Home » Modeling » OCL » SemanticException
SemanticException [message #634261] Wed, 20 October 2010 22:11 Go to next message
Hi, I am having problems with OCLHelper. I have the following code which is working fine. But when I change the expression to "price > 0" I get a SemanticException. Any ideas? Thanks in advance, Eban
Class umlClass = (Class)package.getOwnedMember("Product");
Property umlProperty = umlClass.getOwnedAttribute("price", null);
OCL ocl = OCL.newInstance();
OCLHelper helper = ocl.createOCLHelper();
helper.setAttributeContext(umlProperty.getOwner(), umlProperty);
String expression = "price = 0"
OCLExpression query = helper.createQuery(expression);
org.eclipse.ocl.SemanticException: Cannot find operation (>(Integer)) for the type (null)
at org.eclipse.ocl.util.OCLUtil.checkForErrors(OCLUtil.java:352 )
at org.eclipse.ocl.util.OCLUtil.checkForErrors(OCLUtil.java:322 )
at org.eclipse.ocl.internal.helper.HelperUtil.checkForErrors(He lperUtil.java:519)
at org.eclipse.ocl.internal.helper.HelperUtil.parseQuery(Helper Util.java:165)
at org.eclipse.ocl.internal.helper.OCLHelperImpl.createQuery(OC LHelperImpl.java:175)
at org.eclipse.ocl.uml.OCLHelperImpl.createQuery(OCLHelperImpl. java:91)
at org.eclipse.ocl.uml.OCLHelperImpl.createQuery(OCLHelperImpl. java:1)
Re: SemanticException [message #634314 is a reply to message #634261] Thu, 21 October 2010 04:46 Go to previous messageGo to next message
Hi Eban
as the message says
price has a null type.
OclVoid supports = but not > so the change caused a useless evaluation
to change to a semantic probvlem.
Ed Willink
> for the type (null)
> lperUtil.java:519)
> Util.java:165)
> java:91)
> java:1)
Re: SemanticException [message #635736 is a reply to message #634261] Wed, 27 October 2010 17:47 Go to previous messageGo to next message
Hi Ed, thanks for the reply Smile
I checked the uml model and I do have a type for price:
<ownedAttribute xmi:id="_YePi8IeiEd6G9vv1xOexfw" name="price" aggregation="composite">
<type xmi:type="uml:PrimitiveType" href="pathmap://UML_METAMODELS/Ecore.metamodel.uml#EBigDecimal"/>
</ownedAttribute>
Is this not a type it expects?
I also looked at the doc for getOwnedAttribute and I figured the 2nd param can be null as it would just search based in the name.
Property getOwnedAttribute(java.lang.String name,
Type type)
Retrieves the first Property with the specified 'Name', and 'Type' from the 'Owned Attribute' containment reference list.
Parameters:
name - The 'Name' of the Property to retrieve, or null.
type - The 'Type' of the Property to retrieve, or null.
Cheers
Eban
Re: SemanticException [message #635783 is a reply to message #635736] Thu, 28 October 2010 02:20 Go to previous messageGo to next message
Hi Eban
If you have a problem, it is helpful to provide a reproducible test case.
Your original query was difficult to guess at because you didn't provide
a meta-model.
You now only provide one attribute.
If you understand the problem so well that this is sufficient, perhaps
you can supply the fix.
Otherwise please provide sufficient information to allow investigation.
Ed Willink
On 27/10/2010 22:47, Eban Escott wrote:
> Hi Ed, thanks for the reply :)
> </ownedAttribute>
> Type type)
> Parameters:
> Cheers
> Eban
Re: SemanticException [message #636010 is a reply to message #634261] Thu, 28 October 2010 18:38 Go to previous messageGo to next message
Hi Ed,
I wish a had a fix to the problem and I do apologise if I have not supplied enough information as I am new to OCL and still finding my feet.
Here is the isolated UML model and if you name it MyModel.uml and run the JUnit test it will give you the exception.
Cheers
Eban
<xmi:XMI xmi:version="2.1" xmlns:xmi="http://schema.omg.org/spec/XMI/2.1" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" xmlns:profileM="http:///schemas/profileM/_bYwRQKwKEd6_R4nwdX_sDQ/0" xmlns:uml="http://www.eclipse.org/uml2/3.0.0/UML" xmlns:validation="http:///schemas/validation/_LIcqENZpEd-pV_SeKY8DIg/10" xsi:schemaLocation="http:///schemas/profileM/_bYwRQKwKEd6_R4nwdX_sDQ/0 ../../Profile/model/profileM.profile.uml#_bYxfYKwKEd6_R4nwdX_sDQ http:///schemas/validation/_LIcqENZpEd-pV_SeKY8DIg/10 ../../Profile/model/validation.profile.uml#_LIdRINZpEd-pV_SeKY8DIg">
  <uml:Package xmi:id="_Rl0wAHTSEd6tw7FQB0T26Q" name="MyPackage">
    <elementImport xmi:id="_RrcP0HTSEd6tw7FQB0T26Q">
      <importedElement xmi:type="uml:PrimitiveType" href="pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#Boolean"/>
    </elementImport>
    <elementImport xmi:id="_RrqSQHTSEd6tw7FQB0T26Q">
      <importedElement xmi:type="uml:PrimitiveType" href="pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#String"/>
    </elementImport>
    <elementImport xmi:id="_RrqSQXTSEd6tw7FQB0T26Q">
      <importedElement xmi:type="uml:PrimitiveType" href="pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#UnlimitedNatural"/>
    </elementImport>
    <elementImport xmi:id="_RrqSQnTSEd6tw7FQB0T26Q">
      <importedElement xmi:type="uml:PrimitiveType" href="pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#Integer"/>
    </elementImport>
    <packagedElement xmi:type="uml:Class" xmi:id="_TxO3oHTSEd6tw7FQB0T26Q" name="Product">
      <ownedAttribute xmi:id="_QKQ5EH8nEd6YbOsakxhBTg" name="id" aggregation="composite">
        <type xmi:type="uml:PrimitiveType" href="pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#Integer"/>
      </ownedAttribute>
      <ownedAttribute xmi:id="_QciWUIeiEd6G9vv1xOexfw" name="name" aggregation="composite">
        <type xmi:type="uml:PrimitiveType" href="pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#String"/>
      </ownedAttribute>
      </ownedAttribute>
    </packagedElement>
  </uml:Package>
</xmi:XMI>
package transform.ocl;
import java.io.File;
import java.io.IOException;
import junit.framework.Assert;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.ocl.expressions.OCLExpression;
import org.eclipse.ocl.helper.OCLHelper;
import org.eclipse.ocl.uml.OCL;
import org.eclipse.uml2.uml.Class;
import org.eclipse.uml2.uml.Classifier;
import org.eclipse.uml2.uml.Operation;
import org.eclipse.uml2.uml.Package;
import org.eclipse.uml2.uml.Property;
import org.eclipse.uml2.uml.UMLPackage;
import org.eclipse.uml2.uml.resource.UMLResource;
import org.junit.Test;
import transform.utils.TransformationUtils;
public class IsolationForEdTest {
	@Test
	public void ocl1() {
		try {
			Package umlPackage = loadModel();
			Class umlClass = (Class)umlPackage.getOwnedMember("Product");
			OCLExpression query = helper.createQuery("price > 0");
		} catch (Exception e) {
			e.printStackTrace();
			Assert.assertTrue(false);
	private Package loadModel() throws IOException {
		ResourceSet resourceSet = new ResourceSetImpl();
		resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
		Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
		File file = new File("MyModel.uml");
		if(!file.exists()) {
			System.out.println("Cannot find file.");
		} else {
			System.out.println("Found " + file.getCanonicalPath());
		URI uri = URI.createFileURI(file.getCanonicalPath());
		Resource resource = resourceSet.getResource(uri, true);
		Package inputPackage = (Package)resource.getContents().get(0);
		return inputPackage;
[Updated on: Thu, 28 October 2010 18:39] by Moderator
Re: SemanticException [message #636069 is a reply to message #636010] Fri, 29 October 2010 04:49 Go to previous messageGo to next message
Hi Eban
Thanks for the excellent repro.
The confusion is that = should fail too. In fact both should be
diagnosed as an unresolved proxy
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=329011) because you have
omitted the required initialisation of UML pathmaps. This is awkward, so
OCL provides a helper.
You need to add:
String reason = OCL.initialize(resourceSet);
TestCase.assertNull("Initialization failed : " + reason, reason);
which will then give you some failures that will prompt you to add
-Dorg.eclipse.ocl.uml=${resource_loc:/org.eclipse.ocl.uml}
-Dorg.eclipse.uml2.uml.resources=${resource_loc:/org.eclipse .uml2.uml.resources}
to your launch configuration and to load
org.eclipse.ocl.uml
into your workspace, since the standalone EMF support cannot extract UML
models from
plugin ZIP files.
Ed Willink
On 28/10/2010 23:38, Eban Escott wrote:
> Hi Ed,
> the JUnit test you it will give you the exception.
> Cheers
> Eban
> ../../Profile/model/profileM.profile.uml#_bYxfYKwKEd6_R4nwdX _sDQ
> ../../Profile/model/validation.profile.uml#_LIdRINZpEd-pV_Se KY8DIg ">
> href=" pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#Boolea n"/>
> </elementImport>
> href=" pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#String"/>
> </elementImport>
> href=" pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#Unlimi tedNatural"/>
> </elementImport>
> href=" pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#Intege r"/>
> </elementImport>
> name="Product">
> </ownedAttribute>
> </ownedAttribute>
> </ownedAttribute>
> </packagedElement>
> </uml:Package>
> </xmi:XMI>
> @Test
> try {
> null);
> umlProperty);
> Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put(UMLResource.FILE_EXTENSION,
> } else {
Re: SemanticException [message #638100 is a reply to message #636069] Tue, 09 November 2010 17:07 Go to previous message
Great, thanks Ed!
I unzipped the jar files into my workspace and added the extra config and it works.
I appreciate your effort Smile
Take care
Eban
Previous Topic:OCL iterate - help a begineer
Next Topic:derive Expression with stereotypes and tagged values
Current Time: Sat Jul 26 11:48:42 EDT 2025
Powered by FUDForum. Page generated in 0.26663 seconds
