Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT.TRANSPARENT on linux?
SWT.TRANSPARENT on linux? [message #639794] Wed, 17 November 2010 14:44 Go to next message
We are developing an Eclipse based RCP app using SWT (3.5.x) for component rendering. When instantiating our Composite instances, we set (among other bits) the SWT.TRANSPARENT style bit.
When viewing on Windows (dev environment), the style performs as advertised, providing true transparency.
When deployed to Linux (SLES 10), the Composite is not transparent, and paints its background opaque.
Does SWT on Linux support the SWT.TRANSPARENT style? Are there certain X config settings that are needed to enable transparency on Linux?
Re: SWT.TRANSPARENT on linux? [message #639966 is a reply to message #639794] Thu, 18 November 2010 09:57 Go to previous message
No, this is not currently expected to work on some platforms, it's an
incomplete implementation. This is indicated in the style bit's javadoc,
though it would have been better if the style had never been released, in
order to eliminate ambiguity caused by users seeing it work in some
contexts.
The feature request to complete this style's implementation is
https://bugs.eclipse.org/bugs/show_bug.cgi?id=295014 . This is not on the
Eclipse 3.7 plan, so it's not clear if/when this will happen.
Grant
"Jarrad" <gilesj@us.ibm.com> wrote in message
news:ic1b2d$g51$1@news.eclipse.org...
Previous Topic:label length within form toolkit
Next Topic:Nesting SWT Tables
Current Time: Sat Jul 26 19:10:22 EDT 2025
Powered by FUDForum. Page generated in 0.03949 seconds
