| Problem Installing VE plugin [message #58586] | Thu, 02 September 2004 06:24  |  |
| Eclipse User  |  |  |  |  | Originally posted by: mauro.morici.welcometechnology.it
 Hi everybody.
 I am having troubles installing the VE plugin. I am using Eclipse 3.0
 (Build id: 200402122000 on a Win2K system) and I downloaded EMF 3.0, GMF
 2.0 and VE 1.0M2.
 After unzipping them to the plugin directory and launching eclipse the
 Visual Class is not available in the new menu.
 I know it's a newbie question but I couldn't find any topic about it in
 help or the web.
 TIA
 Mauro
| Re: Problem Installing VE plugin [message #58709 is a reply to message #58684] | Sat, 04 September 2004 13:00   |  |
| Eclipse User  |  |  |  |  | Originally posted by: user.domain.invalid
 Mauro wrote:
 > Rich Kulp wrote:
 >>IS Buildid 2004021222000 a typo? That build is so old it is not
 >>supported anymore. To use 1.0M2 you should be using Eclipse 3.0 Release
 >>version, GEF 3.0.0 released version, and EMF 2.0.0 released version.
 > No it should be a release version. By the way I don't know what is a typo.
 > Mauro
 a typo is a typing error.  your build id 2004021222000 should be a year,
 2004, followed by a month, 02 or February, followed by a day of the
 month, 12, followed by the time in hhmm format, hours = 22 and minutes =
 00, but you have another 0.  which digit is the extra digit?
 if you expect support, download and install the following:
 Eclipse build eclipse-SDK-3.0
 EMF Release Build 2.0.0 sometimes called build R200406280827
 GEF Build 3.0
 VE Stable Build: 1.0M2
 norwood sisson
| Re: Problem Installing VE plugin [message #64162 is a reply to message #63853] | Mon, 04 October 2004 11:06  |  |
| Eclipse User  |  |  |  |  | Originally posted by: richkulp.us.NO_SPAM.ibm.com
 You don't unzip INTO the eclipse directory, you unzip into the directory
 eclipse is in. I.e.
 d:\xyz\eclipse
 means you unzip into d:/xyz  not into d:/xyz/eclipse
 You can tell if you did it right because if it was done wrong you would
 have an d:\xyz\eclipse\eclipse\plugins directory. Which is wrong.
 Rich Kulp
| Re: Problem Installing VE plugin [message #598138 is a reply to message #58586] | Fri, 03 September 2004 14:39  |  |
| Eclipse User  |  |  |  |  | Originally posted by: richkulp.NO.SPAM.us.ibm.com
 Mauro wrote:
 > Hi everybody.
 > 2.0 and VE 1.0M2.
 > help or the web.
 > TIA
 > Mauro
 Thanks, Rich Kulp
| Re: Problem Installing VE plugin [message #598144 is a reply to message #58660] | Sat, 04 September 2004 10:40  |  |
 Mauro
| Re: Problem Installing VE plugin [message #598150 is a reply to message #58684] | Sat, 04 September 2004 13:00  |  |
 > Mauro
 GEF Build 3.0
 norwood sisson
| Re: Problem Installing VE plugin [message #598162 is a reply to message #58758] | Mon, 06 September 2004 00:33  |  |
| Eclipse User  |  |  |  |  | Creatxr wrote: > I've met the same problem.
 > Is here anyone that has settled the problem?
 after unzipping new plugins, start eclipse with the clean flag to make
 it search for new plugins.
 eclipse -clean
 norwood sisson
| Re: Problem Installing VE plugin [message #598177 is a reply to message #58783] | Wed, 08 September 2004 05:52  |  |
| Eclipse User  |  |  |  |  | Originally posted by: gianluca_finocchiaro.yahoo.it
 > eclipse -clean
 Hi, I had same Mauro's problems with same software
 (win2k, Eclipse build 200406251208, EMF build R200406280827 and GEF 3.0,
 VE1.0M2), resolved with the "-clean" flag.
 Thanks.
 Gianluca
| Re: Problem Installing VE plugin [message #598372 is a reply to message #58858] | Sat, 11 September 2004 07:31  |  |
| Eclipse User  |  |  |  |  | Originally posted by: jeff.arnold.tesco.net
 As a newbie and have just download the current versions of eclipse, VE and
 the depenancies on the download page I too cannot get the visual class to
 show itself.
 I have even tried the
 eclipse -clean option suggested.
 Are there any other ideas on what to do as the docs seem to be sparse when
 it comes to installing plugins etc.
 The reported versions are
 Eclipse Platform
 Version: 3.0.0
 Build id: 200406251208
 Which was downloaded on 11th Sept 04.
 Jeff.
 > > eclipse -clean
 > Thanks.
 > Gianluca
| Re: Problem Installing VE plugin [message #598405 is a reply to message #58783] | Mon, 13 September 2004 09:08  |  |
| Eclipse User  |  |  |  |  | Originally posted by: huehne.dost-telecom.de
 Hi, I got the same problem, with the same builds - also the -clean flag
 doesŽnt help.
 Alf Huehne
 > eclipse -clean
 > norwood sisson
| Re: Problem Installing VE plugin [message #600419 is a reply to message #59721] | Sat, 02 October 2004 08:07  |  |
| Eclipse User  |  |  |  |  | Originally posted by: frisey.interfree.it
 Hi, I got the same problem with these builds:
 emf-sdo-runtime-2.0.1 (R200409171617)
 GEF-runtime-3.0.1 (200408311615)
 eclipse-SDK-3.0.1-win32  (200409161125)
 VE-runtime-1.0 (200409191449)
 As described in the F.A.Q, I've unzipped into the eclipse directory the
 downloaded files.
 Then I start Eclipse using the -clean option, but I can't find any new
 feature in the environment.
 Can someone help me?
 Thanks!
 Nicola Basilico
 "Alf Huehne" <huehne@dost-telecom.de> ha scritto nel messaggio
 news:ci463t$t80$1@eclipse.org...
 > does
| Re: Problem Installing VE plugin [message #600571 is a reply to message #63853] | Mon, 04 October 2004 11:06  |  |
 eclipse is in. I.e.
 d:\xyz\eclipse
 Rich Kulp
FUDForum. Page generated in 0.28364 seconds
