Home » Modeling » EMF » Explicitly storing default values in XML resources
Explicitly storing default values in XML resources [message #638034] Tue, 09 November 2010 12:04 Go to next message
I have tried generating an EMF editor to edit XML instances of a given
(rather complex) XSD file today. I created a genmodel from the XSD and
then generated all the model, edit and editor code. Everything worked
out of the box. This is way cool!
My only problem is that when I create model instances with the generated
editor, default values of booleans or enums are not stored in the
resulting XML file. I did a search for this topic and found out about
the XMLResource.OPTION_KEEP_DEFAULT_CONTENT. So I modified the generated
editors doSave() method and added this option at the beginning. This
seems to be the correct point to do this (I have tried out the
OPTION_FORMATTED option as well, and it behaves as expected).
Also, when I set a property to some non-default value, save, and then
set it back to the default, it keeps being stored in the XML file.
However, unmodified default values are not stored, apparently.
Of course, I do not want to modify each enum-based property once for
every model, so: is there a way to achieve what I want? Did I do or
understand anything wrong?
Stefan
Re: Explicitly storing default values in XML resources [message #638185 is a reply to message #638034] Wed, 10 November 2010 05:01 Go to previous messageGo to next message
Hi again,
Used the debugger I have gained a few more insights.
First, better than changing doSave() in the editor is actually adding
the option to the defaultSaveOptions of the generated ResourceImpl for
my XML file.
Second, the problem seems to be that the defaultFeatureValueLiteral of
the affected features is null, which is why
XMLSaveImpl.shouldSaveFeature returns false in these cases. So, the
question is, why does the property view show a concrete value for the
boolean or enum-typed EAttributes but the actual XMLSaveImpl sees an
unset feature with a null default and does not save it.
I guess, I could work around this issue by changing my xsd2ecore map and
set proper default values everywhere. But my question remains: Why is
the property view and the saved resource inconsistent?
Stefan
Am 09.11.10 18:04, schrieb Stefan Winkler:
> Cheers,
> Stefan
Re: Explicitly storing default values in XML resources [message #638270 is a reply to message #638185] Wed, 10 November 2010 09:58 Go to previous messageGo to next message
Stefan,
Comments below.
Stefan Winkler wrote:
> Hi again,
> my XML file.
It's impossible for a primitive value to be null. EEnums are treated by
EMF like primitives.
> and set proper default values everywhere. But my question remains: Why
> is the property view and the saved resource inconsistent?
The properties view shows the logical value. The same one returned by
calling the getter...
> Cheers,
> Stefan
>> Hi,
>> resulting XML file.
I'd expect that. I wonder why you consider that a problem? The whole
point of default values in a schema is so that the actually instances
don't need to contain such a value in order for it to be the "effective
value."
As the option says, it only keeps explicit defaults, not intrinsic
defaults. (E.g., zero for the primitive numeric types).
You could specialize shouldSaveFeature manually, but you should also be
sure you're solving a problem that really needs to be solved.
>> Cheers,
>> Stefan
Re: Explicitly storing default values in XML resources [message #638323 is a reply to message #638270] Wed, 10 November 2010 15:42 Go to previous messageGo to next message
I had have the same problem sometimes and now I set all values.
I had have the problems with missing values, if I try to parse the
generated xml file with other xml parsers, where you evertime want a
value (default or not).
Maybee, Stefan have this usecase, too ?
Am 10.11.2010 15:58, schrieb Ed Merks:
> Stefan,
> Comments below.
>> Hi again,
>> my XML file.
>> Cheers,
>> Stefan
>>> Hi,
>>> resulting XML file.
> value."
>>> Cheers,
>>> Stefan
Re: Explicitly storing default values in XML resources [message #638329 is a reply to message #638323] Wed, 10 November 2010 16:15 Go to previous messageGo to next message
Shouldn't the XML-Parser fill in this default value based upon the XSD/DTD?
Tom
Am 10.11.10 21:42, schrieb Heiko Ahlig:
>> Stefan,
>> Comments below.
>>> Hi again,
>>> my XML file.
>>> Cheers,
>>> Stefan
>>>> Hi,
>>>> generated
>>>> resulting XML file.
>> value."
>>>> generated
>>>> Cheers,
>>>> Stefan
Re: Explicitly storing default values in XML resources [message #638330 is a reply to message #638323] Wed, 10 November 2010 16:16 Go to previous messageGo to next message
Heiko,
Adding default values to the schema and/or Ecore model and using the
option already described does already solve the problem.
Heiko Ahlig wrote:
>> Stefan,
>> Comments below.
>>> Hi again,
>>> my XML file.
>>> Cheers,
>>> Stefan
>>>> Hi,
>>>> generated
>>>> resulting XML file.
>> value."
>>>> generated
>>>> Cheers,
>>>> Stefan
Re: Explicitly storing default values in XML resources [message #638331 is a reply to message #638329] Wed, 10 November 2010 16:17 Go to previous message
--------------010706050902080709080207
Tom,
Yes, but only a schema-aware parser and then only default values
explicitly in the schema.
> Tom
>> Hi,
>>> Stefan,
>>> Comments below.
>>>> Hi again,
>>>> my XML file.
>>>> Cheers,
>>>> Stefan
>>>>> Hi,
>>>>> generated
>>>>> resulting XML file.
>>> value."
>>>>> generated
>>>>> Cheers,
>>>>> Stefan
<html>
<head>
http-equiv="Content-Type">
</head>
Tom,<br>
<br>
explicitly in the schema.<br>
<br>
<br>
Tom Schindl wrote:
<blockquote cite="mid:ibf1q1$454$1@news.eclipse.org" type="cite">
<pre wrap="">Shouldn't the XML-Parser fill in this default value based upon the XSD/DTD?
Tom
</pre>
<blockquote type="cite">
<pre wrap="">Hi,
</pre>
<pre wrap="">Stefan,
Comments below.
</pre>
<pre wrap="">Hi again,
my XML file.
</pre>
</blockquote>
<pre wrap="">It's impossible for a primitive value to be null. EEnums are treated by
</pre>
<pre wrap="">I guess, I could work around this issue by changing my xsd2ecore map
</pre>
</blockquote>
<pre wrap="">The properties view shows the logical value. The same one returned by
</pre>
<pre wrap="">Cheers,
Stefan
</pre>
<pre wrap="">Hi,
generated
resulting XML file.
</pre>
</blockquote>
</blockquote>
<pre wrap="">I'd expect that. I wonder why you consider that a problem? The whole
value."
</pre>
<pre wrap="">I did a search for this topic and found out about
generated
</pre>
</blockquote>
</blockquote>
<pre wrap="">As the option says, it only keeps explicit defaults, not intrinsic
</pre>
<pre wrap="">Of course, I do not want to modify each enum-based property once for
</pre>
</blockquote>
</blockquote>
<pre wrap="">You could specialize shouldSaveFeature manually, but you should also be
</pre>
Stefan
</pre>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
</body>
</html>
--------------010706050902080709080207--
Previous Topic:Access EMF generated classes from JEE remote client
Next Topic:Sorted ELists
Current Time: Wed Jul 23 21:36:14 EDT 2025
Powered by FUDForum. Page generated in 0.56197 seconds
