Home » Archived » BIRT » Newbie - Saving changes to a report(Save,Save As, Save All greyed out. How can you force save)
Newbie - Saving changes to a report [message #640075] Thu, 18 November 2010 18:14 Go to next message
I have created several reports and have noticed when making minor changes such as changing the Margin for the Master Page from 0.25 in to 0.5cm, I am unable to save the change. The save options are all greyed out.
To make save appear I have been making a dummy change to the layout page and even then it still only gives me Save As.
I am starting to work with libraries and am making changes to library settings. Is this an issue?
What am I doing wrong and how can I force save.
Thanks in advance for your help.
Chris
Re: Newbie - Saving changes to a report [message #640209 is a reply to message #640075] Fri, 19 November 2010 10:19 Go to previous messageGo to next message
Chris,
Are the reports read only on the file system?
Jason
On 11/18/2010 6:14 PM, Chris wrote:
> out. To make save appear I have been making a dummy change to the layout
> Chris
Re: Newbie - Saving changes to a report [message #640699 is a reply to message #640209] Mon, 22 November 2010 16:10 Go to previous messageGo to next message
Thanks Jason,
I don't believe so. They are new reports created by me so should not have read only set.
I have been following the reports created in BIRT 2.6 and decided to create my own library to use.
I have created a report with the master page I wanted and then exported it to the library. Then saved the library and the file. I then created a new report and added it to the report along with several other items I wanted in the report from the library.
When making changes to any of these library items in the report in the properties area eg margins, or underline etc, when I go to save the report the save options are greyed out.
I am using 2.52. Is this an issue with it. I can save the report by changing clicking on a field in a table and doing a dummy change on it. Then save as is available.
By the way do you know when BIRT saves a report? It seems to automatically save or is this not true?
Thank you for your time.
chris
Re: Newbie - Saving changes to a report [message #640725 is a reply to message #640699] Mon, 22 November 2010 17:07 Go to previous message
Can you try this with 2.6.1?
You should get an indication when you override a library element as
described here:
http://www.eclipse.org/birt/phoenix/project/notable2.6.php#j ump_11
The report should auto save when previewing it. Other than that it is a
manual operation.
Jason
On 11/22/2010 4:10 PM, Chris wrote:
> Thanks Jason,
> have read only set.
> chris
Previous Topic:Table of contents in a PDF file
Next Topic:Birt in Oracle APEX
Current Time: Wed Jul 23 04:52:55 EDT 2025
Powered by FUDForum. Page generated in 0.57258 seconds
