CDIException: No symbol table is loaded [message #63822] |
Tue, 04 March 2003 11:24  |
Originally posted by: gregory.ewing.qualipse.fr
------=_NextPart_000_0173_01C2E272.F1D236F0
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Whenever i try debugging either my C or CPP "Hello World" program i get =
the following error displayed in a popup window :=20
"Unable to set temporary breakpoint in main.
Reason: No symbol table is loaded. Use the "file" command. Continue ?"
In the eclipse log i have the following error :
!ENTRY org.eclipse.cdt.debug.core 4 1000 mars 04, 2003 17:05:04.618
!MESSAGE Internal error logged from CDI Debug:=20
!STACK 0
org.eclipse.cdt.debug.core.cdi.CDIException: No symbol table is loaded. =
at =
org.eclipse.cdt.debug.mi.core.cdi.BreakpointManager.setLocat ionBreakpoint=
(BreakpointManager.java:345)
at =
org.eclipse.cdt.debug.internal.core.model.CDebugTarget.setLi neBreakpoint(=
CDebugTarget.java:1647)
at =
org.eclipse.cdt.debug.internal.core.model.CDebugTarget.break pointAdded(CD=
ebugTarget.java:640)
at =
org.eclipse.debug.internal.core.BreakpointManager$Breakpoint Notifier.run(=
BreakpointManager.java:752)
at =
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.j=
ava:867)
at org.eclipse.core.runtime.Platform.run(Platform.java:413)
at =
org.eclipse.debug.internal.core.BreakpointManager$Breakpoint Notifier.noti=
fy(BreakpointManager.java:778)
at =
org.eclipse.debug.internal.core.BreakpointManager.fireUpdate (BreakpointMa=
nager.java:680)
at =
org.eclipse.debug.internal.core.BreakpointManager.addBreakpo ints(Breakpoi=
ntManager.java:419)
at =
org.eclipse.debug.internal.core.BreakpointManager.addBreakpo int(Breakpoin=
tManager.java:396)
at =
org.eclipse.cdt.debug.internal.core.breakpoints.CBreakpoint. register(CBre=
akpoint.java:161)
at =
org.eclipse.cdt.debug.internal.core.breakpoints.CBreakpoint$ 1.run(CBreakp=
oint.java:61)
at =
org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1588)
at =
org.eclipse.cdt.debug.internal.core.breakpoints.CBreakpoint. run(CBreakpoi=
nt.java:145)
at =
org.eclipse.cdt.debug.internal.core.breakpoints.CBreakpoint. <init>(CBreak=
point.java:64)
at =
org.eclipse.cdt.debug.internal.core.breakpoints.CLineBreakpo int. <init>(CL=
ineBreakpoint.java:38)
at =
org.eclipse.cdt.debug.core.CDebugModel.createLineBreakpoint( CDebugModel.j=
ava:300)
at =
org.eclipse.cdt.debug.internal.ui.actions.ManageBreakpointRu lerAction.add=
Marker(ManageBreakpointRulerAction.java:249)
at =
org.eclipse.cdt.debug.internal.ui.actions.ManageBreakpointRu lerAction.run=
(ManageBreakpointRulerAction.java:84)
at =
org.eclipse.ui.texteditor.AbstractRulerActionDelegate.run(Ab stractRulerAc=
tionDelegate.java:98)
at =
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:250)
at org.eclipse.ui.internal.PluginAction.run(PluginAction.java:2 12)
at =
org.eclipse.ui.texteditor.AbstractTextEditor$4.triggerAction (AbstractText=
Editor.java:1667)
at =
org.eclipse.ui.texteditor.AbstractTextEditor$4.mouseDoubleCl ick(AbstractT=
extEditor.java:1681)
at =
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:134)=
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :77)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:836)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1692)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1410)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1289)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1272)
at =
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.=
java:845)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at =
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java=
:39)
at =
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorI=
mpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.basicRun(Main.java:247)
at org.eclipse.core.launcher.Main.run(Main.java:703)
at org.eclipse.core.launcher.Main.main(Main.java:539)
Regards, Greg.
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2600.0" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DTahoma size=3D2>Hello,</FONT></DIV>
<DIV><FONT face=3DTahoma size=3D2></FONT> </DIV>
<DIV><FONT face=3DTahoma size=3D2>Whenever i try debugging either my C =
or CPP "Hello=20
World" program i get the following error displayed in a popup window :=20
</FONT></DIV>
<DIV><FONT face=3DTahoma size=3D2>"Unable to set temporary breakpoint in =
main.</FONT></DIV>
<DIV><FONT face=3DTahoma size=3D2> Reason: No symbol table is =
loaded. Use the=20
"file" command. Continue ?"</FONT></DIV>
<DIV><FONT face=3DTahoma size=3D2>In the eclipse log i have the =
following error=20
:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DCourier size=3D2>!ENTRY org.eclipse.cdt.debug.core 4 =
1000 mars 04,=20
2003 17:05:04.618<BR>!MESSAGE Internal error logged from CDI Debug: =
<BR>!STACK=20
0<BR>org.eclipse.cdt.debug.core.cdi.CDIException: No symbol table is=20
loaded. Use the "file" command.<BR> at=20
(BreakpointManager.java:345)<BR> at=20
CDebugTarget.java:1647)<BR> at=20
ebugTarget.java:640)<BR> at=20
BreakpointManager.java:752)<BR> at=20
ava:867)<BR> at=20
org.eclipse.core.runtime.Platform.run(Platform.java:413)<BR > at=20
fy(BreakpointManager.java:778)<BR> at=20
nager.java:680)<BR> at=20
ntManager.java:419)<BR> at=20
tManager.java:396)<BR> at=20
akpoint.java:161)<BR> at=20
oint.java:61)<BR> at=20
org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1588) <BR=
> at=20
nt.java:145)<BR> at=20
org.eclipse.cdt.debug.internal.core.breakpoints.CBreakpoint. <init>(=
CBreakpoint.java:64)<BR> at=20
org.eclipse.cdt.debug.internal.core.breakpoints.CLineBreakpo int.<init&=
gt;(CLineBreakpoint.java:38)<BR> at=20
ava:300)<BR> at=20
Marker(ManageBreakpointRulerAction.java:249)<BR> at=20
(ManageBreakpointRulerAction.java:84)<BR> at=20
tionDelegate.java:98)<BR> at=20
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:250) <=
BR> at=20
org.eclipse.ui.internal.PluginAction.run(PluginAction.java:2 12) <BR> =
at=20
Editor.java:1667)<BR> at=20
extEditor.java:1681)<BR> at=20
<BR> at=20
org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :77) <BR> =
;at=20
org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:836)<BR > at=20
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1692) <BR>&=
nbsp;at=20
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1410) <BR>&nb=
sp;at=20
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1289) <BR>&n=
bsp;at=20
org.eclipse.ui.internal.Workbench.run(Workbench.java:1272)<BR > at=20
java:845)<BR> at=20
org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)<BR > at=20
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)<BR> at=20
:39)<BR> at=20
mpl.java:25)<BR> at=20
java.lang.reflect.Method.invoke(Method.java:324)<BR> at=20
org.eclipse.core.launcher.Main.basicRun(Main.java:247)<BR> at=20
org.eclipse.core.launcher.Main.run(Main.java:703)<BR> at=20
org.eclipse.core.launcher.Main.main(Main.java:539)<BR></FONT ></DIV>
<DIV><FONT size=3D2></FONT> </DIV>
<DIV><FONT face=3DTahoma size=3D2>Regards, =
Greg.</FONT></DIV></BODY></HTML>
------=_NextPart_000_0173_01C2E272.F1D236F0--
Re: CDIException: No symbol table is loaded [message #63844 is a reply to message #63822] |
Tue, 04 March 2003 11:33   |
------=_NextPart_000_0185_01C2E274.320C5D30
Me again,
When i click on the ""Show Debugger Console O Target Selection", the =
following message is displayed :
info threads
No stack.
Warning: D:Program FilesEclipse/"D:\Program: No such file or directory.
Warning: D:Program FilesEclipse/Files\Eclipse\workspace\CPP_Test": No =
kill
The program is not being run.
Quit (expect signal SIGINT when the program is resumed)
Obviously the is a problem with my working directory, the correct dir =
path is : D:\Program Files\Eclipse\workspace\CPP_Test. How can a correct =
this ?
Regards, Greg.
"Ewing" <gregory.ewing@qualipse.fr> a =E9crit dans le message de news: =
b42ka0$33n$1@rogue.oti.com...
Whenever i try debugging either my C or CPP "Hello World" program i =
Reason: No symbol table is loaded. Use the "file" command. Continue =
!STACK 0
org.eclipse.cdt.debug.core.cdi.CDIException: No symbol table is =
at =
at =
at =
at =
at =
ava:867)
at =
at =
nager.java:680)
at =
ntManager.java:419)
at =
tManager.java:396)
at =
akpoint.java:161)
at =
oint.java:61)
at =
at =
nt.java:145)
at =
point.java:64)
at =
at =
ava:300)
at =
at =
at =
at =
at =
Editor.java:1667)
at =
at =
at =
at =
at =
java:845)
at =
:39)
at =
mpl.java:25)
Regards, Greg.
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DTahoma size=3D2>Me again,</FONT></DIV>
<DIV><FONT face=3DTahoma size=3D2>When i click on the ""Show Debugger =
Console O=20
Target Selection", the following message is displayed :</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV><FONT =
color=3D#ff0000 size=3D2>
<DIV><FONT face=3DCourier color=3D#000000>info threads</FONT></DIV>
<DIV><FONT face=3DCourier color=3D#000000>No stack.</FONT></DIV>
<DIV><FONT face=3DCourier color=3D#000000>Warning: D:Program=20
FilesEclipse/"D:\Program: No such file or directory.</FONT></DIV>
FilesEclipse/Files\Eclipse\workspace\CPP_Test": No such file or=20
<DIV><FONT face=3DCourier color=3D#000000>No symbol table is loaded. Use =
the "file"=20
command.</FONT></DIV>
the "file"=20
<DIV><FONT face=3DCourier color=3D#000000>kill</FONT></DIV>
<DIV><FONT face=3DCourier color=3D#000000>The program is not being =
run.</FONT></DIV>
<DIV><FONT face=3DCourier color=3D#000000>Quit (expect signal SIGINT =
when the=20
program is resumed)</FONT></DIV>
<DIV><FONT face=3DCourier color=3D#000000></FONT> </DIV>
<DIV><FONT face=3DTahoma color=3D#000000>Obviously the is a problem with =
my working=20
directory, the correct dir path is : D:\Program=20
Files\Eclipse\workspace\CPP_Test. How can a correct this ?</FONT></DIV>
<DIV><FONT face=3DTahoma color=3D#000000></FONT> </DIV>
<DIV><FONT face=3DTahoma color=3D#000000>Regards, =
Greg.</FONT></DIV></FONT>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ewing" <<A=20
href=3D"mailto:gregory.ewing@qualipse.fr">gregory.ewing@qualipse.fr</A>&g=
t; a=20
=E9crit dans le message de news: <A=20
href=3D"mailto:b42ka0$33n$1@rogue.oti.com">b42ka0$33n$1@rogue.oti.com</A>=
....</DIV>
or CPP=20
"Hello World" program i get the following error displayed in a popup =
window :=20
</FONT></DIV>
<DIV><FONT face=3DTahoma size=3D2>"Unable to set temporary breakpoint =
in=20
main.</FONT></DIV>
loaded. Use the=20
following error=20
:</FONT></DIV>
1000 mars=20
04, 2003 17:05:04.618<BR>!MESSAGE Internal error logged from CDI =
Debug:=20
<BR>!STACK 0<BR>org.eclipse.cdt.debug.core.cdi.CDIException: No symbol =
table=20
is loaded. Use the "file" command.<BR> at=20
ava:867)<BR> at=20
> at=20
ava:300)<BR> at=20
BR> at=20
at=20
<BR> at=20
;at=20
nbsp;at=20
sp;at=20
bsp;at=20
org.eclipse.ui.internal.Workbench.run(Workbench.java:1272)<BR > at =
java:845)<BR> at=20
sun.reflect.NativeMethodAccessorImpl.invoke0(Native =
Method)<BR> at=20
:39)<BR> at=20
<DIV><FONT face=3DTahoma size=3D2>Regards,=20
Greg.</FONT></DIV></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_0185_01C2E274.320C5D30--
Re: CDIException: No symbol table is loaded [message #63867 is a reply to message #63844] |
Tue, 04 March 2003 13:34  |
Originally posted by: mikhailkhod.rogers.com
The problem is that your path contains space character. This bug is already
fixed in the head branch.
"Ewing" <gregory.ewing@qualipse.fr> wrote in message
news:b42kqp$3hs$1@rogue.oti.com...
Me again,
info threads
No stack.
Warning: D:Program FilesEclipse/Files\Eclipse\workspace\CPP_Test": No such
file or directory.
kill
Obviously the is a problem with my working directory, the correct dir path
is : D:\Program Files\Eclipse\workspace\CPP_Test. How can a correct this ?
Regards, Greg.
FUDForum. Page generated in 0.04410 seconds
