[Tree] unwanted automatic SelectionEvents [message #637713] |
Mon, 08 November 2010 09:07  |
I have a Tree constructed with the following style:
SWT.SINGLE | SWT.CHECK | SWT.BORDER | SWT.H_SCROLL | SWT.V_SCROLL
| SWT.FULL_SELECTION | SWT.VIRTUAL
and I added a SelectionListener on it.
I am working with an Eclipse 3.4.2 target on a 32bit WinXP.
The problem is that I get automatic SelectionEvents when I for example remove a selected (blue background) row in the tree calling MyTreeViewer.remove(Object). Looking deeper into the stack trace, I see that the event is constructed and scheduled by Tree.wmNotifyChild() for the cases:
case OS.TVN_SELCHANGEDA:
case OS.TVN_SELCHANGEDW:
The problem is that I cannot differentiate between those "automatic" events and the "real" selection events the user fired by clicking with the mouse or navigating with the keyboard in the Tree. And I just want to react only to those explicit "user"-fired selection events.
Is there a way to turn off those "automatic" events? Or to differentiate between them?
(like implementing a Strategy or something?)
Re: [Tree] unwanted automatic SelectionEvents [message #638860 is a reply to message #638784] |
Fri, 12 November 2010 14:26  |
Grant Gayed wrote on Fri, 12 November 2010 10:05 | Hi, sorry for the late reply,
There isn't a way to differentiate between these cases by looking at the
event. This is one of those rare cases where an event gets sent for a
programmatic change, because the selection change could be a side effect of
doing something different (eg.- disposing a TreeItem that has selected child
items). I think the only way to handle this in your case is to set a
boolean flag around your call to remove() that indicates that selection
change events received are a result of the remove() call. I know this is a
bit ugly, but I don't think there's another option (this is why most
programmatic changes do not cause events to be sent).
Grant
My use case is a bit more complicated than that:
I reimplemented the PostSelection behaviour because it is not supported (yet) by Eclipse RAP. I mention that I develop a single sourced application which has a rich client version (Eclipse RCP) and a web version (RAP). By PostSelection behaviour I mean that I only schedule my selection actions when the SelectionListener is notified, and after a certain delay I run them or ignore them if other selection events were fired in the meantime (use case: changing selection quickly with the keyboard arrow up/down should only perform the action for the last row I stopped on and ignore the others).
And I am not quite sure that I shall be able to cleanly sync that with your semaphore solution.
I already thought of a semaphore myself, but more precise than a boolean flag:
to record the timestamps before and after .remove() and ignore the events scheduled during this time. But I found 2 problems to this approach:
1) event.time is not supported in Eclipse RAP
2) Even in RCP, I have no idea what the value of event.time is. It's not the number of millis from 1.1.1970, like all other Java dates are. The value is given by Display.getlastEventTime(), which seems to be platform specific:int getLastEventTime () {
return OS.IsWinCE ? OS.GetTickCount () : OS.GetMessageTime ();
} Any Idea of how could I transform that into a Java date?
[Updated on: Fri, 12 November 2010 14:28] by Moderator
FUDForum. Page generated in 0.06720 seconds
