Home » Archived » BIRT » Problem BIRT and WindowBuilder Pro
Problem BIRT and WindowBuilder Pro [message #638483] Thu, 11 November 2010 08:08 Go to next message
My instalation of Eclipse is for develpment report (BIRT) and I have installed WIndowBuilder Pro. I want to make an UI for access to reports.
Since I installed WB Pro, BIRT don´t work. The preview is blank and when I try a report in the internal browser, eclipse is thinking in a blank frame, but the report don't make it.
I installed GWT designer, Swing designer and SWT designer, all packages. My O.S. is Windows Vista and Eclipse es Version Helios (and BIRT 2.6.1).
I have gone uninstall one application for one and BIRT don' work until all packages were uninstalled.
Do you know why is this? Any idea?
Thanks. Grettings from Spain.
Re: Problem BIRT and WindowBuilder Pro [message #638564 is a reply to message #638483] Thu, 11 November 2010 11:07 Go to previous messageGo to next message
Agustin,
I just tried this and did not get an issue. What I did is started with
the birt all in one download eclipse-reporting-helios-SR1-win32 and then
used the update manager to add the WB Pro. I added all the features
from WB Pro and it worked well.
Jason
Re: Problem BIRT and WindowBuilder Pro [message #638692 is a reply to message #638564] Fri, 12 November 2010 03:45 Go to previous messageGo to next message
Well, I've inspected .log file and I see nothing.
I've repeated the instalation in linux with a simple report and it the same. But I realize that blank screen isn't frozen but eclipse run very very slow.
Re: Problem BIRT and WindowBuilder Pro [message #638770 is a reply to message #638692] Fri, 12 November 2010 09:26 Go to previous messageGo to next message
Did you start with the BIRT allinone download?
Jason
On 11/12/2010 3:45 AM, agustin wrote:
> Well, I've inspected .log file and I see nothing. I've repeated the
> Thanks
Re: Problem BIRT and WindowBuilder Pro [message #639159 is a reply to message #638770] Mon, 15 November 2010 08:01 Go to previous messageGo to next message
Yes, i did.
I installed the packages both Windows XP and Linux (Debian) in two diferents machines.
Re: Problem BIRT and WindowBuilder Pro [message #639229 is a reply to message #639159] Mon, 15 November 2010 11:08 Go to previous messageGo to next message
Can you open a bug for this? I can not reproduce the issue.
Jason
On 11/15/2010 8:01 AM, agustin wrote:
> Yes, i did.
> diferents machines.
Re: Problem BIRT and WindowBuilder Pro [message #639401 is a reply to message #639229] Tue, 16 November 2010 07:32 Go to previous messageGo to next message
Ok. Bug 330339 Submitted
Thank for your help.
Re: Problem BIRT and WindowBuilder Pro [message #639484 is a reply to message #639401] Tue, 16 November 2010 12:29 Go to previous message
Thanks for submitting.
Previous Topic:Accessing data in previous row
Next Topic:Implement own DataCube
Current Time: Sat Jul 26 10:40:23 EDT 2025
Powered by FUDForum. Page generated in 0.28253 seconds
