Home » Modeling » M2T (model-to-text transformation) » [Xpand] Template could not be found
[Xpand] Template could not be found [message #639469] Tue, 16 November 2010 11:56 Go to next message
Hello everybody,
I created a simple Xtext project and exported its three generated projects as plugins. Then, I created a Java project which adds the Xtext Nature of my plugin.
I'm able to use Xtext programmatically after loading the model this way:
private Model loadModel() {
		new org.eclipse.emf.mwe.utils.StandaloneSetup().setPlatformUri("../");
		Injector injector = new TGStandaloneSetup().createInjectorAndDoEMFRegistration();
		XtextResourceSet resourceSet = injector.getInstance(XtextResourceSet.class);
		resourceSet.addLoadOption(XtextResource.OPTION_RESOLVE_ALL, Boolean.TRUE);
		Resource resource = resourceSet.getResource(
			    URI.createURI("platform:/resource/JavaX/src/example.tg"), true);
		return (Model) resource.getContents().get(0);
Now, I would like to generate code from my model using XpandFacade. This is my code for that:
Model model = loadModel();
        // XPand
        String outputFolder = "output";
        OutputImpl output = new OutputImpl();
        Outlet outlet = new Outlet(outputFolder);
        outlet.setOverwrite(true);
        output.addOutlet(outlet);
        EmfMetaModel metaModel = new EmfMetaModel(TGPackage.eINSTANCE);
        XpandExecutionContextImpl executionContext = new XpandExecutionContextImpl(output, null);
        executionContext.registerMetaModel(metaModel);
        XpandFacade facade = XpandFacade.create(executionContext);
        facade.evaluate("templates::Template::main", model.getTables().get(0));
but Im getting the next exception
Exception in thread "main" EvaluationException : No Definition templates::Template::main for tG::Table could be found!
	Internal error : element was null
That template is in the package src.templates of the org.xtext.example.tg.generator project (exported as a plugin).
I do not know if the template should be there. The other thing is that while I am able to import the org.xtext.example.tg project classes, I can't do that with org.xtext.example.tg.generator classes.
I would appreciate any help.
Thank you very much.
Re: [Xpand] Template could not be found [message #639541 is a reply to message #639469] Tue, 16 November 2010 15:20 Go to previous message
are you sure the template uses the emf metamodel? xtext by default uses javabeansmetamodel for the xpand generator project.
~Christian
[Updated on: Tue, 16 November 2010 15:20] by Moderator
Previous Topic:[Acceleo] ESE2010 Tutorial
Next Topic:Incremental Gen. throws nullPointer
Current Time: Fri Jul 18 21:48:05 EDT 2025
Powered by FUDForum. Page generated in 0.06089 seconds
