Home » Modeling » TMF (Xtext) » Can't get Importing Namespaces to work
Can't get Importing Namespaces to work [message #636939] |
Wed, 03 November 2010 09:22  |
I am trying to use namespace aware importing (Xtext 1.0.0), in such a way that I can import things like:
import file1.*
I followed the instructions in the manual and the example of the domainmodel, but still I can't get it to work. What am I forgetting?
My rules in de grammar look as follows:
Import:
'import' importedNamespace=QualifiedNameWithWildCard
QualifiedNameWithWildCard:
QualifiedName '.*'
QualifiedName:
ID ('.' ID)*
Bar:
'bar' name=ID
Foo:
'foo' barreference=[Bar|QualifiedName]
My workflow contains the following relevant fragments:
(The other ones are outcommented)
fragment = scoping.ImportNamespacesScopingFragment {}
fragment = exporting.QualifiedNamesFragment {}
And my scope-provider, which I have not implemented anything in, yet:
public class FoobarScopeProvider extends ImportedNamespaceAwareLocalScopeProvider {
Now, say I have a file written in this grammar called foobar2, containing:
and my main file foobar1 contains the following:
import foobar2.*
foo foobar2.barlabel
Is this how this should work? In my current tests, my editor cannot see the imported elements: foobar2.barlabel cannot be found.
I hope someone has some clues as to where my error could be, or what I am forgetting. If I should provide more information, please let me know.
Re: Can't get Importing Namespaces to work [message #637115 is a reply to message #636939] |
Thu, 04 November 2010 05:27   |
Okay... So, to see if I understand: Because ImportedNamespaceAwareLocalScopeProvider uses this DefaultDeclaritiveQualifiedNameProvider, you can not refer to the filename (the resource), so I should override this function.
Yes, that is helpful, I can do that, but I think my problem is something else. More basic, perhaps. The linking isn't established at all, I need to understand the ImportedNamespaceAwareLocalScopeProvider.
If, for example, each file has a top level element called 'Model', with a name=ID , which contains the imports, I should be able to use elements from the other files if I import this Model, right?
So, if my entry rule looks like this:
Model:
name=ID
imports+=Import*
foos+=Foo*
bars+=Bar*
What do I need to type after 'import' to be able to reference all the elements from within another file?
<filename>.<Modelname>.*
or
<Modelname>.*
I do not get any suggestions from the editor in this. It cannot make the link. The files are in the same directory, and if I use other scoping methods (such as the DefaultGlobalScopeProvider), it finds everything, but that is also not what I want. I would like to be able to only import certain namespaces.
Re: Can't get Importing Namespaces to work [message #637425 is a reply to message #637115] |
Fri, 05 November 2010 08:49  |
I'd recommend to read the section on scoping in the docs.
Qualified names are by default composed of the names of the object and
all its containers. In you case, the file name, too.
An importedNamespace only makes elements from the global scope available
by a name that's the fully qualified name without the importedNamespace
as a prefix. If your objects are further nested, the import might not
work as you expect.
It also sounds like you want an implicit import for elements in the same
file. You could add this by overriding
org.eclipse.xtext.scoping.impl.ImportedNamespaceAwareLocalSc opeProvider.internalGetImportNormalizers(EObject)
Jan
Am 04.11.10 10:27, schrieb Thomas Delissen:
> Model: name=ID
> imports+=Import*
> foos+=Foo*
> bars+=Bar*
> <filename>.<Modelname>.* or
> <Modelname>.*
> certain namespaces.
Current Time: Fri Jul 18 17:19:31 EDT 2025
Powered by FUDForum. Page generated in 0.06314 seconds
