Home » Archived » BIRT » Exception in Birt while loading class in Google Analytics client library(Loading some Google Analytics class when using Scripted data source causing NPE)
Exception in Birt while loading class in Google Analytics client library [message #639706] Wed, 17 November 2010 09:37 Go to next message
Hi all!
I'm trying to make a report in Birt 2.6.2 which will present data fetched from Google Analytics service. From forum messages and documentation, I've concluded that scription data source should be used for this purpose.
I developed a java class which logs in to GA and fetches data. This class has dependancies to GA client libraries. I've put this class and libs into scriptlib folder and I also included GA libs on Report Designer classpath.
Java class is instantiated in "open" method for a data set.
The problem occures when class instatiates one of the Google's classes from GA client lib when report is run in Report Designer.
This is the stacktrace of the exception:
org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
   at org.eclipse.birt.report.service.ReportEngineService.throwDummyException(ReportEngineService.java:1097)
   at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:926)
   at org.eclipse.birt.report.service.BirtViewerReportService.runAndRenderReport(BirtViewerReportService.java:973)
   at org.eclipse.birt.report.service.actionhandler.BirtGetPageAllActionHandler.__execute(BirtGetPageAllActionHandler.java:131)
   at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
   at org.eclipse.birt.report.soapengine.processor.AbstractBaseDocumentProcessor.__executeAction(AbstractBaseDocumentProcessor.java:47)
   at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.executeAction(AbstractBaseComponentProcessor.java:143)
   at org.eclipse.birt.report.soapengine.processor.BirtDocumentProcessor.handleGetPageAll(BirtDocumentProcessor.java:183)
   at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.process(AbstractBaseComponentProcessor.java:112)
   at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingImpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
   at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
   at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
   at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
   at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
   at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
   at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
   at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
   at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
   at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
   at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
   at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
   at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
   at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
   at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)
   at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180)
   at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
   at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:126)
   at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
   at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:318)
   at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:511)
   at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:390)
   at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:182)
   at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:765)
   at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
   at org.mortbay.jetty.Server.handle(Server.java:326)
   at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:542)
   at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:939)
   at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:756)
   at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:212)
   at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:404)
   at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:409)
   at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThreadPool.java:582)
Caused by: org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
   at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:209)
   at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
   at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:920)
... 49 more
Caused by: java.lang.ExceptionInInitializerError
   at bumblehood.reporting.GoogleAnalyticsDataFetcher.(GoogleAnalyticsDataFetcher.java:61)
   at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
   at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
   at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
   at java.lang.reflect.Constructor.newInstance(Unknown Source)
   at org.mozilla.javascript.MemberBox.newInstance(MemberBox.java:194)
   at org.mozilla.javascript.NativeJavaClass.constructSpecific(NativeJavaClass.java:281)
   at org.mozilla.javascript.NativeJavaClass.construct(NativeJavaClass.java:200)
   at org.mozilla.javascript.ScriptRuntime.newObject(ScriptRuntime.java:2327)
   at org.mozilla.javascript.gen.c10._c1(:3)
   at org.mozilla.javascript.gen.c10.call()
   at org.mozilla.javascript.optimizer.OptRuntime.callName0(OptRuntime.java:108)
   at org.mozilla.javascript.gen.c11._c0(:0)
   at org.mozilla.javascript.gen.c11.call()
   at org.mozilla.javascript.ContextFactory.doTopCall(ContextFactory.java:398)
   at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime.java:3065)
   at org.mozilla.javascript.gen.c11.exec()
   at org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateRawScript(JavascriptEvalUtil.java:95)
   at org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateScript(JavascriptEvalUtil.java:134)
   at org.eclipse.birt.data.engine.script.ScriptEvalUtil.evaluateJSAsExpr(ScriptEvalUtil.java:1001)
   at org.eclipse.birt.data.engine.script.JSMethodRunner.runScript(JSMethodRunner.java:76)
   at org.eclipse.birt.report.engine.script.internal.DtEScriptExecutor.handleJS(DtEScriptExecutor.java:90)
   at org.eclipse.birt.report.engine.script.internal.DataSetScriptExecutor.handleJS(DataSetScriptExecutor.java:219)
   at org.eclipse.birt.report.engine.script.internal.ScriptDataSetScriptExecutor.handleOpen(ScriptDataSetScriptExecutor.java:88)
   at org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime.open(ScriptDataSetRuntime.java:80)
   at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor$CustomDataSet.open(PreparedScriptDSQuery.java:247)
   at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor.executeOdiQuery(PreparedScriptDSQuery.java:223)
   at org.eclipse.birt.data.engine.impl.QueryExecutor.execute(QueryExecutor.java:1094)
   at org.eclipse.birt.data.engine.impl.ServiceForQueryResults.executeQuery(ServiceForQueryResults.java:232)
   at org.eclipse.birt.data.engine.impl.QueryResults.getResultIterator(QueryResults.java:172)
   at org.eclipse.birt.report.engine.data.dte.QueryResultSet.(QueryResultSet.java:98)
   at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteQuery(DteDataEngine.java:168)
   at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:265)
   at org.eclipse.birt.report.engine.executor.ExecutionContext.executeQuery(ExecutionContext.java:1876)
   at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:80)
   at org.eclipse.birt.report.engine.executor.TableItemExecutor.execute(TableItemExecutor.java:62)
   at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)
   at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)
   at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:34)
   at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
   at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:90)
   at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:99)
   at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:180)
... 51 more
   at com.google.gdata.client.Service.(Service.java:97)
... 95 more
The java code for root NPE is:
	public class Service {
		private static final String SERVICE_VERSION =
		  "GData-Java/" + Service.class.getPackage().getImplementationVersion() // <------ THIS IS LINE WHICH THROWS NPE
			  + "(gzip)"; // Necessary to get GZIP encoded responses
Does anyone understands why this line causes NPE?
Marko
[Updated on: Wed, 17 November 2010 09:57] by Moderator
Re: Exception while loading class in Google Analytics client library [message #639774 is a reply to message #639706] Wed, 17 November 2010 12:47 Go to previous messageGo to next message
Marko,
in the designer can you remove the jars from the script lib and just try
adding them to the project classpath?
Jason
On 11/17/2010 9:37 AM, marko13 wrote:
> Hi all!
> for this purpose.
> Designer classpath.
> at
> org.eclipse.birt.report.service.ReportEngineService.throwDum myException(ReportEngineService.java:1097)
> at
> org.eclipse.birt.report.service.ReportEngineService.runAndRe nderReport(ReportEngineService.java:926)
> at
> org.eclipse.birt.report.service.BirtViewerReportService.runA ndRenderReport(BirtViewerReportService.java:973)
> at
> org.eclipse.birt.report.service.actionhandler.BirtGetPageAll ActionHandler.__execute(BirtGetPageAllActionHandler.java:131 )
> at
> org.eclipse.birt.report.service.actionhandler.AbstractBaseAc tionHandler.execute(AbstractBaseActionHandler.java:90)
> at
> org.eclipse.birt.report.soapengine.processor.AbstractBaseDoc umentProcessor.__executeAction(AbstractBaseDocumentProcessor .java:47)
> at
> org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.executeAction(AbstractBaseComponentProcessor .java:143)
> at
> org.eclipse.birt.report.soapengine.processor.BirtDocumentPro cessor.handleGetPageAll(BirtDocumentProcessor.java:183)
> at
> org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.process(AbstractBaseComponentProcessor.java: 112)
> at
> org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingI mpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
> at
> org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCP rovider.java:397)
> at
> org.apache.axis.providers.java.RPCProvider.processMessage(RP CProvider.java:186)
> at
> org.apache.axis.providers.java.JavaProvider.invoke(JavaProvi der.java:323)
> at
> org.apache.axis.strategies.InvocationStrategy.visit(Invocati onStrategy.java:32)
> at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService .java:454)
> at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281 )
> at org.apache.axis.transport.http.AxisServlet.doPost(AxisServle t.java:699)
> at
> org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
> at
> org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
> at
> org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.service(BirtSoapMessageDispatcherServlet.java:122)
> at
> org.eclipse.equinox.http.registry.internal.ServletManager$Se rvletWrapper.service(ServletManager.java:180)
> at
> org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.service(ServletRegistration.java:61)
> at
> org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:126)
> at
> org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:60)
> at
> org.eclipse.equinox.http.jetty.internal.HttpServerManager$In ternalHttpServiceServlet.service(HttpServerManager.java:318)
> at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:511)
> at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:390)
> at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandl er.java:182)
> at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandl er.java:765)
> at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapp er.java:152)
> at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnectio n.java:542)
> at
> org.mortbay.jetty.HttpConnection$RequestHandler.content(Http Connection.java:939)
> at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java: 212)
> at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java: 404)
> at
> org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEn dPoint.java:409)
> at
> org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThr eadPool.java:582)
> at
> org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:209)
> at
> org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:77)
> at
> org.eclipse.birt.report.service.ReportEngineService.runAndRe nderReport(ReportEngineService.java:920)
> ... 49 more
> at
> bumblehood.reporting.GoogleAnalyticsDataFetcher.(GoogleAnaly ticsDataFetcher.java:61)
> at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
> at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknow n Source)
> at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Un known
> Source)
> at org.mozilla.javascript.MemberBox.newInstance(MemberBox.java: 194)
> at
> org.mozilla.javascript.NativeJavaClass.constructSpecific(Nat iveJavaClass.java:281)
> at
> org.mozilla.javascript.NativeJavaClass.construct(NativeJavaC lass.java:200)
> at org.mozilla.javascript.ScriptRuntime.newObject(ScriptRuntime .java:2327)
> at
> org.mozilla.javascript.optimizer.OptRuntime.callName0(OptRun time.java:108)
> at org.mozilla.javascript.ContextFactory.doTopCall(ContextFacto ry.java:398)
> at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime .java:3065)
> at
> org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateRawS cript(JavascriptEvalUtil.java:95)
> at
> org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateScri pt(JavascriptEvalUtil.java:134)
> at
> org.eclipse.birt.data.engine.script.ScriptEvalUtil.evaluateJ SAsExpr(ScriptEvalUtil.java:1001)
> at
> org.eclipse.birt.data.engine.script.JSMethodRunner.runScript (JSMethodRunner.java:76)
> at
> org.eclipse.birt.report.engine.script.internal.DtEScriptExec utor.handleJS(DtEScriptExecutor.java:90)
> at
> org.eclipse.birt.report.engine.script.internal.DataSetScript Executor.handleJS(DataSetScriptExecutor.java:219)
> at
> org.eclipse.birt.report.engine.script.internal.ScriptDataSet ScriptExecutor.handleOpen(ScriptDataSetScriptExecutor.java:8 8)
> at
> org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime.open( ScriptDataSetRuntime.java:80)
> at
> org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor$CustomDataSet.open(PreparedScriptDSQuery.j ava:247)
> at
> org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor.executeOdiQuery(PreparedScriptDSQuery.java :223)
> at
> org.eclipse.birt.data.engine.impl.QueryExecutor.execute(Quer yExecutor.java:1094)
> at
> org.eclipse.birt.data.engine.impl.ServiceForQueryResults.exe cuteQuery(ServiceForQueryResults.java:232)
> at
> org.eclipse.birt.data.engine.impl.QueryResults.getResultIter ator(QueryResults.java:172)
> at
> org.eclipse.birt.report.engine.data.dte.QueryResultSet.(Quer yResultSet.java:98)
> at
> org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExec uteQuery(DteDataEngine.java:168)
> at
> org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.e xecute(AbstractDataEngine.java:265)
> at
> org.eclipse.birt.report.engine.executor.ExecutionContext.exe cuteQuery(ExecutionContext.java:1876)
> at
> org.eclipse.birt.report.engine.executor.QueryItemExecutor.ex ecuteQuery(QueryItemExecutor.java:80)
> at
> org.eclipse.birt.report.engine.executor.TableItemExecutor.ex ecute(TableItemExecutor.java:62)
> at
> org.eclipse.birt.report.engine.internal.executor.dup.Suppres sDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor .java:43)
> at
> org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe dReportItemExecutor.execute(WrappedReportItemExecutor.java:4 6)
> at
> org.eclipse.birt.report.engine.internal.executor.l18n.Locali zedReportItemExecutor.execute(LocalizedReportItemExecutor.ja va:34)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutNodes(HTMLBlockStackingLM.java:65)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:90)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:99)
> at
> org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:180)
> ... 51 more
> ... 95 more
> Marko
Re: Exception in Birt while loading class in Google Analytics client library [message #639878 is a reply to message #639706] Thu, 18 November 2010 04:05 Go to previous messageGo to next message
Jason,
I removed the jars from birt viewer plugin's scriptlib folder as you suggested and then I got ClassNotFoundException.
Caused by: java.lang.ClassNotFoundException: com.google.gdata.util.AuthenticationException
   at org.eclipse.birt.core.framework.URLClassLoader.findClass1(URLClassLoader.java:185)
   at org.eclipse.birt.core.framework.URLClassLoader$1.run(URLClassLoader.java:154)
   at org.eclipse.birt.core.framework.URLClassLoader$1.run(URLClassLoader.java:1)
   at org.eclipse.birt.core.framework.URLClassLoader.findClass(URLClassLoader.java:149)
... 102 more
I did include jars in project classpath in Preferences -> Report Design -> Classpath
[Updated on: Thu, 18 November 2010 04:06] by Moderator
Re: Exception in Birt while loading class in Google Analytics client library [message #639976 is a reply to message #639878] Thu, 18 November 2010 10:05 Go to previous messageGo to next message
Are the jars in a separate project or the report project? What version
of BIRT are you using? Any chance you could email me the jars and the
report?
Jason
On 11/18/2010 4:05 AM, marko13 wrote:
> Jason,
> I removed the jars from birt vierwer plugin's scriptlib folder and then
> at
> org.eclipse.birt.core.framework.URLClassLoader.findClass1(UR LClassLoader.java:185)
> at
> org.eclipse.birt.core.framework.URLClassLoader$1.run(URLClas sLoader.java:154)
> at
> org.eclipse.birt.core.framework.URLClassLoader$1.run(URLClas sLoader.java:1)
> at java.security.AccessController.doPrivileged(Native Method)
> at
> org.eclipse.birt.core.framework.URLClassLoader.findClass(URL ClassLoader.java:149)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> ... 102 more
> -> Classpath
Re: Exception in Birt while loading class in Google Analytics client library [message #639989 is a reply to message #639976] Thu, 18 November 2010 10:46 Go to previous messageGo to next message
I'm using RPC Designer, version 2.6.1. I belive that jars are added to the project (not separate project).
I can send you the report and the jars. Just tell me on which email address, since email sending on forum is disabled,
Marko
[Updated on: Thu, 18 November 2010 10:46] by Moderator
Re: Exception in Birt while loading class in Google Analytics client library [message #639996 is a reply to message #639989] Thu, 18 November 2010 10:50 Go to previous messageGo to next message
jasonweathersby at windstream dot net
Re: Exception in Birt while loading class in Google Analytics client library [message #640960 is a reply to message #639996] Tue, 23 November 2010 12:04 Go to previous messageGo to next message
Was this issue resolved? I'm trying to do the exact same thing and would love to see this as an example.
Thank you.
Re: Exception in Birt while loading class in Google Analytics client library [message #640977 is a reply to message #640960] Tue, 23 November 2010 12:52 Go to previous messageGo to next message
Meghan,
I go the classpath stuff working but got authentication problems when
trying to login to google. Take a look at this blog post to see how to
handle the classpath in the designer:
http://birtworld.blogspot.com/2009/12/birt-designer-classpat h-changes.html
Try creating a java project in the same workspace as the report project
and then add the java project to the classpath of the report project in
the preferences. If you have an example of a working java client I
could build you an example of this.
Jason
> Thank you.
Re: Exception in Birt while loading class in Google Analytics client library [message #640999 is a reply to message #640977] Tue, 23 November 2010 14:45 Go to previous messageGo to next message
Jason,
Thanks for your quick reply. Unfortunately I am very new to BIRT and more importantly unfamiliar with JAVA. I was hoping to work from this report as an example and learn what components I needed to create in order to tap into my Google Analytics account. Any ideas on where to even start?
Re: Exception in Birt while loading class in Google Analytics client library [message #641212 is a reply to message #640999] Wed, 24 November 2010 09:50 Go to previous messageGo to next message
I will try to put an example together in a day or two.
Jason
On 11/23/2010 2:45 PM, Meghan wrote:
> Jason,
> even start?
Re: Exception in Birt while loading class in Google Analytics client library [message #645877 is a reply to message #641212] Mon, 20 December 2010 17:00 Go to previous messageGo to next message
Jason,
Any luck on getting an example? Just wanted to follow up.
Thanks.
Meghan
Re: Exception in Birt while loading class in Google Analytics client library [message #645999 is a reply to message #645877] Tue, 21 December 2010 09:22 Go to previous messageGo to next message
Meghan,
Thanks for reminding me. I will try to get a blog on this up shortly.
Jason
On 12/20/2010 5:00 PM, Meghan wrote:
> Jason,
> Thanks.
> Meghan
Re: Exception in Birt while loading class in Google Analytics client library [message #646246 is a reply to message #645999] Wed, 22 December 2010 16:01 Go to previous messageGo to next message
Meghan,
I went through building an example but I am still having issues with the
classpath. Once I get that worked out I will post something.
Jason
On 12/21/2010 9:22 AM, Jason Weathersby wrote:
> Meghan,
> Jason
>> Jason,
>> Thanks.
>> Meghan
Re: Exception in Birt while loading class in Google Analytics client library [message #667183 is a reply to message #646246] Wed, 27 April 2011 05:15 Go to previous messageGo to next message
I'm trying to use Google Analytics as a data source in my report and i would like to follow an example. So, Is there any progress on this issue?
Thanks.
[Updated on: Wed, 27 April 2011 05:16] by Moderator
Re: Exception in Birt while loading class in Google Analytics client library [message #667264 is a reply to message #667183] Wed, 27 April 2011 13:49 Go to previous messageGo to next message
I have an example built but I have not written up yet. I will try to do
this tomorrow. The only issue I have is that the example uses my
private google account settings. What issue are you having?
Jason
On 4/27/2011 5:15 AM, piratejackus wrote:
> Hello Jason,
> Thanks.
> [quote title=Jason Weathersby wrote on Wed, 22 December 2010 16:01]Meghan,
> Jason
Re: Exception in Birt while loading class in Google Analytics client library [message #667273 is a reply to message #667264] Wed, 27 April 2011 15:14 Go to previous messageGo to next message
i found a fine example which gave me an idea. I was having an issue with connecting report script and java objects, but i made it.
Thank you for your reponse Jason.
the useful link that i found is on my other computer, i will paste it here if i don't forget (:
[quote title=Jason Weathersby wrote on Wed, 27 April 2011 19:49]I have an example built but I have not written up yet. I will try to do
Jason
> Hello Jason,
> Thanks.
Meghan,
> Jason
[Updated on: Wed, 27 April 2011 17:55] by Moderator
Re: Exception in Birt while loading class in Google Analytics client library [message #667281 is a reply to message #667273] Wed, 27 April 2011 16:16 Go to previous messageGo to next message
I went back through my example and realized that I did not get this to
work. There is a class loader issue with one of the Google static
variables. Did you get your example to work?
Jason
> here i don't forget (:
> an example built but I have not written up yet. I will try to do this
> tomorrow. The only issue I have is that the example uses my private
> Jason
>> Hello Jason,
>> Thanks.
>> Meghan,
>> the
>> > Jason
Re: Exception in Birt while loading class in Google Analytics client library [message #667296 is a reply to message #667281] Wed, 27 April 2011 17:53 Go to previous messageGo to next message
Hi Jason,
I can make queries in google analytics and pass the data to my objects and then use them with the javascript (Report Scripting tool) in the reports. More simply; i can use google analytics with POJO s, as a scripted data source, in my reports.
If you like, i can give you a more detailed information on my basic project tomorrow (after about 9-10 hours). I didn't have any big problems with that.
Just let me know.
Jason Weathersby wrote on Wed, 27 April 2011 22:16
Jason
I have
> Jason
>> Hello Jason,
>> Thanks.
>> Meghan,
>> the
>> > Jason
[Updated on: Thu, 28 April 2011 11:42] by Moderator
Re: Exception in Birt while loading class in Google Analytics client library [message #667325 is a reply to message #667296] Thu, 28 April 2011 03:10 Go to previous messageGo to next message
So this is the link that helped me to use 'scripted data source' in my Birt report :
(it is detailed)
http:// thoughts.inphina.com/2010/09/12/using-scripted-data-sources- in-birt-and-deploying-in-application-server/
and the rest of it is just like the google analytics example code:
(under Analytics Account Authorization topic, click the plus near the View the Full Java Example)
http://code.google.com/apis/analytics/docs/gdata/2.0/gdataJa va.html
Those were enough for me, i'm also new to Birt & Google Analytics.
Cheers
[Updated on: Thu, 28 April 2011 03:12] by Moderator
Re: Exception in Birt while loading class in Google Analytics client library [message #667342 is a reply to message #667325] Thu, 28 April 2011 04:59 Go to previous messageGo to next message
hi Jason,
Excuse me for misleading this thread. Yesterday, when i see the gdata results in preview results of data set, i thought that i did it and i had to leave. but when i tried to run the report in preview (same in other formats) i got a similar exception as marko, i copied it here.
The line that i get the ExceptionInInitializerError is:
AnalyticsService analyticsService = new AnalyticsService("GAFetcher");
and for the NPE:
public static Version getVersion()
    return VersionRegistry.get().getVersion(Service.class);
in com.google.gdata.client.Service.java
It is a fast reply without a solution just to set aright my situation in this. I'm still looking for the reason. As i find it, i will post it here. I will also open this issue in birt-excahnge forum.
Here is the stacktrace:
- org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
AxisFault
faultCode: {http://schemas.xmlsoap.org/soap/envelope/}Server.userExcept ion
faultSubcode:
faultString: org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
faultActor:
faultNode:
faultDetail:
{http://xml.apache.org/axis/}stackTrace:org.eclipse.birt.rep ort.service.api.ReportServiceException: Error happened while running the report.
at org.eclipse.birt.report.service.ReportEngineService.throwDum myException(ReportEngineService.java:1105)
at org.eclipse.birt.report.service.ReportEngineService.runAndRe nderReport(ReportEngineService.java:934)
at org.eclipse.birt.report.service.BirtViewerReportService.runA ndRenderReport(BirtViewerReportService.java:973)
at org.eclipse.birt.report.service.actionhandler.BirtRunAndRend erActionHandler.__execute(BirtRunAndRenderActionHandler.java :76)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseAc tionHandler.execute(AbstractBaseActionHandler.java:90)
at org.eclipse.birt.report.presentation.aggregation.layout.Engi neFragment.doService(EngineFragment.java:318)
at org.eclipse.birt.report.presentation.aggregation.AbstractBas eFragment.service(AbstractBaseFragment.java:76)
at org.eclipse.birt.report.servlet.BirtEngineServlet.__doGet(Bi rtEngineServlet.java:120)
at org.eclipse.birt.report.servlet.BaseReportEngineServlet.doGe t(BaseReportEngineServlet.java:185)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
at org.eclipse.birt.report.servlet.BaseReportEngineServlet.serv ice(BaseReportEngineServlet.java:116)
at org.eclipse.equinox.http.registry.internal.ServletManager$Se rvletWrapper.service(ServletManager.java:180)
at org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.service(ServletRegistration.java:61)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:126)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:60)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$In ternalHttpServiceServlet.service(HttpServerManager.java:318)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComple te(HttpConnection.java:924)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:549)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEn dPoint.java:409)
at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThr eadPool.java:582)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:209)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:77)
at org.eclipse.birt.report.service.ReportEngineService.runAndRe nderReport(ReportEngineService.java:928)
... 30 more
at gafetcher.WoomjiUserSystemInfo.getVisitorsSystemAndVisitInfo (WoomjiUserSystemInfo.java:43)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.mozilla.javascript.MemberBox.invoke(MemberBox.java:161)
at org.mozilla.javascript.NativeJavaMethod.call(NativeJavaMetho d.java:247)
at org.mozilla.javascript.optimizer.OptRuntime.callProp0(OptRun time.java:119)
at org.mozilla.javascript.gen.c5._c1(/report/data-sets/script-d ata-set[@id=&quot;13&quot;]/method[@name=&quot;o pen&quot;]:5)
at org.mozilla.javascript.gen.c5.call(/report/data-sets/script- data-set[@id=&quot;13&quot;]/method[@name=&quot; open&quot;])
at org.mozilla.javascript.optimizer.OptRuntime.callName0(OptRun time.java:108)
at org.mozilla.javascript.gen.c6._c0(/report/data-sets/script-d ata-set[@id=&quot;13&quot;]/method[@name=&quot;o pen&quot;]:0)
at org.mozilla.javascript.gen.c6.call(/report/data-sets/script- data-set[@id=&quot;13&quot;]/method[@name=&quot; open&quot;])
at org.mozilla.javascript.gen.c6.exec(/report/data-sets/script- data-set[@id=&quot;13&quot;]/method[@name=&quot; open&quot;])
at org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateRawS cript(JavascriptEvalUtil.java:95)
at org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateScri pt(JavascriptEvalUtil.java:134)
at org.eclipse.birt.data.engine.script.ScriptEvalUtil.evaluateJ SAsExpr(ScriptEvalUtil.java:1001)
at org.eclipse.birt.data.engine.script.JSMethodRunner.runScript (JSMethodRunner.java:138)
at org.eclipse.birt.report.engine.script.internal.DtEScriptExec utor.handleJS(DtEScriptExecutor.java:90)
at org.eclipse.birt.report.engine.script.internal.DataSetScript Executor.handleJS(DataSetScriptExecutor.java:246)
at org.eclipse.birt.report.engine.script.internal.ScriptDataSet ScriptExecutor.handleOpen(ScriptDataSetScriptExecutor.java:9 7)
at org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime.open( ScriptDataSetRuntime.java:80)
at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor$CustomDataSet.open(PreparedScriptDSQuery.j ava:247)
at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor.executeOdiQuery(PreparedScriptDSQuery.java :223)
at org.eclipse.birt.data.engine.impl.QueryExecutor.execute(Quer yExecutor.java:1103)
at org.eclipse.birt.data.engine.impl.ServiceForQueryResults.exe cuteQuery(ServiceForQueryResults.java:232)
at org.eclipse.birt.data.engine.impl.QueryResults.getResultIter ator(QueryResults.java:173)
at org.eclipse.birt.report.engine.data.dte.QueryResultSet.& lt;init&gt;(QueryResultSet.java:98)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExec uteQuery(DteDataEngine.java:168)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.e xecute(AbstractDataEngine.java:265)
at org.eclipse.birt.report.engine.executor.ExecutionContext.exe cuteQuery(ExecutionContext.java:1890)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.ex ecuteQuery(QueryItemExecutor.java:80)
at org.eclipse.birt.report.engine.executor.TableItemExecutor.ex ecute(TableItemExecutor.java:62)
at org.eclipse.birt.report.engine.internal.executor.dup.Suppres sDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor .java:43)
at org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe dReportItemExecutor.execute(WrappedReportItemExecutor.java:4 6)
at org.eclipse.birt.report.engine.internal.executor.l18n.Locali zedReportItemExecutor.execute(LocalizedReportItemExecutor.ja va:34)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:90)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:99)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:180)
... 32 more
at com.google.gdata.client.Service.&lt;clinit&gt;(Servi ce.java:97)
... 75 more
{http://xml.apache.org/axis/}hostname:extelia_innovation_699
{}:org.eclipse.birt.report.service.api.ReportServiceExceptio n: Error happened while running the report.
... 30 more
... 32 more
... 75 more
at org.apache.axis.AxisFault.makeFault(AxisFault.java:101)
at org.eclipse.birt.report.utility.BirtUtility.makeAxisFault(Bi rtUtility.java:761)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseAc tionHandler.execute(AbstractBaseActionHandler.java:94)
Caused by: org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
... 27 more
... 30 more
at org.mozilla.javascript.gen.c5._c1(/report/data-sets/script-d ata-set[@id= "13"]/method[@name="open"]:5)
at org.mozilla.javascript.gen.c5.call(/report/data-sets/script- data-set[@id= "13"]/method[@name="open"])
at org.mozilla.javascript.gen.c6._c0(/report/data-sets/script-d ata-set[@id= "13"]/method[@name="open"]:0)
at org.mozilla.javascript.gen.c6.call(/report/data-sets/script- data-set[@id= "13"]/method[@name="open"])
at org.mozilla.javascript.gen.c6.exec(/report/data-sets/script- data-set[@id= "13"]/method[@name="open"])
at org.eclipse.birt.report.engine.data.dte.QueryResultSet.<init >(QueryResultSet.java:98)
... 32 more
at com.google.gdata.client.Service.<clinit>(Service.java:97)
... 75 more
[Updated on: Fri, 29 April 2011 05:55] by Moderator
Re: Exception in Birt while loading class in Google Analytics client library [message #667395 is a reply to message #667342] Thu, 28 April 2011 09:55 Go to previous messageGo to next message
This is the error that I got. It is a classloader issue with the BIRT
engine. Currently I do not have a work around.
Jason
On 4/28/2011 4:59 AM, piratejackus wrote:
> hi Jason,
> and for the NPE:
> It is a fast reply withour a solution just to set aright my situation in
> AxisFault
> faultSubcode: faultString:
> faultActor: faultNode: faultDetail:
> er.java:390)
> er.java:182)
> er.java:765)
> er.java:152)
> dPoint.java:409)
> eadPool.java:582)
> ... 30 more
> ssorImpl.java:57)
> time.java:119)
> ata-set[@id="13"]/method[@name="o pen"]:5)
> data-set[@id="13"]/method[@name=" open"])
> time.java:108)
> ata-set[@id="13"]/method[@name="o pen"]:0)
> ry.java:398)
> lt;init>(QueryResultSet.java:98)
> ... 32 more
> at com.google.gdata.client.Service.<clinit>(Servi ce.java:97)
> ... 75 more
> er.java:390)
> er.java:182)
> er.java:765)
> er.java:152)
> dPoint.java:409)
> eadPool.java:582)
> ... 30 more
> ssorImpl.java:57)
> time.java:119)
> time.java:108)
> ry.java:398)
> ... 32 more
> ... 75 more
> rtUtility.java:761)
> er.java:390)
> er.java:182)
> er.java:765)
> er.java:152)
> dPoint.java:409)
> eadPool.java:582)
> ... 27 more
> ... 30 more
> ssorImpl.java:57)
> time.java:119)
> time.java:108)
> ry.java:398)
> ... 32 more
> ... 75 more
Re: Exception in Birt while loading class in Google Analytics client library [message #667397 is a reply to message #667395] Thu, 28 April 2011 10:07 Go to previous messageGo to next message
hi Jason,
I'm still on this and tried to copy the necessary libraries to the scriptlib (in my case under ~/software/springsource/sts-2.5.2.SR1/plugins/org.eclipse.bi rt.report.viewer_2.6.2.r262_v20110214/birt/scriptlib)
and i put them in the resources under Report Design - Property Editor. They are also in the classpath but it still doesn't work. If i can find a solution, i will be back!
p.s. : i created another detailed thread (with the code) under the birt-exchange forum to get more help from birt admins:http:// www.birt-exchange.org/org/forum/index.php/topic/22184-google -analytics-api-as-a-scripted-data-source/
Jason Weathersby wrote on Thu, 28 April 2011 15:55
Jason
[Updated on: Thu, 28 April 2011 11:27] by Moderator
Re: Exception in Birt while loading class in Google Analytics client library [message #667420 is a reply to message #667395] Thu, 28 April 2011 11:27 Go to previous messageGo to next message
Hi Jason,
Do you know the difference between the dataset preview and the designer preview? You said that it is a classloader issue, so it means that the engine cannot find the jars to initialize the service (Google Analytics), right?
Jason
[Updated on: Thu, 28 April 2011 11:28] by Moderator
Re: Exception in Birt while loading class in Google Analytics client library [message #667435 is a reply to message #667420] Thu, 28 April 2011 13:43 Go to previous messageGo to next message
BIRT uses a custom classloader that does not implement optional features
that are being used by the AnalyticsService class.
Jason
On 4/28/2011 11:27 AM, piratejackus wrote:
> Hi Jason,
> Analytics), right?
>> Jason
Re: Exception in Birt while loading class in Google Analytics client library [message #667570 is a reply to message #667435] Fri, 29 April 2011 11:11 Go to previous messageGo to next message
Hi Jason,
I searched my other reporting tool option: pentaho but its google analytics api plugin is not free! For the jasper, i couldn't find much resources till now.
I tried to put the libs, my classes and my report under the birt-runtime example (birt-runtime-2_6_2 -> WebViewerExample) packaged it as a war and deployed in a tomcat server. I got:
WARNING: Fail to execute script in function __bm_OPEN(). Source:
appUserSystemInfo = new Packages.AppUserSystemInfo();
appVisitersSystemAndVisitInfos = appUserSystemInfo.getVisitorsSystemAndVisitInfo();
i = 0; + "
A BIRT exception occurred. See next exception for more information.
Error evaluating Javascript expression. Script engine error: TypeError: [JavaPackage AppUserSystemInfo] is not a function, it is object. (/report/data-sets/script-data-set[@id="13"]/method[@name= "open"]#3)
Script source: /report/data-sets/script-data-set[@id="13"]/method[@name="open "], line: 0, text:
__bm_OPEN()
org.eclipse.birt.data.engine.core.DataException: Fail to execute script in function __bm_OPEN(). Source:
i = 0; + "
Actually i'm trying this way because the classloader issue tired me a lot. I opened a bug for that one:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=344239.
So do you think that it might work by deploying the projet in a web server?
Thanks.
[Updated on: Fri, 29 April 2011 11:14] by Moderator
Re: Exception in Birt while loading class in Google Analytics client library [message #667596 is a reply to message #667570] Fri, 29 April 2011 16:12 Go to previous messageGo to next message
We actually got this working.
We downloaded the following jars:
gdata-analytics-2.1
gdata-analytics-meta-2.1
gdata-client-1.0
gdata-client-meta-1.0
gdata-core-1.0
google-collect-1.0-rc1
The class files were unpacked and stored in the plugin folder of our Eclipse directory. My path looks like this:
C:\Eclipse\eclipse\plugins\org.eclipse.birt.report.viewer_2. 6.1.v20100913\birt\WEB-INF\classes\com\google\gdata
We've also created another directory under classes\com\[remainingpath] that stores the following class files:
AnalyticsServiceAdapter.class, PriorityFutureTask.class, ThrottledPriorityBlockingQueue.class, and UsageData.class
It is this set of class files that is referenced by our data set.
in the data set open event we have code like this:
count = 0;
var myUrl = 'https://www.google.com/analytics/feeds/data' +
// this is your google account ID
'?ids=ga%##### +
'&dimensions=ga%3Adate%2Cga%3ApagePath' +
'%2Cga%3Acountry' +
'%2Cga%3Aregion' +
'&metrics=ga%3Apageviews%2Cga%3AtimeOnPage' +
'&filters=ga%3ApagePath%3D%40training%2F' +
'&sort=-ga%3Apageviews' +
'&start-date=2010-01-01' +
'&end-date=2010-01-31'
var gaa = new Packages.com.folderpath.google.analytics.AnalyticsServiceAda pter();
stock = gaa.doQuery(myUrl);
Then, in the fetch script we have:
if (typeof stock == "undefined"){
return (false);
var myObject = eval('(' + stock + ')');
if (typeof myObject == "undefined"){
return (false);
if ('entries' in myObject && typeof myObject.entries.length == 'undefined'){
var totCount = 1;
if(count < totCount){
row["Date"] = myObject.entries.dimensions[0].value;
row["RealDate"] = row["Date"].substring(0, 4) + '-' + row["Date"].substring(4,6) + '-' + row["Date"].substring(6,8);
row["ContentPath"] = myObject.entries.dimensions[1].value;
row["Country"] = myObject.entries.dimensions[2].value;
row["Region"] = myObject.entries.dimensions[3].value;
row["ContentViews"] = myObject.entries.metrics[0].value;
row["TimeOnContent"] = myObject.entries.metrics[1].value;
count++;
return(true);
else
if ('entries' in myObject){
var totCount = myObject.entries.length;
row["Date"] = myObject.entries[count].dimensions[0].value;
row["ContentPath"] = myObject.entries[count].dimensions[1].value;
row["Country"] = myObject.entries[count].dimensions[2].value;
row["Region"] = myObject.entries[count].dimensions[3].value;
row["ContentViews"] = myObject.entries[count].metrics[0].value;
row["TimeOnContent"] = myObject.entries[count].metrics[1].value;
count++;
return (true);
return (false);
I hope this helps.
Re: Exception in Birt while loading class in Google Analytics client library [message #667612 is a reply to message #667596] Fri, 29 April 2011 18:02 Go to previous messageGo to next message
Thanks Meghan. This is good information.
> gdata-analytics-2.1
> gdata-client-1.0
> gdata-core-1.0
> count = 0;
> '?ids=ga%##### +
> '%2Cga%3Acountry' + '%2Cga%3Aregion' +
> '&filters=ga%3ApagePath%3D%40training%2F' + '&sort=-ga%3Apageviews' +
> var gaa = new
> return (false);
> return (false);
> 'undefined'){
> var totCount = 1;
> count++;
> return(true);
> else
> count++;
> return (true);
> return (false);
> I hope this helps.
Re: Exception in Birt while loading class in Google Analytics client library [message #667633 is a reply to message #667612] Sat, 30 April 2011 04:07 Go to previous messageGo to next message
Hi all,
Meghan, thank you for this solution but i got some questions:
- Where did you put those jars? classpath, scriptlib, WEB-INF/lib,Report Design -> Property Editor -> Jar Files (which one or ones?)
- I think you created those classes,com,google,data directories and also for your depending classes that other directory, am i right?
- If you already referenced ga api libraries, why did you placed AnalyticsServiceAdapter.class under WEB-INF too?
In my side, i have some news too!
i created a bug form for the birt application and this issue. can be found;
I received a patch for the URLClassLoader.java from the birt team. I applied it and it worked for me. I don't have anymore problems on this issue. That may help you too.
(The patch and the solution is in that link)
Thank you one more time Meghan and Jason for all your effort.
Ciao!
Jason Weathersby wrote on Sat, 30 April 2011 00:02
> gdata-analytics-2.1
> gdata-client-1.0
> gdata-core-1.0
> count = 0;
> '?ids=ga%##### +
> var gaa = new
> return (false);
> return (false);
> 'undefined'){
> var totCount = 1;
> count++;
> return(true);
> else
> count++;
> return (true);
> return (false);
> I hope this helps.
[Updated on: Sat, 30 April 2011 04:08] by Moderator
Re: Exception in Birt while loading class in Google Analytics client library [message #685826 is a reply to message #667633] Mon, 20 June 2011 05:57 Go to previous messageGo to next message
I am trying to reproduce the solution that is suggested in this thread, for using scripted datasets to produce reports with data extracted from the Google Analytics Data API. It is rather difficult to follow the instructions here. I have tried moving the google api jar here and there but I still dont have any results. Is there some way I can get an example of how this could be done?
Thank you for your help
-Teo
Re: Exception in Birt while loading class in Google Analytics client library [message #685830 is a reply to message #685826] Mon, 20 June 2011 06:10 Go to previous messageGo to next message
Hi Teo,
What is your problem exactly? Can you post your stacktrace or any error message? Did you try to use the patched version of URLClassLoader class?
Re: Exception in Birt while loading class in Google Analytics client library [message #685979 is a reply to message #685830] Tue, 21 June 2011 04:44 Go to previous messageGo to next message
I am trying to fetch some data from GA and present them through a scripted data source. I currently have the POJOs that implement the model of the scripted data source in the ...org.eclipse.birt.report.viewer_2.6.2.r262_v20110214\birt\WEB-INF\classes\com\gamodel folder and include the GA jars in the report designer classpath. The jars are located inside the scriptlib folder, but I have also extracted the gdata folder as follows ...org.eclipse.birt.report.viewer_2.6.2.r262_v20110214\birt\WEB-INF\classes\com\google\gdata . Do I need to put them somewhere else?
Thank you for your help,
Teo
this is the stacktrace I get by using the patched URLClassLoader...
at org.eclipse.birt.report.service.ReportEngineService.throwDummyException(ReportEngineService.java:1105)
at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:934)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:928)
... 49 more
Caused by: java.lang.NoClassDefFoundError: com/google/gdata/util/AuthenticationException
at java.lang.Class.getDeclaredMethods0(Native Method)
at java.lang.Class.privateGetDeclaredMethods(Class.java:2427)
at java.lang.Class.privateGetPublicMethods(Class.java:2547)
at java.lang.Class.getMethods(Class.java:1410)
at org.mozilla.javascript.JavaMembers.discoverAccessibleMethods(JavaMembers.java:380)
at org.mozilla.javascript.JavaMembers.discoverAccessibleMethods(JavaMembers.java:335)
at org.mozilla.javascript.JavaMembers.reflect(JavaMembers.java:450)
at org.mozilla.javascript.JavaMembers.(JavaMembers.java:76)
at org.mozilla.javascript.JavaMembers.lookupClass(JavaMembers.java:838)
at org.mozilla.javascript.NativeJavaClass.initMembers(NativeJavaClass.java:84)
at org.mozilla.javascript.NativeJavaClass.(NativeJavaClass.java:78)
at org.mozilla.javascript.NativeJavaPackage.getPkgProperty(NativeJavaPackage.java:164)
at org.mozilla.javascript.ImporterTopLevel.getPackageProperty(ImporterTopLevel.java:146)
at org.mozilla.javascript.ImporterTopLevel.get(ImporterTopLevel.java:134)
at org.mozilla.javascript.ScriptableObject.getProperty(ScriptableObject.java:1617)
at org.mozilla.javascript.ScriptRuntime.topScopeName(ScriptRuntime.java:1788)
at org.mozilla.javascript.ScriptRuntime.nameOrFunction(ScriptRuntime.java:1755)
at org.mozilla.javascript.ScriptRuntime.name(ScriptRuntime.java:1697)
at org.mozilla.javascript.gen.c5._c1(/report/data-sets/script-data-set[@id="8"]/method[@name="open"]:4)
at org.mozilla.javascript.gen.c5.call(/report/data-sets/script-data-set[@id="8"]/method[@name="open"])
at org.mozilla.javascript.gen.c6._c0(/report/data-sets/script-data-set[@id="8"]/method[@name="open"]:0)
at org.mozilla.javascript.gen.c6.call(/report/data-sets/script-data-set[@id="8"]/method[@name="open"])
at org.mozilla.javascript.gen.c6.exec(/report/data-sets/script-data-set[@id="8"]/method[@name="open"])
at org.eclipse.birt.data.engine.script.JSMethodRunner.runScript(JSMethodRunner.java:138)
at org.eclipse.birt.report.engine.script.internal.DataSetScriptExecutor.handleJS(DataSetScriptExecutor.java:246)
at org.eclipse.birt.report.engine.script.internal.ScriptDataSetScriptExecutor.handleOpen(ScriptDataSetScriptExecutor.java:97)
at org.eclipse.birt.data.engine.impl.QueryExecutor.execute(QueryExecutor.java:1103)
at org.eclipse.birt.data.engine.impl.QueryResults.getResultIterator(QueryResults.java:173)
at org.eclipse.birt.report.engine.executor.ExecutionContext.executeQuery(ExecutionContext.java:1890)
... 51 more
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:506)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:422)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:410)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:320)
... 104 more
[Updated on: Tue, 21 June 2011 08:40] by Moderator
Re: Exception in Birt while loading class in Google Analytics client library [message #685982 is a reply to message #685979] Tue, 21 June 2011 05:04 Go to previous messageGo to next message
That exception is the same that i got before. Here is my project hierarchy:
piratejackus@D20715:~/software/springsource/workspace-sts-2.6.0.SR1/GAFetcher$ tree -a
|-- bin
|   |-- constants
|   |   `-- LoginCredentials.class
|   |-- gafetcher
|   |   |-- GAFetcherTest.class
|   |   `-- MyProjectUserSystemInfo.class
|   |-- js
|   |   `-- debugWindow.js
|   |-- models
|   |   `-- UserSystemAndVisitInfo.class
|   `-- reports
|       `-- myProject_user_ga.rptdesign
|-- .classpath
|-- lib
|   |-- activation.jar
|   |-- gdata-analytics-2.1.jar
|   |-- gdata-analytics-meta-2.1.jar
|   |-- gdata-client-1.0.jar
|   |-- gdata-client-meta-1.0.jar
|   |-- gdata-core-1.0.jar
|   |-- gdata-docs-3.0.jar
|   |-- gdata-docs-meta-3.0.jar
|   |-- gdata-media-1.0.jar
|   |-- google-collect-1.0-rc1.jar
|   |-- jsr305.jar
|   |-- mail.jar
|   `-- servlet-api.jar
|-- .project
|-- .settings
|   `-- org.eclipse.jdt.core.prefs
`-- src
    |-- constants
    |   `-- LoginCredentials.java
    |-- gafetcher
    |   |-- GAFetcherTest.java
    |   `-- MyProjectUserSystemInfo.java
    |-- js
    |   `-- debugWindow.js
    |-- models
    |   `-- UserSystemAndVisitInfo.java
    `-- reports
i also have these libraries under scriptlib directory(actually i didn't try by removing libraries from here):
piratejackus@D20715:~/software/springsource/sts-2.5.2.SR1/plugins/org.eclipse.birt.report.viewer_2.6.2.r262_v20110214/birt/scriptlib$ ls
activation.jar           gdata-analytics-meta-2.1.jar  gdata-client-meta-1.0.jar  gdata-docs-3.0.jar       gdata-media-1.0.jar         jsr305.jar  readme.txt
gdata-analytics-2.1.jar  gdata-client-1.0.jar          gdata-core-1.0.jar         gdata-docs-meta-3.0.jar  google-collect-1.0-rc1.jar  mail.jar    servlet-api.jar
Can you preview the results in your dateset properties(right click your dataset and click on edit then preview results)? Just to be sure if your scripting code(java script) and POJOs works well.
If you can get results here so try to replace your libraries as i mentioned above.
If you have still problems, let me know.
[Updated on: Tue, 21 June 2011 05:05] by Moderator
Re: Exception in Birt while loading class in Google Analytics client library [message #686032 is a reply to message #685982] Tue, 21 June 2011 08:54 Go to previous messageGo to next message
the POJOs and the javascript code seem to be working fine as I tried them with some dummy data. The problem apears when I try to connect to GA to get the data. That is when I get this exception. I don't know what your implementation is but I am trying to connet to the GA API inside my Java Classes and not by using javascript in the report design.. So you just moved the jars to the scriptlib, recompiled the URLClassLoader.java, applied the produced classes and it worked? The hierarchy in your workspace is not that important, right?
Re: Exception in Birt while loading class in Google Analytics client library [message #686036 is a reply to message #686032] Tue, 21 June 2011 09:18 Go to previous messageGo to next message
In one of my older post i gave a link (which is: http://www.birt-exchange.org/org/forum/index.php/topic/22184-google-analytics-api-as-a-scripted-data-source/) where you can find all my source code. I used java classes to get GA data too. Java script is just to call my java classes from report.
The hierarchy is not important. I got it working just after i applied the patch.
Did you apply the patch? I couldn't see the NPE in your stack trace, is that all of the trace?
At last, you have a AuthenticationException which is different from my situation i guess (i made a mistake buy saying that they are same problems).
[Updated on: Tue, 21 June 2011 09:19] by Moderator
Re: Exception in Birt while loading class in Google Analytics client library [message #686452 is a reply to message #686036] Wed, 22 June 2011 05:05 Go to previous messageGo to next message
Thanks for your help, it was absolutely vital Smile. I finally got it working. I had some real authentication issues and that is why I could not get any results.
-Te0
Re: Exception in Birt while loading class in Google Analytics client library [message #686454 is a reply to message #686452] Wed, 22 June 2011 05:12 Go to previous message
Gald to hear that. Good luck on your project.
Previous Topic:Documented changes to font sizes?
Next Topic:PageVariable classcast-exception after osgi-bundle-refresh
Current Time: Sat Jul 26 10:49:40 EDT 2025
Powered by FUDForum. Page generated in 0.26766 seconds
