Home » Modeling » EMF » Serialization problem concerning Maps
Serialization problem concerning Maps [message #552429] Thu, 12 August 2010 04:27 Go to next message
I want to serialize my model to XMI. In my model there are maps which I want to serialize, too. I want to save the key and the value of each map entry. How can I do this?
I use the resource set. I do it like that:
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("xmi", new XMIResourceFactoryImpl());
Resource resource = resourceSet.createResource(URI.createFileURI("some file name"));
resource.getContents().add(form);
resource.save(null);
So far no problem but my maps store only the keys.
One map is defined as Java interface like this:
 * @model
public interface Variables extends EObject {
  * @return
  * @model mapType="HashMap" keyType="String" valueType="VartabEntry" containment="true"
 EMap<String, VartabEntry> getVartabEntriesMap();
And VartabEntry is defined like this:
 * @model
public interface VartabEntry extends EObject  {
     * @return
     * @model
    String getEnglishName();
     * @return
     * @model
    String getName();
   ... and more attributes.
And I got following XMI part in my file:
  <variables>
    <vartabEntriesMap key="0:grust"/>
    <vartabEntriesMap key="0:gruppe"/>
    <vartabEntriesMap key="0:grbez"/>
    <vartabEntriesMap key="0:dnr"/>
    <vartabEntriesMap key="0:dbez"/>
    <vartabEntriesMap key="0:ozeilen"/>
    <vartabEntriesMap key="0:sn"/>
  </variables>
How can I tell EMF to store also the VartabEntry instances in the XMI file?
With regards,
Udo
Re: Serialization problem concerning Maps [message #552565 is a reply to message #552429] Thu, 12 August 2010 12:01 Go to previous messageGo to next message
Udo,
Comments below.
> resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put( "xmi",
> file name"));
> * @model
> * @return
> containment="true"
Did you look at the FAQ how to do this?
> * @model
> * @return
> * @model
> * @return
> * @model
> String getName();
You'd not define an explicit interface for the map entry. Did you
look at how EAnnotation.getDetails works?
> <variables>
> </variables>
> file?
> With regards,
> Udo
Re: Serialization problem concerning Maps [message #553052 is a reply to message #552565] Mon, 16 August 2010 05:30 Go to previous messageGo to next message
Hi Ed,
comments below.
Ed Merks wrote on Thu, 12 August 2010 12:01
Udo,
Comments below.
> file name"));
> * @model
> * @return
> containment="true"
As I understand the FAQ I did the right thing with my "@model" annotations.
EMF generated the class EStringToVartabEntryMapEntryImpl.
Do I have to add some methods to that generated class?
My ecore model looks like this (for the generated class):
  <eClassifiers xsi:type="ecore:EClass" name="EStringToVartabEntryMapEntry" instanceClassName="java.util.Map$Entry">
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="key" eType="ecore:EDataType platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore#//EString"/>
    <eStructuralFeatures xsi:type="ecore:EReference" name="value" eType="#//VartabEntry"/>
  </eClassifiers>
Is this correct?
> * @model
> * @return
> * @model
> * @return
> * @model
> String getName();
I do not understand, why I should not define an interface for my "value" type. What should I implement to serialize that correctly. I saw that EAnnotation.getDetails tries to get the serialized form of my value type but where do I specify it?
> <variables>
> </variables>
> file?
> With regards,
> Udo
Re: Serialization problem concerning Maps [message #553098 is a reply to message #553052] Mon, 16 August 2010 09:27 Go to previous messageGo to next message
--------------070502020401070906050607
Udo,
Comments below.
Udo wrote:
> Hi Ed,
> comments below.
>> Udo,
>> Comments below.
>> which > I want to serialize, too. I want to save the key and the
>> value of each > map entry. How can I do this?
>> ryMap().put( "xmi", > new XMIResourceFactoryImpl());
>> > Resource resource =
>> resourceSet.createResource(URI.createFileURI("some > file name"));
>> > * @model
>> > * @return
>> valueType="VartabEntry" > containment="true"
>> annotations.
The FAQ looked like this.
* @model keyType="java.lang.String" valueType="java.lang.String"
Map<String, String> getScoScoMap();
And EAnnotation.details looks like this:
* @model
mapType="org.eclipse.emf.ecore.EStringToStringMapEntry<org.eclipse.emf.ecore.EString,
org.eclipse.emf.ecore.EString>"
EMap<String, String> getDetails();
Things to note are fully qualified names. In fact, note that in
EAnnotation, the fully qualified names are Ecore names, not Java names.
There's also no use of containment='true'.
Yes, but there is no EStringToVartabMapEntry interface. I.e., there's
nothing like your VartabEntry.
>> platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore#//E String "/>
>> </eClassifiers>
>> Is this correct?
You don't want the value to be of type VartabEntry though do you? I
assume you want it to be string like in the FAQ example and in EAnnotation.
>> > * @model
>> > * @return
>> > * @model
>> > * @return
>> > * @model
>> > String getName();
>> > <variables>
>> > </variables>
>> XMI > file?
>> > With regards,
>> > Udo
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Udo,<br>
<br>
Comments below.  <br>
<br>
Udo wrote:
<blockquote cite="mid:i4b0ge$jc7$1@build.eclipse.org" type="cite">Hi
Ed, <br>
comments below.
<br>
<br>
<br>
<blockquote type="cite">Udo,
<br>
<br>
Comments below.
<br>
<br>
Udo wrote:
<br>
&gt; I want to serialize my model to XMI. In my model there are maps
which &gt; I want to serialize, too. I want to save the key and the
value of each &gt; map entry. How can I do this?
<br>
&gt;
<br>
&gt; I use the resource set. I do it like that:
<br>
&gt;
<br>
&gt;
<br>
&gt; ResourceSet resourceSet = new ResourceSetImpl();
<br>
&gt;   resourceSet.getResourceFactoryRegistry().getExtensionToFacto
ryMap().put( "xmi", &gt; new XMIResourceFactoryImpl());
<br>
&gt; Resource resource =
resourceSet.createResource(URI.createFileURI("some &gt; file name"));
<br>
&gt; resource.getContents().add(form);
<br>
&gt; resource.save(null);
<br>
&gt;
<br>
&gt;
<br>
&gt; So far no problem but my maps store only the keys.
<br>
&gt;
<br>
&gt; One map is defined as Java interface like this:
<br>
&gt;
<br>
&gt;
<br>
&gt; /**
<br>
&gt; * @model
<br>
&gt; */
<br>
&gt; public interface Variables extends EObject {
<br>
&gt;
<br>
&gt; /**
<br>
&gt;  * @return
<br>
&gt;  * @model mapType="HashMap" keyType="String"
valueType="VartabEntry" &gt; containment="true"
<br>
&gt;     */
<br>
&gt; EMap&lt;String, VartabEntry&gt; getVartabEntriesMap();
<br>
<br>
<br>
annotations.  <br>
</blockquote>
</blockquote>
The FAQ looked like this.<br>
<blockquote>
<pre class="source-java5"><span class="coMULTI">/**
*/</span>
Map&lt;String, String&gt; getScoScoMap<span class="br0">(</span><span
class="br0">)</span>;
</pre>
</blockquote>
And EAnnotation.details looks like this:<br>
<blockquote>  /**<br>
   * @model
mapType=" org.eclipse.emf.ecore.EStringToStringMapEntry&lt;org.ecl ipse.emf.ecore.EString,
org.eclipse.emf.ecore.EString&gt;"<br>
   */<br>
  EMap&lt;String, String&gt; getDetails();<br>
</blockquote>
names.  There's also no use of containment='true'.<br>
<blockquote type="cite"> EMF generated the class
<br>
</blockquote>
</blockquote>
<blockquote type="cite"><br>
<br>
<br>
<br>
<br>
<br>
  &lt;eClassifiers xsi:type="ecore:EClass"
instanceClassName="java.util.Map$Entry"&gt;
<br>
    &lt;eStructuralFeatures xsi:type="ecore:EAttribute" name="key"
platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore#//E String "/&gt;
<br>
    &lt;eStructuralFeatures xsi:type="ecore:EReference" name="value"
eType="#//VartabEntry"/&gt;
<br>
  &lt;/eClassifiers&gt;
<br>
<br>
<br>
Is this correct?
<br>
</blockquote>
</blockquote>
EAnnotation.<br>
&gt;
<br>
&gt;
<br>
&gt; And VartabEntry is defined like this:
<br>
&gt;
<br>
&gt;
<br>
&gt; /**
<br>
&gt; * @model
<br>
&gt; */
<br>
&gt; public interface VartabEntry extends EObject  {
<br>
&gt;       /**
<br>
&gt;     * @return
<br>
&gt;     * @model
<br>
&gt;     */
<br>
&gt;    String getEnglishName();
<br>
&gt;
<br>
&gt;   /**
<br>
&gt;     * @return
<br>
&gt;     * @model
<br>
&gt;     */
<br>
&gt;    String getName();
<br>
&gt;
<br>
&gt;   ... and more attributes.
<br>
&gt;
<br>
<br>
<br>
<br>
&gt;
<br>
&gt; And I got following XMI part in my file:
<br>
&gt;
<br>
&gt;
<br>
&gt;  &lt;variables&gt;
<br>
&gt;    &lt;vartabEntriesMap key="0:grust"/&gt;
<br>
&gt;    &lt;vartabEntriesMap key="0:gruppe"/&gt;
<br>
&gt;    &lt;vartabEntriesMap key="0:grbez"/&gt;
<br>
&gt;    &lt;vartabEntriesMap key="0:dnr"/&gt;
<br>
&gt;    &lt;vartabEntriesMap key="0:dbez"/&gt;
<br>
&gt;    &lt;vartabEntriesMap key="0:ozeilen"/&gt;
<br>
&gt;    &lt;vartabEntriesMap key="0:sn"/&gt;
<br>
&gt;
<br>
&gt; ..
<br>
&gt;  &lt;/variables&gt;
<br>
&gt;
<br>
&gt;
<br>
&gt;
<br>
&gt; How can I tell EMF to store also the VartabEntry instances in the
XMI &gt; file?
<br>
&gt;
<br>
&gt; With regards,
<br>
&gt; Udo
<br>
&gt;
<br>
</blockquote>
<br>
<br>
</blockquote>
</body>
</html>
--------------070502020401070906050607--
Re: Serialization problem concerning Maps [message #553948 is a reply to message #553098] Thu, 19 August 2010 09:51 Go to previous messageGo to next message
Hi Ed,
I think you got me wrong.
I do want to have a map which has keys of type String and values of type VartabEntry. The only thing which I do not understand is how do I tell the generated class EStringToVartabEntryMapEntryImpl to serialize its keys AND values. It serializes only its keys, which are serialized correctly.
Or can I not use a map like I want to use?
Udo
Re: Serialization problem concerning Maps [message #553961 is a reply to message #553948] Thu, 19 August 2010 10:18 Go to previous messageGo to next message
--------------020801050208000902000106
Udo,
Comments below.
Udo wrote:
> Hi Ed,
> type VartabEntry.
Oh.
I see nothing that should prevent that feature from being serialized.
You're sure it's actually populated with non-null values?
The Change model has maps with references so it should work...
* @model
mapType="org.eclipse.emf.ecore.change.EObjectToChangesMapEntry <org.eclipse.emf.ecore.EObject,
org.eclipse.emf.ecore.change.FeatureChange>"
* @generated
EMap<EObject, EList<FeatureChange>> getObjectChanges();
Check during serialization if eIsSet is being called for the value
feature of the map entry and if it's returning true. It should be
serialized in that case.
> Regards,
> Udo
<html>
<head>
</head>
Udo,<br>
<br>
Comments below.<br>
<br>
Udo wrote:
<blockquote cite="mid:i4jcsc$agh$1@build.eclipse.org" type="cite">Hi
Ed,
<br>
<br>
<br>
<br>
type VartabEntry.</blockquote>
Oh.<br>
<blockquote cite="mid:i4jcsc$agh$1@build.eclipse.org" type="cite"> The
<br>
</blockquote>
You're sure it's actually populated with non-null values?<br>
<blockquote cite="mid:i4jcsc$agh$1@build.eclipse.org" type="cite"><br>
<br>
</blockquote>
The Change model has maps with references so it should work...<br>
<blockquote>   * @model
mapType=" org.eclipse.emf.ecore.change.EObjectToChangesMapEntry&lt ;org.eclipse.emf.ecore.EObject,
org.eclipse.emf.ecore.change.FeatureChange&gt;"<br>
   * @generated<br>
   */<br>
  EMap&lt;EObject, EList&lt;FeatureChange&gt;&gt; getObjectChanges();<br>
</blockquote>
serialized in that case.<br>
<br>
Udo
<br>
<br>
</blockquote>
</body>
</html>
--------------020801050208000902000106--
Re: Serialization problem concerning Maps [message #555600 is a reply to message #553961] Fri, 27 August 2010 05:48 Go to previous messageGo to next message
Hi Ed,
I checked the method eIsSet of my EStringToVartabEntryMapEntryImpl and it returns true. I did this by overwriting the method eIsSet in that class and checking the name of the feature and value of the super.eIsSet() method. The value feature returns true.
My output still looks like this:
 <variables>
Still only keys.
Do you have any ideas what I could do wrong?
Re: Serialization problem concerning Maps [message #555664 is a reply to message #555600] Fri, 27 August 2010 10:12 Go to previous messageGo to next message
Udo,
The debugger is doing to answer your questions faster than me. Monitor
what happens in XMLSaveImpl.saveFeatures for your map entry instances.
Pay particular attention to the processing of the features where there
is a guard like this
if (kind != TRANSIENT && shouldSaveFeature(o, f))
Udo wrote:
> Hi Ed,
> Quote:
> <variables>
> Still only keys.
Re: Serialization problem concerning Maps [message #638066 is a reply to message #555664] Tue, 09 November 2010 13:55 Go to previous messageGo to next message
Hi Ed,
I found a solution but I don't know how to do it with annotations in my
interfaces.
If I open the *.ecore file and go to the value feature of the map and
change the containment from (default) "false" to "true" then the value
which is my from EMF generated object is also saved.
How can I tell the EMF generator with Java annotations that the value of
my map needs the containment attribute set to "true"?
Here is the snippet from my ecore file:
<eClassifiers xsi:type="ecore:EClass" name="VartabEntryMap"
name="key"
http://www.eclipse.org/emf/2002/Ecore#//EString"/>
name="value"
containment="true"/>
</eClassifiers>
The second last line is the important one. How to do that in Java
annotations?
Udo
Am 27.08.2010 16:12, schrieb Ed Merks:
> Udo,
> Udo wrote:
>> Hi Ed,
>> Quote:
>> <variables>
>> Still only keys.
Re: Serialization problem concerning Maps [message #638266 is a reply to message #638066] Wed, 10 November 2010 09:38 Go to previous message
Udo,
Comments below.
Udo Walker wrote:
> Hi Ed,
> my interfaces.
You can always generate the code to see what @model annotations are
generated. Delete the method and let it me regenerated if necessary.
> of my map needs the containment attribute set to "true"?
I'm not sure what you did that made if false. There is a FAQ about this.
> name="key"
> name="value"
> </eClassifiers>
> annotations?
> Udo
>> Udo,
>> Udo wrote:
>>> Hi Ed,
>>> Quote:
>>> <variables>
>>> Still only keys.
Previous Topic:Ecore Model
Next Topic:Creating Children You Didn't Know Existed revisited
Current Time: Sun Jul 27 11:51:45 EDT 2025
Powered by FUDForum. Page generated in 0.08084 seconds
