Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Re: SWT control preferred, minimum and maximum sizes
Re: SWT control preferred, minimum and maximum sizes [message #639263] Mon, 15 November 2010 13:50 Go to next message
I am facing an issue related to the minimum size of a control. I'm
probably overlooking an easy solution. The problem is the following: I
have a ScrolledComposite that displays a particular composite A. I
would like to have the scrollbars visible only if the visible area is
smaller than the mininum size of the composite A. How can I do that? I
am using the following method right now:
sc.setContent(compositeA);
sc.setExpandHorizontal(true);
sc.setExpandVertical(true);
sc.setMinWidth(...);
sc.setMinHeight(...);
The problem is: how to get the minimum size of the composite A? I tried
to use computeSize(0, 0) but the resulted size is also 0. If I use
computeSize(SWT.DEFAULT, SWT.DEFAULT), then it works but fails in
certain particular case: if composite A contains several buttons and a
table, I would like to know its minimum size so the scroll bars of the
Scrolled Composite only appears if the table inside the composite A
cannot shrink anymore.
Any help is welcome, thanks.
Jean
On 2006-04-20 06:34:57 -0700, Veronika Irvine said:
> There is currenlty no way to determine the minimum or maximum size.
> Calling computeSize(0, 0) will give the size needed to show a control
> with client area of (0,0) - that is it will add on all neccessary trim.
> For example, in a TabFolder the tabs and the border are considered
> trim.
> "Alexander Mitin" <Alexander.Mitin@gmail.com> wrote in message
> news:95f7ac89d47840ea3876e46ffb1b5185$1@www.eclipse.org...
>> Hello.
>> Consider the following SWING code:
>> final JTextField textField = new JTextField();
>> textField.setText("button");
>> // skip some code
>> Dimension preferredSize = button.getPreferredSize();
>> Dimension minimumSize = button.getMinimumSize();
>> Dimension maximumSize = button.getMaximumSize();
>> System.out.println("preferredSize = " + preferredSize);
>> System.out.println("minimumSize = " + minimumSize);
>> System.out.println("maximumSize = " + maximumSize);
>> This gives me the result: "preferredSize =
>> java.awt.Dimension[width=41,height=20]
>> minimumSize = java.awt.Dimension[width=11,height=20]
>> maximumSize = java.awt.Dimension[width=2147483647,height=2147483647]"
>> How I do the same thing in SWT: determine the minimum, maximum and
>> preferred sizes of SWT control? Yes, I can call
>> textControl.computeSize(SWT.DEFAULT, SWT.DEFAULT, true) for preferred
>> size but what about minimum and maximum control sizes? If I call
>> textControl.computeSize(0, 0, true) (expecting the control to compute
>> its minimum size) that gives me strange result. Is there any generic
>> methods to determine minimum and maximum size of SWT control which I've
>> missed? Or how can I determine the exact minimum and maximum sizes?
Re: SWT control preferred, minimum and maximum sizes [message #639384 is a reply to message #639263] Tue, 16 November 2010 05:47 Go to previous messageGo to next message
composite.computeSize(SWT.DEFAULT, SWT.DEFAULT) gives the preferred size of the composite. And you can use this to set the min size for the control in the ScrolledComposite. I'm not sure if I understood "table inside the composite A cannot shrink anymore" correctly. I assumed it means when the table items are not fully visible.
Here is a simple snippet with Table and Buttons inside a ScrolledComposite that works for me.
public class Snippet {
public static void main (String [] args)
Display display = new Display ();
Shell shell = new Shell (display);
shell.setLayout(new FillLayout());
final ScrolledComposite c1 = new ScrolledComposite(shell, SWT.BORDER | SWT.H_SCROLL | SWT.V_SCROLL);
final Composite composite = new Composite(c1, SWT.BORDER);
composite.setLayout(new GridLayout(4, false));
for (int i = 0; i < 20; i++) {
Button button = new Button(composite, SWT.PUSH);
button.setLayoutData(new GridData(SWT.BEGINNING, SWT.CENTER, false, false));
button.setText("button" + i);
Table table = new Table(composite, SWT.SINGLE|SWT.NO_SCROLL);
table.setLayoutData(new GridData(SWT.FILL, SWT.FILL, true, true));
table.setLinesVisible(true);
table.setHeaderVisible(true);
TableItem tableItem= new TableItem(table, SWT.NONE);
tableItem.setText(0, "item"+i);
for (int i = 0; i < table.getColumnCount(); i++) {
table.getColumn(i).pack();
composite.pack();
c1.setExpandHorizontal(true);
c1.setExpandVertical(true);
c1.setContent(composite);
c1.setMinSize(composite.computeSize(SWT.DEFAULT, SWT.DEFAULT));
shell.pack();
shell.open ();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
If a particular case is not working for you , can you modify the above snippet to show the failing case?
Re: SWT control preferred, minimum and maximum sizes [message #639518 is a reply to message #639384] Tue, 16 November 2010 13:59 Go to previous messageGo to next message
----------------19037194461706782197
Content-Type: text/plain; charset=iso-8859-1; format=flowed
Thanks for your answer. If I run your snippet, I can see that the table
height will grow as I add more lines and the scrolledcomposite adjusts
itself to be able to scroll the complete height of the table. That's
fine. However, I'm looking at something a bit different: let's say I
want to display only 10 lines of the table at a time and have the table
show its scroll bars. There is maybe a nicer way of doing that but so
far I have to manually set the size on the composite (see code below)
which is something I would rather avoid. This is where I'm looking at
getting the minimum size of the table so I can set the size without
having to rely on constant value. I'm trying to get the answer to the
question "what is the minimum size a component needs to have to display
itself completely?".
Here is the code to illustrate what I want to achieve.
public static void main (String [] args) {
Table table = new Table(composite, SWT.SINGLE|SWT.V_SCROLL|SWT.H_SCROLL);
for (int i = 0; i < 200; i++) {
//composite.pack();
composite.setSize(200, 300);
//c1.setExpandVertical(false);
//shell.pack();
shell.open ();
display.dispose ();
/Jean
On 2010-11-16 03:17:27 -0800, Lakshmi Shanmugam said:
> means when the table items are not fully visible. Here is a simple
> for me.
> composite.pack();
> shell.pack();
> shell.open ();
> display.dispose ();
Content-Type: text/html; charset=iso-8859-1
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<meta http-equiv="Content-Style-Type" content="text/css">
<title></title>
<meta name="Generator" content="Cocoa HTML Writer">
<meta name="CocoaVersion" content="1038.35">
<style type="text/css">
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; line-height: 15.0px; font: 12.0px Helvetica}
p.p2 {margin: 0.0px 0.0px 0.0px 0.0px; line-height: 15.0px; font: 12.0px Helvetica; min-height: 14.0px}
p.p3 {margin: 0.0px 0.0px 0.0px 0.0px; font: 11.0px Monaco}
p.p4 {margin: 0.0px 0.0px 0.0px 0.0px; font: 11.0px Monaco; min-height: 15.0px}
p.p5 {margin: 0.0px 0.0px 0.0px 0.0px; font: 11.0px Monaco; color: #559173}
p.p6 {margin: 0.0px 0.0px 0.0px 12.0px; line-height: 14.0px; font: 12.0px Helvetica; color: #1a0090}
p.p7 {margin: 0.0px 0.0px 0.0px 12.0px; line-height: 14.0px; font: 12.0px Helvetica; color: #1a0090; min-height: 14.0px}
span.s1 {color: #8e0068}
span.s2 {color: #2900c9}
span.s3 {color: #4c00fc}
span.s4 {color: #000000}
span.Apple-tab-span {white-space:pre}
</style>
</head>
<body>
<p class="p1">Hi,</p>
<p class="p2"><br></p>
<p class="p1">Thanks for your answer. If I run your snippet, I can see that the table height will grow as I add more lines and the scrolledcomposite adjusts itself to be able to scroll the complete height of the table. That's fine. However, I'm looking at something a bit different: let's say I want to display only 10 lines of the table at a time and have the table show its scroll bars. There is maybe a nicer way of doing that but so far I have to manually set the size on the composite (see code below) which is something I would rather avoid. This is where I'm looking at getting the minimum size of the table so I can set the size without having to rely on constant value. I'm trying to<span class="Apple-converted-space">
Re: SWT control preferred, minimum and maximum sizes [message #639723 is a reply to message #639518] Wed, 17 November 2010 10:28 Go to previous message
To have the table show a fixed number of items and scrollbars you could try to control the height of the table directly using the GridData.heightHint.
GridData layoutData = new GridData(SWT.FILL, SWT.FILL, true, true);
table.setLayoutData(layoutData);
int ht = (table.getItemHeight() * 10) + table.getHeaderHeight();
layoutData.heightHint = table.computeSize(SWT.DEFAULT, ht).y;
Previous Topic:CheckBox button in a TableColumn
Next Topic:Accessibility issue in a tableViewer
Current Time: Sat Jul 19 01:06:11 EDT 2025
Powered by FUDForum. Page generated in 0.26080 seconds
