Hudson CI [message #638435] |
Thu, 11 November 2010 04:59  |
Hi All,
I am just wondering if it is possible to deploy bundles to Virgo server via configured Hudson jobs and Maven. Similar to tomcat Maven plugin by which we can deploy artifacts to tomcat container.
AA
[Updated on: Thu, 11 November 2010 05:00] by Moderator
Re: Hudson CI [message #640008 is a reply to message #638435] |
Thu, 18 November 2010 11:25   |
Hi.
Actually we are doing this - Hudson copies built by maven bundles into dm server usr repository and later on we copy plan file into pickup folder.
Mostly works, but i am not 100% satisfied, so i decided to do another way
around:
I have kind of plan file, which beside of artefacts, defines dependencies between them. This plan (i call it provisioning spec) is processed by provisioning service, which works together with maven local repo and remote ones and if it finds new updates to artifacts then it deployes them into
dm server(i am talking about version 2.0.4 - i couldn't find virgo deps in repos),
using JMX deployer.
Now problem is, that after some deployments in a raw server tells, me that:
[2010-11-18 17:03:07.556] service-monitor-thread-1 <KE0100W> Reference '&org.springframework.osgi.service.importer.support.Osgi ServiceProxyFactoryBean#0' in bundle 'com.springsource.kernel.deployer' version '2.0.4.RELEASE' is waiting for service with filter '(objectClass=com.springsource.kernel.osgi.region.Region)'.
[2010-11-18 17:03:07.558] service-monitor-thread-1 <KE0100W> Reference '&bundleStarter' in bundle 'com.springsource.kernel.deployer' version '2.0.4.RELEASE' is waiting for service with filter '(objectClass=com.springsource.kernel.core.BundleStarter)'.
and after a while the timeout occurs:
[2010-11-18 17:08:02.624] Thread-3 <AG0000E> Application context creation failure for bundle 'com.springsource.kernel.deployer' version '2.0.4.RELEASE'. org.springframework.context.ApplicationContextException: Application context initialization for 'com.springsource.kernel.deployer' has timed out
at org.springframework.osgi.extender.internal.dependencies.star tup.DependencyWaiterApplicationContextExecutor.timeout(Depen dencyWaiterApplicationContextExecutor.java:454)
Actually the bundles are deployed, but the message is annoying.
Anybody can comment, what could be wrong?
From admin console the 'com.springsource.kernel.deployer' bundle looks 'active' all the time.
Ivar
Re: Hudson CI [message #640489 is a reply to message #640484] |
Mon, 22 November 2010 05:20  |
Hi Ivar
Everything you describe looks normal except I can't say why your provisioning service should cause the kernel initialisation to be fouled up. I suggest you debug the RegionManager initialisation in the case where the provisioning manager is causing problems.
FUDForum. Page generated in 0.05838 seconds
