Home » Eclipse Projects » Rich Client Platform (RCP) » Dynamically displaying controls depending on selection from combo box / Master Details model(The ability to display different controls in a view dynamically)
Dynamically displaying controls depending on selection from combo box / Master Details model [message #638366] Wed, 10 November 2010 22:19 Go to next message
Hi all!
I'm a complete n00b at RCP and I'm trying to prod and poke my way through. I'm working on some geological software, part of which involves specifying a geometry (go figure) Very Happy
For example, when trying to define a line, it will have a length, and an orientation (rotation through x, y, z) as user input which will be linked through a bean to an underlying model. When defining a plane, it might have a width and breadth associated with it and an orientation. When defining a circle, it'll have a centre point, and a radius etc.
All of these would have different controls for user input that are dependent on the "geometry" being defined. I was wondering what might actually be the best way to present the controls dynamically when the user has selected either a line, circle, plane etc from a combo box, or a listbox? I.e. if the user clicks "circle", the controls pertaining to a circle are shown, if he selects "line", the controls for the line are displayed.
This isn't necessarily just RCP specific but also general UI programming. As I'm developing this as an RCP application in Eclipse, I'd appreciate any thoughts you have.
Thank you for your help.
Re: Dynamically displaying controls depending on selection from combo box / Master Details model [message #638795 is a reply to message #638366] Fri, 12 November 2010 09:55 Go to previous messageGo to next message
Here are two ways to do it, at the swt level:
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/org. eclipse.swt.snippets/src/org/eclipse/swt/snippets/Snippet98. java
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/org. eclipse.swt.snippets/src/org/eclipse/swt/snippets/Snippet249 .java
HTH,
Grant
<j.lambertporter@gmail.com> wrote in message
news:ibfn5b$fqg$1@news.eclipse.org...
> Hi all!
> a geometry (go figure) :d
> displayed.
Re: Dynamically displaying controls depending on selection from combo box / Master Details model [message #638930 is a reply to message #638795] Sat, 13 November 2010 07:44 Go to previous message
Thanks Grant!
I appreciate the help - I'll give these bad boys a read. Still very much Java SE focused!
Thanks again Smile
Previous Topic:I think *IMenuService* has a bug in 3.6
Next Topic:why a translate method is used twice?
Current Time: Sat Jul 26 18:11:00 EDT 2025
Powered by FUDForum. Page generated in 0.44301 seconds
