Home » Eclipse Projects » Eclipse Platform » [ANN] oXygen XML Editor available as closely integrated eclipse plugin
[ANN] oXygen XML Editor available as closely integrated eclipse plugin [message #51086] Wed, 28 May 2003 03:54 Go to next message
Originally posted by: george.sync.ro
A closely integrated version of oXygen is available as oXygen 2.0.2 beta
for Eclipse from
http://www.oxygenxml.com/download.html
Not all the oXygen features are covered (they will be soon) but the core
points are there:
- support for XML, XSL, XSD and DTD documents
- validation and well formed checks reporting problems as problem
markers
- content assistant driven by XML Schema, DTD or the document structure
itself
- syntax coloring
- transformation support allowing both XSLT and FOP
- XPath support allows evaluation of XPath expressions
- format and indent the documents
Feedback more than welcome.
Thank you,
George
George Cristian Bina mailto:george@sync.ro
COO - sync.ro
Phone +40-(0)251-461480, +40-(0)251-461481
Fax +40-(0)251-461482
Mobile +40-(0)723-224067
SyncRO Soft srl, Bd N. Titulescu 170, Craiova, 1100 - Romania
http://www.sync.ro
<oXygen/> XML Editor - http://www.oxygenxml.com/
Re: [ANN] oXygen XML Editor available as closely integrated eclipse plugin [message #51547 is a reply to message #51086] Wed, 28 May 2003 06:44 Go to previous messageGo to next message
erm, what does this plugin do? I dont see syntax coloring on my XML, DTD
or XSD files. The configuration dialog still seems to be swing, and is
not integrated in the eclipse preferences
> for Eclipse from
> points are there:
> markers
> itself
> - syntax coloring
> Thank you,
> George
> COO - sync.ro
> http://www.sync.ro
Re: [ANN] oXygen XML Editor available as closely integrated eclipseplugin [message #51615 is a reply to message #51547] Wed, 28 May 2003 07:28 Go to previous messageGo to next message
Thanks for letting us know about this problem. All the tests we have done
were on configurations were oXygen was also installed and we were not able
to spot the syntax coloring initialization problem. We will fix this. In
the meanwhile you can put the http://www.oxygenxml.com/update/options file
in your user home directory under a folder named com.oxygenxml and the
colors will appear (this file should be named "options" and it is a
properties file). Alternativelly you can start once any of the other
distributions of oXygen and the options file will be created automatically.
There are 2 swing remaninings, the oXygen options dialog and the
transformer configuration dialog. The eclipse relevant options from the
first one will be moved to eclipse preferences - this is work in progress
and is about 80% ready. The other one will be also re-written in SWT.
Best Regards,
George
Re: [ANN] oXygen XML Editor available as closely integrated eclipseplugin [message #51921 is a reply to message #51615] Wed, 28 May 2003 10:21 Go to previous messageGo to next message
We updated the kit fixing the syntax coloring initialization.
Thanks again for reporting this problem,
George
COO - sync.ro
http://www.sync.ro
Re: [ANN] oXygen XML Editor available as closely integrated eclipseplugin [message #63971 is a reply to message #51921] Thu, 05 June 2003 11:24 Go to previous message
A new release of oXygen 2.0.2 beta3 for Eclipse is available for download
from http://www.oxygenxml.com/download.html . The zip contains a 30 day
trial license so no special registration is needed to try it out. For what's
new you can check:
http://www.oxygenxml.com/forum/viewtopic.php?t=80
Thank you,
George
COO - sync.ro
http://www.sync.ro
Previous Topic:Register and ImageLoader
Next Topic:ant custom task: init() isn't called and getProject() returns null
Current Time: Sun Jul 20 06:22:48 EDT 2025
Powered by FUDForum. Page generated in 0.03582 seconds
