Home » Modeling » EMF » EMT Transactions(EMF Transaction spanning multiple Operations/Commands)
EMT Transactions [message #637517] Fri, 05 November 2010 20:27 Go to next message
Hi all,
currently I'm trying to implement a batch job consisting of a bunch of Commands/Operations. All operation are required to run in a single "transaction".
Unfortunatelly EMF executes each operation inside a single EMFTransatcion. Using a UndoContext as logical transaction context could solve the problem but EMF internally manages the UndoContext to be bound to the underlying resource. For me this makes no sense since when rolling back I just want to undo my "own" operations, not the operations made by other threads on the same resource.
What I need is something like:
#1 BeginOfTransaction (In a custom Context, let's say "MyBatchJob")
#2 Execute Operation 1..n
#3 Commit / Rollback Transaction (of Context "MyBatchJob")
The documented "Batch-Approach" using IResourceChangeListener woun't work for the same reason. It's triggered on each Operation, not on groups of operations.
Probably I confused the sence of EMFT, can someone please tell me if EMFT is the right solution for my task?
[Updated on: Sat, 04 December 2010 19:40] by Moderator
Re: EMT Transactions [message #637541 is a reply to message #637517] Sat, 06 November 2010 06:32 Go to previous messageGo to next message
Mischa,
I'm not sure if anyone is actively monitoring questions about
transaction. One can only hope...
Mischa wrote:
> Hi all,
> "transaction".
> be bound to the underlying resource. For me this makes no sence since
If other threads are making changes, those changes might well affects
the same objects you're changing, so most certainly you should expect
there to be single chain of undoable operations.
Re: EMT Transactions [message #637550 is a reply to message #637517] Sat, 06 November 2010 11:04 Go to previous messageGo to next message
Hi Mischa,
I don't think that EMF Transactions can do this for you. If you need object-grained locking, transactionality without the cooperation of the applications, multiple transactions on the same object graph including rollback of individual transactions, then you may want to have a look at CDO: http://www.eclipse.org/cdo
Cheers
/Eike
http://www.esc-net.de
Am 06.11.2010 01:27, schrieb Mischa:
> Hi all,
> Unfortunatelly EMF executes each operation inside a single EMFTransatcion. Using a UndoContext as logical transaction context could solve the problem but EMF internally manages the UndoContext to be bound to the underlying resource. For me this makes no sence since when rolling back I just want to undo my "own" operations, not the operations made by other threads on the same resource.
Re: EMT Transactions [message #637551 is a reply to message #637550] Sat, 06 November 2010 11:14 Go to previous messageGo to next message
--------------070104020701010606050504
BTW., with CDO it would look like this:
|CDOSession session = config.openSession();
CDOTransaction transaction = session.openTransaction();
Resource resource = transaction.getResource("/things/res.xml");
EObject root = resource.getContents().get(0);
process_X(root);
CDOSavepoint savepoint = transaction.setSavepoint();
process_Y(root);
savepoint.rollback();
*if *(ok)
transaction.setCommitComment("Changes from process X");
CDOCommitInfo commitInfo = transaction.commit();
System.out.println(commitInfo.getTimeStamp());
*else*
transaction.rollback();
session.close();|
Note that you can open multiple transactions on the session that all share their state until objects get modified.
Cheers
/Eike
Am 06.11.2010 16:04, schrieb Eike Stepper:
> Hi Mischa,
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> Hi all,
Content-Type: text/html; charset=UTF-8
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
BTW., with CDO it would look like this:<br>
<br>
<title></title>
<style type="text/css">
<!--code { font-family: Courier New, Courier; font-size: 10pt; margin: 0px; }-->
</style>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
<!-- = Java Sourcecode to HTML automatically converted code = -->
<!-- = Java2Html Converter 5.0 [2006-02-26] by Markus Gebhard markus@jave.de = -->
<!-- = Further information: http://www.java2html.de = -->
<div class="java" align="left">
<table bgcolor="#ffffff" border="0" cellpadding="3"
cellspacing="0">
<tbody>
<tr>
<!-- start source code --> <td nowrap="nowrap" align="left"
valign="top"> <code>
<font color="#ffffff">    </font><font color="#000000">CDOSession session = config.openSession </font><font
color="#000000">()</font><font color="#000000">;</font><br>
<font color="#ffffff">    </font><font color="#000000">CDOTransaction transaction = session.openTransaction </font><font
<font color="#ffffff"></font><br>
<font color="#ffffff">    </font><font color="#000000">Resource resource = transaction.getResource </font><font
color="#000000">(</font><font color="#2a00ff">"/things/res.xml"</font><font
color="#000000">)</font><font color="#000000">;</font><br>
<font color="#ffffff">    </font><font color="#000000">EObject root = resource.getContents</font ><font
color="#000000">()</font><font color="#000000">.get</font><font
color="#000000">(</font><font color="#990000">0</font><font
<font color="#ffffff">    </font><font color="#000000">process_X</font><font
color="#000000">(</font><font color="#000000">root</font><font
<font color="#ffffff">    </font><font color="#000000">CDOSavepoint savepoint = transaction.setSavepoint </font><font
<font color="#ffffff">    </font><font color="#000000">process_Y</font><font
<font color="#ffffff">    </font><font color="#000000">savepoint.rollback</font><font
<font color="#ffffff">    </font><font color="#7f0055"><b>if </b></font><font
color="#000000">(</font><font color="#000000">ok</font><font
color="#000000">)</font><br>
<font color="#ffffff">    </font><font color="#000000">{</font><br>
<font color="#ffffff">      </font><font color="#000000">transaction.setCommitComment</font><font
color="#000000">(</font><font color="#2a00ff">"Changes from process X"</font><font
<font color="#ffffff">      </font><font color="#000000">CDOCommitInfo commitInfo = transaction.commit </font><font
<font color="#ffffff">      </font><font color="#000000">System.out.println</font><font
color="#000000">(</font><font color="#000000">commitInfo.getTimeStamp</font><font
color="#000000">())</font><font color="#000000">;</font><br>
<font color="#ffffff">    </font><font color="#000000">}</font><br>
<font color="#ffffff">    </font><font color="#7f0055"><b>else</b></font><br>
<font color="#ffffff">      </font><font color="#000000">transaction.rollback</font><font
<font color="#ffffff">    </font><font color="#000000">session.close</font><font
color="#000000">()</font><font color="#000000">;</font></code>
</td>
<!-- end source code --> </tr>
</tbody>
</table>
</div>
<!-- = END of automatically generated HTML code = -->
<br>
share their state until objects get modified.<br>
<br>
Cheers<br>
/Eike<br>
<br>
----<br>
<a class="moz-txt-link-freetext" href="http://www.esc-net.de">http://www.esc-net.de</a><br>
<a class="moz-txt-link-freetext" href="http://thegordian.blogspot.com">http://thegordian.blogspot.com</a><br>
<a class="moz-txt-link-freetext" href="http://twitter.com/eikestepper">http://twitter.com/eikestepper</a><br>
<br>
<br>
<br>
<blockquote cite="mid:ib3qir$jlh$1@news.eclipse.org" type="cite">Hi
Mischa,
<br>
<br>
you may want to have a look at CDO: <a class="moz-txt-link-freetext" href="http://www.eclipse.org/cdo">http://www.eclipse.org/cdo</a>
<br>
<br>
Cheers
<br>
/Eike
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<blockquote type="cite">Hi all,
<br>
<br>
<br>
the same resource.
<br>
<br>
<br>
"MyBatchJob")
<br>
<br>
<br>
<br>
<br>
me if EMFT is the right solution for my task? </blockquote>
</blockquote>
</body>
</html>
--------------070104020701010606050504--
Re: EMT Transactions [message #637555 is a reply to message #637550] Sat, 06 November 2010 11:56 Go to previous messageGo to next message
Hello Eike,
thanks a lot, this is exactly what I'm looking for. You saved me a lot of time going further with EMF-Transaction which seems to be applied for other scenarios.
Re: EMT Transactions [message #637567 is a reply to message #637555] Sat, 06 November 2010 14:28 Go to previous messageGo to next message
Am 06.11.2010 16:56, schrieb Mischa:
> Hello Eike,
You're welcome. If you're not yet familiar with CDO I guess that you'll want to come back with more questions ;-)
Note that CDO comes with its own resources, which are mapped to databases or similar backends!
Cheers
/Eike
Re: EMT Transactions [message #637596 is a reply to message #637567] Sun, 07 November 2010 09:30 Go to previous messageGo to next message
Hi Eike,
is there also a kind of server abstraction with direct access to ECoreResources? Let's say I use the Lecacy-API just to make use of the Transaction mechanisms but changes are populated to the underlying ECore-Resource directly instead of being delegated to a physical CDO-Server.
Re: EMT Transactions [message #637601 is a reply to message #637596] Sun, 07 November 2010 09:36 Go to previous message
Am 07.11.2010 15:30, schrieb Mischa:
> Hi Eike,
As I said, CDOTransactions do only work with CDOResources.
Cheers
/Eike
Previous Topic:Mixing intrinsic and extrinsic IDs
Next Topic:Reference not properly loaded from XML file
Current Time: Sun Jul 27 22:25:22 EDT 2025
Powered by FUDForum. Page generated in 0.05106 seconds
