Home » Archived » AMP » Keybinding conflicts ALT+SHIFT+L
Keybinding conflicts ALT+SHIFT+L [message #638124] |
Tue, 09 November 2010 21:02  |
Does anyone else get a Keybinding conflict on ALT+SHIFT+L error when running models?
!ENTRY org.eclipse.jface 2 0 2010-11-10 15:00:33.190
!MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2010-11-10 15:00:33.190
!MESSAGE A conflict occurred for ALT+SHIFT+L:
Binding(ALT+SHIFT+L,
ParameterizedCommand(Command(org.eclipse.amp.axf.ui.resume,Resume,
Category(org.eclipse.amp.axf.ui,Model Execution Engine,Running and Exploring Models,true),
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.amp.axf.activeEditorContext,,,system)
ParameterizedCommand(Command(org.eclipse.jdt.ui.edit.text.java.extract.local.variable,Extract Local Variable,
Extracts an expression into a new local variable and uses the new local variable,
Category(org.eclipse.jdt.ui.category.refactoring,Refactor - Java,Java Refactoring Actions,true),
,,true),null),
org.eclipse.ui.contexts.window,,,system)
Re: Keybinding conflicts ALT+SHIFT+L [message #639584 is a reply to message #638124] |
Tue, 16 November 2010 21:56   |
Hmm..that binding should be option-cmd-L on Mac which should map to alt-ctrl I think on Windows. Check your key preferences. I do see that JDT unfortunately applies it's command to all Windows instead of just Java Source. I odn't know why that is. If this seems like a real conflict let me know and we'll change it or even get rid of it. In retrospect I don't see really see that that the key-binding is all that useful -- most people will just click on the toolbar button or whatever.
Oliver Mannion wrote on Tue, 09 November 2010 21:02 | Does anyone else get a Keybinding conflict on ALT+SHIFT+L error when running models?
,,true),null),
,,true),null),
Re: Keybinding conflicts ALT+SHIFT+L [message #1077022 is a reply to message #640038] |
Thu, 01 August 2013 02:26  |
Whatever be the case, a developer is looking for some resolution from this forum.
One possible resolution is
1. Goto Window -> Preferences -> General -> Keys
2. Type the key shortcut for which the conflict is reported in the "filter" section (for e.g. type 'ALT+SHIFT+Q' in filter)
3. Select the exact key for which conflict is being reported.
4. All the conflicting applications/plugins will be displayed there.
5. Choose the plugin which you do not use frequently and "Unbind" the key for that plugin.
Vikas
Current Time: Wed Jul 23 05:32:33 EDT 2025
Powered by FUDForum. Page generated in 0.05447 seconds
