hide NavigationTreeView and StatusLineView [message #636648] |
Tue, 02 November 2010 06:24  |
Originally posted by: matthiasrodler.gmx.net
I use the Riena framework within a common RCP application. Riena adds
two Views:
NavigatinTreeView
StatusLineView
which are shown in the "Show View" dialog in the others folder.
How can I remove them?
Matthias
Re: hide NavigationTreeView and StatusLineView [message #637859 is a reply to message #637842] |
Tue, 09 November 2010 03:14   |
o.e.r.client is an empty bundle that just helps to manage dependencies. So instead of being dependant on individual
bundles you can be dependant on o.e.r.client and that gets you everything.
If you only want a part of Riena, then remove o.e.r.client and make you app dependant on the individual bundles that you
need.
christian
Am 09.11.10 07:28, schrieb Matthias Rodler:
> If I try to validate the my product it will tell me that your listed
> bundles are required by o.e.r.client.
> Matthias
> Am 08.11.2010 21:01, schrieb Matthias Rodler:
>> Thanks Christian for your answer I will remove those bundles.
>> Is it possible to use the riena navigation in a rcp application?
>> Matthias
>> Am 08.11.2010 09:13, schrieb Christian Campo:
>>> Hi Matthias,
>>> do you use the Navigation View in your application or do you just use
>>> Ridgets. If you just use Ridgets, you dont need to deploy the bundles
>>> with o.e.r.navigation.* or o.e.r.workarea
>>> That should help
>>> christian
>>> Am 02.11.10 11:24, schrieb Matthias Rodler:
>>>> Hi,
>>>> two Views:
>>>> NavigatinTreeView
>>>> StatusLineView
>>>> Thanks,
>>>> Matthias
Re: hide NavigationTreeView and StatusLineView [message #639543 is a reply to message #637860] |
Tue, 16 November 2010 15:36  |
Originally posted by: matthias.rodler.gmx.net
I meant the "classic" RCP without the Riena UI. I'm currently using the
rcp view with the attached controller class and Ridgets as much as I can
(I still need TableViewer/TreeViewer).
I removed any the dependencies to the named bundles. This removed the views.
Matthias
Am 09.11.2010 09:16, schrieb Christian Campo:
> Not sure what that means. Riena IS an RCP based application framework.
> So every Riena application is also an RCP application.
> If the question is whether you can reuse RCP Views in Riena. Most
> certainly you can. There are must multiple RCP Mail sample projects in
> Riena. One shows how you can embedd a Riena view (which is an RCP View
> with an extra controller class). The other shows how you can embedd a
> plain unmodified RCP view in a Riena navigation based app.
> So what exactly is your use case ?
> christian
> Am 08.11.10 21:01, schrieb Matthias Rodler:
>> Matthias
>>> Hi Matthias,
>>> That should help
>>> christian
>>>> Hi,
>>>> two Views:
>>>> NavigatinTreeView
>>>> StatusLineView
>>>> Thanks,
>>>> Matthias
FUDForum. Page generated in 0.09192 seconds
