Home » Eclipse Projects » Eclipse Platform » Register a PreferencePage at runtime?
Register a PreferencePage at runtime? [message #639106] Mon, 15 November 2010 05:37 Go to next message
I want to register and create preference pages at runtime, wthout use of the 'org.eclipse.ui.preferencePages.page' Extensionpoint.
Is this possible? and if yes, how?
Jan
Re: Register a PreferencePage at runtime? [message #639238 is a reply to message #639106] Mon, 15 November 2010 12:42 Go to previous messageGo to next message
You can instantiate your own
org.eclipse.jface.preference.PreferenceDialog.PreferenceDial og(Shell,
PreferenceManager) with your own preference pages.
it won't be hooked up to the standard workbench preference system,
though, which is controlled by a subclass. See
org.eclipse.ui.internal.dialogs.WorkbenchPreferenceDialog.cr eateDialogOn(Shell,
String)
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Register a PreferencePage at runtime? [message #734597 is a reply to message #639238] Sat, 08 October 2011 16:18 Go to previous message
Paul Webster wrote on Mon, 15 November 2010 12:42
String)
PW
Paul Webster
Paul,
Can you take a look at this "related" post?
http://www.eclipse.org/forums/index.php/t/237702/
Maybe you can explain that behavior.
Thanks.
Previous Topic:Adding a predefined popup menu to a TreeViewer without an id
Next Topic:JFace PreferenceDialog: Widget Disposed exception the second time
Current Time: Tue Jul 22 23:57:17 EDT 2025
Powered by FUDForum. Page generated in 0.08731 seconds
