Ed, for pointing me at your article on substitution groups
> (http://ed-merks.blogspot.com/2007/12/winters-icy-grip.html) .
> However, that does not give me the container tag, in my case <parts>, right?
> Best regards, thanks in advance,
> FLO
HTH,
Philip
[1] http://www.devx.com/Java/Article/29093/1954
Re: serialize ecore references into container [message #640194 is a reply to message #640132] |
Fri, 19 November 2010 09:21  |
Florian,
I've not found the time to complete the work for
https://bugs.eclipse.org/bugs/show_bug.cgi?id=201662
> </chair:Chair>
> <Chair>
> <Parts>
> <Arm/>
> <Leg/>
> </Parts>
> </Chair>
> FLO
Current Time: Wed Jul 23 05:34:33 EDT 2025
Powered by FUDForum. Page generated in 0.27398 seconds
