Home » Eclipse Projects » Eclipse 4 » Wizard with xwt
Wizard with xwt [message #636960] Wed, 03 November 2010 10:32 Go to next message
Is it possible to define wizard's pages with XWT ?
Have you got a simple example ?
My aim is to reuse a page (ie a XWT file) in several wizard.
Thank you.
Re: Wizard with xwt [message #637172 is a reply to message #636960] Thu, 04 November 2010 09:12 Go to previous messageGo to next message
I reply to me because I found a solution. I added a class XWTWizardPage which load XWT file.
package myproject.ui;
public class XWTWizardPage extends WizardPage {
    private Object dataContext;
    private BindingContext bindingContext;
    private AggregateValidationStatus validationStatus;
    private Class<?> contentCLS;
     * @param _pageName
    protected XWTWizardPage(String _pageName, Class<?> contentCLS,
            Object dataContext) {
        super(_pageName);
        this.contentCLS = contentCLS;
        this.dataContext = dataContext;
        this.bindingContext = null;
    protected XWTWizardPage(String pageName, String title,
            ImageDescriptor titleImage, Class<?> contentCLS,
        super(pageName, title, null);
    public void createControl(Composite _parent) {
        if (bindingContext == null) {
            bindingContext = new BindingContext(_parent);
        validationStatus = bindingContext.getStatus();
        validationStatus.addChangeListener(new IChangeListener() {
                public void handleChange(ChangeEvent event) {
                        IStatus status = (IStatus) validationStatus.getValue();
                        setMessage(status.getMessage(), status.getSeverity());
        ClassLoader classLoader = Thread.currentThread()
                        .getContextClassLoader();
        try {
                Thread.currentThread().setContextClassLoader(
                                contentCLS.getClassLoader());
                HashMap<String, Object> newOptions = new HashMap<String, Object>();
                newOptions.put(XWTLoader.CONTAINER_PROPERTY, _parent);
                Object dataContext = getDataContext();
                if (dataContext != null) {
                        newOptions.put(XWTLoader.DATACONTEXT_PROPERTY, dataContext);
                BindingContext bindingContext = getBindingContext();
                if (bindingContext != null) {
                        newOptions.put(XWTLoader.BINDING_CONTEXT_PROPERTY,
                                        bindingContext);
                newOptions.put(XWTLoader.CLASS_PROPERTY, contentCLS);
                Control control = XWT.loadWithOptions(getContentURL(), newOptions);
                control.setParent(_parent);
                setPageComplete(true);
                setControl(control);
        } catch (Exception e) {
                e.printStackTrace();
        } finally {
                Thread.currentThread().setContextClassLoader(classLoader);
                _parent.setVisible(true);
    public URL getContentURL() {
        if (contentCLS != null) {
                return contentCLS.getResource(contentCLS.getSimpleName()
                                + IConstants.XWT_EXTENSION_SUFFIX);
        return null;
    public Object getDataContext() {
            return dataContext;
    public BindingContext getBindingContext() {
            return bindingContext;
The ActionWizard class is the wizard which add pages:
public class ActionWizard extends Wizard {
    private PropagationData m_data;
    public ActionWizard() {
        super();
      public void addPages() {
        addPage(new OnePage(FirstPage.class, data)); // data is used for binding in FirstPage.xwt
        addPage(new TwoPage(SecondPage.class, data));// data is used for binding in SecondPage.xwt
OnePage.java and TwoPage.java extend XWTWizardPage.java.
Then, you have to define FirstPage.xwt which contains a Composite, and FirstPage.java which extends Composite.
The same for SecondPage.
Re: Wizard with xwt [message #637615 is a reply to message #637172] Sun, 07 November 2010 16:42 Go to previous messageGo to next message
Can you fill a bug in bugzilla and add your code in it? It helps the
integration in XWT.
Best regards
Yves YANG
"Valoueee" <val.dupin@free.fr> wrote in message
news:iaub9b$o9j$1@news.eclipse.org...
> Hello,
> * @param _pageName
> super(_pageName);
> @Override
> try {
> Object>();
> dataContext);
> bindingContext);
> } finally {
> return null; }
> return dataContext;
> super();
> public void addPages() { addPage(new OnePage(FirstPage.class,
Re: Wizard with xwt [message #637648 is a reply to message #637615] Mon, 08 November 2010 03:37 Go to previous messageGo to next message
Are you sure it's a bug ? I think It's a lack no ?
Re: Wizard with xwt [message #637808 is a reply to message #637648] Mon, 08 November 2010 18:19 Go to previous messageGo to next message
It is not a bug. But eclipse uses the bugzilla to handle each case. It is
the way we work.
Best regards
Yves YNAG
news:ib8cli$ekk$1@news.eclipse.org...
> Hello,
Re: Wizard with xwt [message #639385 is a reply to message #636960] Tue, 16 November 2010 05:57 Go to previous message
The bug is created here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=330332
Please join this bug to discuss the design and follow the integration and development.
[Updated on: Tue, 16 November 2010 05:58] by Moderator
Previous Topic:Consistent duplication of custom xwt UI
Next Topic:Can't reopen a persisted closed part!
Current Time: Sat Jul 26 06:45:18 EDT 2025
Powered by FUDForum. Page generated in 0.04528 seconds
