Home » Newcomers » Newcomers » Error msg: No command output when running(I might have done some configuration changes in Eclipse ...)
Error msg: No command output when running [message #637820] Mon, 08 November 2010 21:50 Go to next message
and ever since I got this error msg for every application created, uploaded and ran on the emulator. However, all applications ran well on the emulator. Any ideas what's the cause & how to fix it?
Severity: Error
Message: No command output when running: 'am start -n curtis.tetrahedra.bouncing.ii/curtis.tetrahedra.bouncing.ii. CurtisII -a android.intent.action.MAIN -c android.intent.category.LAUNCHER' on device emulator-5554
Exception Stack Trace:
com.android.ddmlib.ShellCommandUnresponsiveException
at com.android.ddmlib.AdbHelper.executeRemoteCommand(AdbHelper. java:408)
at com.android.ddmlib.Device.executeShellCommand(Device.java:27 7)
at com.android.ide.eclipse.adt.internal.launch.ActivityLaunchAc tion.doLaunchAction(Unknown Source)
at com.android.ide.eclipse.adt.internal.launch.AndroidLaunchCon troller.launchApp(Unknown Source)
at com.android.ide.eclipse.adt.internal.launch.AndroidLaunchCon troller.simpleLaunch(Unknown Source)
at com.android.ide.eclipse.adt.internal.launch.AndroidLaunchCon troller.access$3(Unknown Source)
at com.android.ide.eclipse.adt.internal.launch.AndroidLaunchCon troller$3.run(Unknown Source)
Session Data:
eclipse.buildId=M20100909-0800
java.version=1.6.0_22
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_TW
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.java.product
Re: Error msg: No command output when running [message #637821 is a reply to message #637820] Mon, 08 November 2010 21:55 Go to previous messageGo to next message
>[snip]
stackOverflow is a good forum for this sort of thing.
Re: Error msg: No command output when running [message #1018179 is a reply to message #637820] Wed, 13 March 2013 06:20 Go to previous messageGo to next message
Hi. I'm having the same exact problem. Please tell me you solved and how, it's driving me crazy.
Thank you in advance.
Re: Error msg: No command output when running [message #1049358 is a reply to message #1018179] Thu, 25 April 2013 14:54 Go to previous message
I too have gone crazy with this problem...
Finally solved it with a simple configuration on Eclipse:
- Window --> Preferences
- Select Android -> DDMS from left panel
- Increase value of "ADB connection time out (ms)"
Previous Topic:Install Help
Next Topic:modules don't get loaded into interactive-shell [SOLVED]
Current Time: Thu Jul 24 22:31:51 EDT 2025
Powered by FUDForum. Page generated in 0.31294 seconds
