Home » Eclipse Projects » DTP » Where are "vendor filter" in Driver Definition (in Helios) ?
Where are "vendor filter" in Driver Definition (in Helios) ? [message #638320] Wed, 10 November 2010 15:14 Go to next message
I would like to create a driver definition for PostgreSQL with DTP
(Window >> Preferences >> Data Management >> ...)
In Galileo, non problem.
But in Helios, while entring a new Driver Definition, there's only one vendor filter ("generic JDBC"), where there was a lot of vendors filters in Galileo...
Do you know how to populate vendor filter ?
Thanks in advance
Re: Where are "vendor filter" in Driver Definition (in Helios) ? [message #639575 is a reply to message #638320] Tue, 16 November 2010 18:36 Go to previous messageGo to next message
Hi there...
What do you have installed? Did you install all of DTP or just
Connectivity? If you didn't install the "Enablement" features, you won't
see any of the additional vendor filters.
Works fine for me in Helios.
--Fitz
akamanouche@gmail.com wrote:
> in Galileo...
> Thanks in advance
Re: Where are "vendor filter" in Driver Definition (in Helios) ? [message #639801 is a reply to message #639575] Wed, 17 November 2010 15:50 Go to previous messageGo to next message
Hi Brian
Thanks for your response
I didn't install anything more than the default DTP config, given with Helios distrib.
But i'm going to... as You suggested
I will give feedback
thx
Re: Where are "vendor filter" in Driver Definition (in Helios) ? [message #639811 is a reply to message #639801] Wed, 17 November 2010 17:13 Go to previous messageGo to next message
I followed this : http:// www.vogella.de/articles/EclipseDataToolsPlatform/article.htm l
... and installed only "Data Tools Platform Enablement Extender SDK".
It's OK now : i can create a new Driver Definition (to a PostgreSQL database, for instance).
But something is still odd... :
In Helios, it's necessary to do this, if you want to have all vendors filters in Driver Definition popup.
In Galileo, it wasn't necessary : all vendors filters were already available.
Why ?
Any idea ?
Re: Where are "vendor filter" in Driver Definition (in Helios) ? [message #639959 is a reply to message #639811] Thu, 18 November 2010 09:40 Go to previous message
Ok, I'm confused...
What did you use as your base Eclipse install? Base Helios? If you
install the bigger distribution (Java EE or JEE) it has all the bits
installed by default.
And then what did you choose to install from the DTP zip or update site?
--Fitz
SylvainR wrote:
> I followed this :
> http://www.vogella.de/articles/EclipseDataToolsPlatform/arti cle.html
> available.
> Why ?
> Any idea ?
Previous Topic:UI Table for editing schema/data
Next Topic:Semicolon problem on multiple inserts
Current Time: Wed Jul 23 19:36:26 EDT 2025
Powered by FUDForum. Page generated in 1.04552 seconds
