Home » Modeling » EMF » [CDO] generating dawn genmodel([CDO] generating dawn genmodel)
[CDO] generating dawn genmodel [message #638791] Fri, 12 November 2010 10:28 Go to next message
I try to generate a .dawngenmodel from an ecore genmodel. But the action leads to a FileNotFoundException. The file not found is the file the action is supposed to generate.
If I look at the dawn code in
GenerateDawnGenModelAction.java:205 it tries to load the resource the following way:
resourceSet.getResource(uri, true);
which looks ok (as far as I understand the code).
ideas?
- Ronald
Re: [CDO] generating dawn genmodel [message #638867 is a reply to message #638791] Fri, 12 November 2010 14:35 Go to previous messageGo to next message
Hi Ronald,
could you provide the complete stack trace? This could make it easier to
judge what happens. ;)
But one question in advance:
Are you trying the generate the extension for a tree-based EMF editor or
for a GMF editor?
Martin
Am 12.11.2010 16:28, schrieb Ronald Krijgsheld:
> following way:
> ideas?
> - Ronald
Re: [CDO] generating dawn genmodel [message #638869 is a reply to message #638867] Fri, 12 November 2010 15:20 Go to previous messageGo to next message
Hi Martin,
below the stacktrace.
I'm not really sure if I understand your question on what I'm trying to generate. I simply right click on a genmodel to generate the corresponding dawngemodel. So, I suppose that can only generate a dawn genmodel for editor support. Later, we'll need a CDO enabled GMF editor or a CDO enabled Graphiti editor.
But first I just wanted to see what code is generated and how I need to change my existing code to make use of the generated dawn code.
First things first Smile
Ronald
Caused by: org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedException: java.io.FileNotFoundException: C:\projects\systemize\newsvn\pmw\trunk\com.cmic.pmw.foundati on\model\Foundation.dawngenmodel
pecified)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:315)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:274)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:397)
at org.eclipse.emf.cdo.dawn.codegen.actions.GenerateDawnGenMode lAction.getDawnGenModelResource(GenerateDawnGenModelAction.j ava:205)
at org.eclipse.emf.cdo.dawn.codegen.actions.GenerateDawnGenMode lAction.access$3(GenerateDawnGenModelAction.java:201)
at org.eclipse.emf.cdo.dawn.codegen.actions.GenerateDawnGenMode lAction$1.run(GenerateDawnGenModelAction.java:80)
at org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
Caused by: java.io.FileNotFoundException: C:\projects\systemize\newsvn\pmw\trunk\com.cmic.pmw.foundati on\model\Foundation.dawngenmodel (The system cannot find the file specified)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(Unknown Source)
at org.eclipse.emf.ecore.resource.impl.FileURIHandlerImpl.creat eInputStream(FileURIHandlerImpl.java:105)
at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterIm pl.createInputStream(ExtensibleURIConverterImpl.java:301)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1254)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:255)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:270)
... 5 more
Re: [CDO] generating dawn genmodel [message #638988 is a reply to message #638869] Sun, 14 November 2010 08:11 Go to previous messageGo to next message
Hi Ronald,
comments below.
Am 12.11.2010 21:20, schrieb Ronald Krijgsheld:
> Hi Martin,
Not exactly. Dawn currently supports generating extensions for GMF
editors and EMF (tree-based) editors, although the latter is still work
in progress.
To gain the required information the Dawn GenModel decorates the other
generator models. So the Dawn GenModel can hold a reference to the EMF
genmodel (*.genmodel) and/or the GMF genmodel (*.gengmf).
To add the GMF related information the context menu on the *.gmfgen must
be used invoked whereas you must use the context menu entry in the
*genmodel to add the information for the tree-based editor. That's why I
asked what kind of editor extension you tried to generated.
I admit that this handling is not perfect yet. Soon, I am going to
create a wizard which will make the workflow a bit more understandable.
But however. There was indeed a bug in the creation procedure which is
now fixed. It should work with the next build. If not, please let me know.
Martin
> change my existing code to make use of the generated dawn code. First
> things first :)
> Ronald
> pecified)
> specified)
> ceImpl.java:1254)
> ... 5 more
Re: [CDO] generating dawn genmodel [message #639023 is a reply to message #638988] Sun, 14 November 2010 15:33 Go to previous messageGo to next message
Martin,
Thanks, I wil try it this week (probably monday/tuesday)
Ronald
Re: [CDO] generating dawn genmodel [message #639049 is a reply to message #638988] Mon, 15 November 2010 01:05 Go to previous messageGo to next message
Am 14.11.2010 14:11, schrieb Martin Flügge:
> Hi Ronald,
> comments below.
>> Hi Martin,
> in progress.
I wonder if it's a good design to add dependencies on various third party technologies (GMF, Grafiti, ...) to a single Dawn plugin. Does that mean that a user who only wants to generate a CDO'ified EMF tree editor has to install GMF?
Cheers
/Eike
http://www.esc-net.de
> Cheers,
> Martin
>> things first :)
>> Thanks,
>> Ronald
>> pecified)
>> specified)
>> ceImpl.java:1254)
>> ... 5 more
Re: [CDO] generating dawn genmodel [message #639097 is a reply to message #639049] Mon, 15 November 2010 04:56 Go to previous message
Currently, yes. But the integration of EMF is still in progress and I will use this integration to create a cleaner separation between the runtime/godegen core facilities and the other frameworks.
Martin
Previous Topic:Re: [Teneo/Hibernate] "javax.persistence" and bundles from elver.org update site
Next Topic:Is there a reason that there isn't an EMFObservableValueEditingSupport class?
Current Time: Sat Jul 26 23:14:56 EDT 2025
Powered by FUDForum. Page generated in 0.05724 seconds
