Home » Eclipse Projects » Equinox » NoClassDefFoundError starting org.eclipse.equinox.registry(NoClassDefFoundError BundleException starting org.eclipse.equinox.registry)
NoClassDefFoundError starting org.eclipse.equinox.registry [message #637945] Tue, 09 November 2010 07:40 Go to next message
I am getting this when starting org.eclipse.equinox.registry
java.lang.NoClassDefFoundError: org/osgi/framework/BundleException
at org.eclipse.core.internal.registry.osgi.EclipseBundleListene r.addBundle(EclipseBundleListener.java:177)
at org.eclipse.core.internal.registry.osgi.EclipseBundleListene r.processBundles(EclipseBundleListener.java:90)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .onStart(RegistryStrategyOSGI.java:224)
at org.eclipse.core.internal.registry.ExtensionRegistry.<init>(ExtensionRegistry.java:725)
at org.eclipse.core.runtime.RegistryFactory.createRegistry(Regi stryFactory.java:58)
at org.eclipse.core.internal.registry.osgi.Activator.startRegis try(Activator.java:137)
at org.eclipse.core.internal.registry.osgi.Activator.start(Acti vator.java:56)
My config.ini says:
osgi.bundles=\
org.eclipse.equinox.common@2:start,\
org.eclipse.equinox.concurrent@3:start,\
org.eclipse.core.jobs@3:start,\
org.eclipse.core.runtime@3:start,\
org.eclipse.equinox.registry@3:start,\
org.eclipse.equinox.preferences@3:start,\
org.eclipse.core.contenttype@3:start,\
The System bundle which is org.eclipse.osgi at [0] is exporting org.osgi.framework
The Manifest.MF on org.eclipse.equinox.registry imports org.osgi.framework.
I haven't seen this reported elsewhere.
Does anyone have any ideas on this?
Robert
Re: NoClassDefFoundError starting org.eclipse.equinox.registry [message #637964 is a reply to message #637945] Tue, 09 November 2010 08:51 Go to previous messageGo to next message
I have never seen this. It is quite strange because the class org.eclipse.core.internal.registry.osgi.Activator implements org.osgi.framework.BundleActivator so we know that the registry bundle's class loader is able to load some at least some classes from the org.osgi.framework package.
What version of equinox are you using?
Tom.
Re: NoClassDefFoundError starting org.eclipse.equinox.registry [message #637975 is a reply to message #637964] Tue, 09 November 2010 09:07 Go to previous messageGo to next message
Tom
Thanks for your reply
I am starting equinox with
java -jar plugins/org.eclipse.osgi_3.6.0.v20100517.jar
and am using
org.eclipse.equinox.registry_3.5.0.v20100503.jar
I have used the property:
org.osgi.framework.system.packages.extra= \
in config.ini
in order to acquire access to some further packages and I also have
eclipse.ignoreApp=true
Robert
Re: NoClassDefFoundError starting org.eclipse.equinox.registry [message #883387 is a reply to message #637975] Fri, 08 June 2012 08:30 Go to previous message
Did you ever resolve this?
I am having the exact same problem ...
Previous Topic:How to stop already running OSGi frameworks from IDE
Next Topic:Configuring jetty, support for Thread parameters
Current Time: Sat Jul 26 18:20:25 EDT 2025
Powered by FUDForum. Page generated in 0.04513 seconds
