Home » Eclipse Projects » Rich Client Platform (RCP) » Export wont recognize selected Target(RCP export)
Export wont recognize selected Target [message #639909] Thu, 18 November 2010 06:33 Go to next message
I am working with helios on a win64 Vista machine.
When I export an rcp product for win64, it was giving me a product that seemed to work ok (after I deleted the jre out of it that it seemed to want to bundle with it every time).
When I create a win32 target (rcp-sdk + deltapack), and set that to be the preference, I find the export uses the files from the actual helios installation and not the selected target.
I believe the win64 exported product was doing the same, but I didn't notice at the time because they were both win64.
Is there some trick to getting the tool to recognize the targets?
[Updated on: Thu, 18 November 2010 06:34] by Moderator
Re: Export wont recognize selected Target [message #643049 is a reply to message #639909] Fri, 03 December 2010 13:01 Go to previous messageGo to next message
Hi Shawn,
You select the target platform during export of the product. IIRC If you have
included the org.eclipse.equinox.executable feature, you are able to select
the target executable.
Best Regards,
Wim Jongman
preference, I find the export continues to uses the files from the actual
Re: Export wont recognize selected Target [message #643880 is a reply to message #643049] Wed, 08 December 2010 10:26 Go to previous message
I ended up creating a new target (and installing another JRE to go with it) and got it to export (both are win32).
However, the "eclipse.exe" that gets installed into the exported project is the win64 one from the eclipse development installation (not from the target).
When I manually copy the eclipse.exe from the win32 target that I had created into the exported product it works fine.
The export is grabbing everything else correctly, except for the eclipse.exe.
Previous Topic:Missing "Plugin Development" preference item
Next Topic:Problem with Table(Viewer) in Forms
Current Time: Wed Jul 23 06:05:34 EDT 2025
Powered by FUDForum. Page generated in 0.08778 seconds
