Home » Modeling » Epsilon » [Eugenia] Phantom nodes
[Eugenia] Phantom nodes [message #588572] Thu, 22 April 2010 12:37 Go to next message
Originally posted by: Juan.deLara.uam.es
I tried to decorate a class which contains instances of
such class with the phantom attribute, but did not manage
to make it work. In the example on the website, a slightly
different situation is shown, where the container and containee
are two different classes. In my case they are the same class,
is that compatible with the phantom attribute?
thanks,
cheers,
j.
Re: [Eugenia] Phantom nodes [message #639733 is a reply to message #588572] Wed, 17 November 2010 10:51 Go to previous messageGo to next message
hi
i have the same problem, so i just revive this thread...
what i have is basically
classA -> gmf.diagram
classB -> gmf.node (phantom)
classB.nestedClassB(0...*) -> gmf.link
so elements of classB can be both contained in classA or classB, and when they're contained in classB i want to show them as external (phantom) nodes.
when i try to generate the *models in the first step, i get the error message
"Called feature domainMetaElement on undefined object (463:69)"
so my question is, is it possible to use phantom nodes in this way or not?
cheers
marco
Re: [Eugenia] Phantom nodes [message #639761 is a reply to message #639733] Wed, 17 November 2010 12:15 Go to previous messageGo to next message
Hi Marco,
I believe we took this offline with Juan. I really should have updated
the bug report (https://bugs.eclipse.org/bugs/show_bug.cgi?id=310248)
with the resolution but this somehow fell through the cracks. As a
result, I can't quite remember what the outcome was after all this time
:) Could you please attach a minimal metamodel that reproduces this so
that I can have (another) look?
Dimitris
mkranz wrote:
> hi
> (phantom) nodes.
> message
> cheers
> marco
Re: [Eugenia] Phantom nodes [message #640520 is a reply to message #639761] Mon, 22 November 2010 07:22 Go to previous messageGo to next message
hi dimitris
seems i'm not allowed to attach things to a post...
i'll send you the example via email. it's basically the example i described in my first post.
hope you remember the solution.
cheers
marco
Re: [Eugenia] Phantom nodes [message #641135 is a reply to message #640520] Wed, 24 November 2010 06:24 Go to previous messageGo to next message
hi dimitris
did you get my mail?
i just saw that there is a new email-adress around (epsilon.devs gmail com), should i use this one instead?
cheers
marco
Re: [Eugenia] Phantom nodes [message #641143 is a reply to message #641135] Wed, 24 November 2010 07:04 Go to previous messageGo to next message
Hi Marco,
I have, but things have been quite hectic in the last few days and I
haven't had a chance to look at this yet. I'll try to look into this
later on today and get back to you.
Dimitris
On 24/11/2010 11:24, mkranz wrote:
> hi dimitris
> did you get my mail? i just saw that there is a new email-adress around
> cheers
> marco
Re: [Eugenia] Phantom nodes [message #641171 is a reply to message #641143] Wed, 24 November 2010 08:26 Go to previous messageGo to next message
hi dimitris
no need to stress yourself (is this good english? Smile), i'll be away until next monday anyway, so take your time.
i just wanted to make sure you got the mail.
cheers
marco
Re: [Eugenia] Phantom nodes [message #641321 is a reply to message #641171] Wed, 24 November 2010 18:02 Go to previous messageGo to next message
Hi Marco,
Thanks for letting me know (yes, that's perfectly good English AFAIK :) ).
Dimitris
mkranz wrote:
> hi dimitris
> no need to stress yourself (is this good english? :)), i'll be away
> cheers
> marco
Re: [Eugenia] Phantom nodes [message #642444 is a reply to message #641321] Wed, 01 December 2010 06:22 Go to previous messageGo to next message
hi dimitris
any news on this one?
cheers
marco
Re: [Eugenia] Phantom nodes [message #643542 is a reply to message #642444] Tue, 07 December 2010 05:35 Go to previous messageGo to next message
hi dimitris
ok my fault, i just recently installed the latest version of epsilon, and did not try it again... sorry! Embarrassed
nevertheless, now i found out that my original problem isn't solved by using phantom nodes... Confused
as in my example, i have a classB that can be contained in both classA (the canvas) and classB instances. so if you create a new classB instance (node) in the diagram, it is created as a containment of the classA canvas. if you now have 2 classB nodes in the diagram and connect them with the connector (stating that one is contained in the other one), the one contained in the other classB instance is removed from the canvas (what makes sense, since it is no longer contained in the classA instance but now in the other classB instance).
long story short, i thought by making classB nodes phantoms i could prevent them from disappearing, but it doesn't work... Sad
i guess this is not related to eugenia but is a gmf problem, right?
cheers
marco
Re: [Eugenia] Phantom nodes [message #643607 is a reply to message #643542] Tue, 07 December 2010 10:50 Go to previous messageGo to next message
Hi Marco,
No worries :) Yes, this is a GMF issue which - I believe - can only be
solved by modifying (some part of) the generated code.
Dimitris
mkranz wrote:
> hi dimitris
> and did not try it again... sorry! :blush:
> using phantom nodes... :? as in my example, i have a classB that can be
> instance).
> prevent them from disappearing, but it doesn't work... :( i guess this
> cheers
> marco
Re: [Eugenia] Phantom nodes [message #839841 is a reply to message #643607] Mon, 09 April 2012 05:21 Go to previous message
hi Dimitris,
Could you tell me what part of the generated GMF code I have to change to make this work? Or could you tell me where I can find more information on this bug?
Oskar
Previous Topic:Bug in org.eclipse.epsilon.evl.emf.validation
Next Topic:Inheritance in rules [SOLVED]
Current Time: Sat Jul 26 08:37:35 EDT 2025
Powered by FUDForum. Page generated in 0.08170 seconds
