Home » Modeling » Epsilon » EMF Register breaking GMF Editors?
EMF Register breaking GMF Editors? [message #637410] Fri, 05 November 2010 08:37 Go to next message
Hi!
I'm not sure, if this question has already been asked/answered, but I could not find any reference in the forum.
Anyway, my problem is that whenever I run my ETL transformation my GMF editors are not able to display my models anymore. Everything is back to normal, when I restart Eclipse. Is this somehow related to the epsilon.emf.register?
Henning
Re: EMF Register breaking GMF Editors? [message #637411 is a reply to message #637410] Fri, 05 November 2010 08:40 Go to previous messageGo to next message
Hi Henning,
If you have generated code from your Ecore metamodel, you should not be
calling the emf.emf.register task as the metamodel is already registered.
Dimitris
Henning wrote:
> Hi!
> Best regards,
> Henning
Re: EMF Register breaking GMF Editors? [message #637452 is a reply to message #637411] Fri, 05 November 2010 10:55 Go to previous message
Ok, that solved my problem! Even though I need to register all meta model now manually, but - oh, well at least it works!
Thanks a lot!
Henning
Previous Topic:Using registered meta model
Next Topic:EMF target model with xmi:id
Current Time: Sat Jul 26 19:24:28 EDT 2025
Powered by FUDForum. Page generated in 0.23353 seconds
