Home » Archived » BIRT » Exception in reading temporary file for caching result rows.
Exception in reading temporary file for caching result rows. [message #639670] Wed, 17 November 2010 07:26 Go to next message
I have created a Report with two masterpages (first and layout) and on a Grid I have set the masterpage to layout.
The difference is that the masterpage first do not have a footer and the masterpage layout have a picture in the footer.
When I try to create a pdf of my report (with separate run and render methodes) I get the error
Does anyone know something about this error?
The reason is to set the property masterpage but I don't know where the error comes from and what does it mean.
Thanks for your help.
pigargo
Re: Exception in reading temporary file for caching result rows. [message #639703 is a reply to message #639670] Wed, 17 November 2010 09:07 Go to previous message
Can you give some more detail on how you are running it? With the API
or the Viewer? Can you post the report and the version of BIRT you are
using?
Jason
On 11/17/2010 7:26 AM, pigargo wrote:
> Hello,
> pigargo
Previous Topic:Generating a report from command line
Next Topic:Failing when deployed (Websphere)
Current Time: Wed Jul 23 12:12:13 EDT 2025
Powered by FUDForum. Page generated in 0.24548 seconds
