Wizard with xwt [message #636960] |
Wed, 03 November 2010 10:32  |
Is it possible to define wizard's pages with XWT ?
Have you got a simple example ?
My aim is to reuse a page (ie a XWT file) in several wizard.
Thank you.
Re: Wizard with xwt [message #637172 is a reply to message #636960] |
Thu, 04 November 2010 09:12   |
I reply to me because I found a solution. I added a class XWTWizardPage which load XWT file.
package myproject.ui;
public class XWTWizardPage extends WizardPage {
private Object dataContext;
private BindingContext bindingContext;
private AggregateValidationStatus validationStatus;
private Class<?> contentCLS;
* @param _pageName
protected XWTWizardPage(String _pageName, Class<?> contentCLS,
Object dataContext) {
super(_pageName);
this.contentCLS = contentCLS;
this.dataContext = dataContext;
this.bindingContext = null;
protected XWTWizardPage(String pageName, String title,
ImageDescriptor titleImage, Class<?> contentCLS,
super(pageName, title, null);
public void createControl(Composite _parent) {
if (bindingContext == null) {
bindingContext = new BindingContext(_parent);
validationStatus = bindingContext.getStatus();
validationStatus.addChangeListener(new IChangeListener() {
public void handleChange(ChangeEvent event) {
IStatus status = (IStatus) validationStatus.getValue();
setMessage(status.getMessage(), status.getSeverity());
ClassLoader classLoader = Thread.currentThread()
.getContextClassLoader();
try {
Thread.currentThread().setContextClassLoader(
contentCLS.getClassLoader());
HashMap<String, Object> newOptions = new HashMap<String, Object>();
newOptions.put(XWTLoader.CONTAINER_PROPERTY, _parent);
Object dataContext = getDataContext();
if (dataContext != null) {
newOptions.put(XWTLoader.DATACONTEXT_PROPERTY, dataContext);
BindingContext bindingContext = getBindingContext();
if (bindingContext != null) {
newOptions.put(XWTLoader.BINDING_CONTEXT_PROPERTY,
bindingContext);
newOptions.put(XWTLoader.CLASS_PROPERTY, contentCLS);
Control control = XWT.loadWithOptions(getContentURL(), newOptions);
control.setParent(_parent);
setPageComplete(true);
setControl(control);
} catch (Exception e) {
e.printStackTrace();
} finally {
Thread.currentThread().setContextClassLoader(classLoader);
_parent.setVisible(true);
public URL getContentURL() {
if (contentCLS != null) {
return contentCLS.getResource(contentCLS.getSimpleName()
+ IConstants.XWT_EXTENSION_SUFFIX);
return null;
public Object getDataContext() {
return dataContext;
public BindingContext getBindingContext() {
return bindingContext;
The ActionWizard class is the wizard which add pages:
public class ActionWizard extends Wizard {
private PropagationData m_data;
public ActionWizard() {
super();
public void addPages() {
addPage(new OnePage(FirstPage.class, data)); // data is used for binding in FirstPage.xwt
addPage(new TwoPage(SecondPage.class, data));// data is used for binding in SecondPage.xwt
OnePage.java and TwoPage.java extend XWTWizardPage.java.
Then, you have to define FirstPage.xwt which contains a Composite, and FirstPage.java which extends Composite.
The same for SecondPage.
Re: Wizard with xwt [message #637615 is a reply to message #637172] |
Sun, 07 November 2010 16:42   |
Can you fill a bug in bugzilla and add your code in it? It helps the
integration in XWT.
Best regards
Yves YANG
"Valoueee" <val.dupin@free.fr> wrote in message
news:iaub9b$o9j$1@news.eclipse.org...
> Hello,
> * @param _pageName
> super(_pageName);
> @Override
> try {
> Object>();
> dataContext);
> bindingContext);
> } finally {
> return null; }
> return dataContext;
> super();
> public void addPages() { addPage(new OnePage(FirstPage.class,
FUDForum. Page generated in 0.04483 seconds
